    MagicMirror² installation and setup scripts
    Scheduled Pinned Locked Moved Solved Feature Requests
    6 Posts 2 Posters 1.4k Views 2 Watching
    • plainbrokeP Offline
      plainbroke
      Hey Sam,
      on your install and update scripts is there a way to change the directory for installation? IE I would like to change the MagicMirror folder to MM on one pi
      and CM on another. Just curious. I pulled down your raspberry.sh and replaced everything MagicMirror with MM and it installed but then I tried a git pull and it did not work. I did have to change the mm.sh in the installers directory, to look at MM instead of MagicMirror… then do a pm2 delete all and a pm2 start mm.sh then pm2 save and it works now… Just playing around, but got me to thinking. NOT A GOOD THING sometimes… LOL
      S 2 Replies Last reply Reply Quote -1
        sdetweil @plainbroke
        @plainbroke no, but after install you can rename the folder to anything you want
        upgrade could use a parm if you change the name, but you could rename, upgrade, rename back
          @plainbroke i can fix mm.sh too
          plainbrokeP 1 Reply Last reply Reply Quote 1
            plainbroke @sdetweil
            @sdetweil said in MagicMirror² installation and setup scripts:
            I thought as much, about the renaming it back to MagicMirror, upgrade and put it back to MM.
            I have moved the mm.sh out to the home/pi directory, and fixed it to see the correct directory. Then I fixed the mm.json to point to the mm.sh in home directory.
            That way I can only have to fix the mm.sh each time.
            Simple enough
            Don’t think about it too much… It was just a thought…
            • plainbrokeP plainbroke has marked this topic as solved on
              plainbroke @plainbroke
              What do you mean by using a parm?
              Like apply/MM ?
                @plainbroke yes, maybe pass a folder name
