    Starting MM Crontab
    15 Posts 3 Posters 2.1k Views 3 Watching
    • mumblebajM Offline
      mumblebaj Module Developer
      Hi.
      I have been using crontab to start my MM for ages and it has always worked well. After updating it no longer seems to work. cron calls a script that has the following.
      DISPLAY=0 npm start
      Now, I have seen that it is suggest to use node --run start:X11 going forward and I have updated my start script with same but that does not seem to work either.
      So my mm.sh now looks like,
      DISPLAY=0 node --run start:X11
      But as mentioned, this does not work.
      Any ideas?
      • KristjanESPERANTOK Offline
        KristjanESPERANTO Module Developer @mumblebaj
        @mumblebaj said in Starting MM Crontab:
        It should be start:x11 and not start:X11.
        Are you still using X11?
        Does it run when you start it manually?
        Can you provide the logs from the startup?
          mumblebaj Module Developer @KristjanESPERANTO
          @KristjanESPERANTO Sorry, typo, it is lower x. It start when I manually run npm start. When I manually run node --run start:x11 it works fine. When I manually run the script ./mm.sh it works fine. When calling it from the cron nothing. In my log I see the command node --run start:x11 but MM does not launch.
            sdetweil @mumblebaj
            @mumblebaj is the cron jon in the user crontab (contrab -e) ? or root (sudo crontab -e) ?
            if root, the pm2 job doesn’t exist there, it opnly exists under user who created the pm2 job
              @sdetweil in my user, crontab -e. It worked just fine until I updated my mirror this morning. I don’t use pm2 on my installation for my own reasons… 😉
                sdetweil @mumblebaj
                only MM update?
                note that we changed the startup strings.
                “start”: “node --run start:x11”,
                  @sdetweil Yep, only MM update. Let me try start: node --run start:x11 and see what happens.
                    @mumblebaj Just an idea: Maybe the node version used in Cron could be to old. When you run a script manually in your terminal, your full user environment (including things like .bashrc or .zshrc) is loaded. Cron runs in a much more minimal environment — it often doesn’t load your shell config files, so tools like nvm (Node Version Manager) might not be available.
                    How to fix it:
                    • Use the full path to Node: Find it with which node and use that path in your cron job.
                    • Set the environment manually in cron: You can define your PATH at the top of the cron file.
                    • Source nvm in your script: If you use nvm, add source ~/.nvm/nvm.sh and nvm use <version> before calling node.
                    mumblebajM 1 Reply Last reply Reply Quote 1
                      @KristjanESPERANTO Thanks Kristjan. But I don’t see how updating MM could cause this. I only updated MM with Sam’s upgrade script. Don’t see how that has changed anything with regards to how Crontab works. Maybe it is related to changing the launch to node --run start. I can see the command being fired in the log but it does not launch MM like it did before the upgrade.
                      Anyhow, I manually launch it for now till I find a suitable solution.
                        sdetweil @mumblebaj
                        @mumblebaj did you use npm start before?
                        it ‘may’ be the path as @KristjanESPERANTO mentioned
                        so from the user command line do
                        which node
                        and use that result in the cron command
                        mumblebajM 2 Replies Last reply Reply Quote 0
