    Need "correct" version of node-libgpiod ....
    22 Posts 3 Posters 3.8k Views 3 Watching
      rkorell Module Developer
      Dear Gurus!
      May one of you got an idea…
      I’m on my way (looooonnnnggggg planned) to re-implement bugsounet’s MMM-Pir, and I am nearly done…
      My last hurdle seems to be the way he has handled the PIR sensor itself. I am not aware if the second way (python script) ever had worked but I stuck with the implementation of the GPIO handler with node-libgpiod.
      This works fine in my environment as-is without any problems.
      Needed dependeny is node-libgpiod.
      I’ve installed this with
      npm install node-libgpiod
      In my own - brand new - module folder - Ran without any error.
      But when mirror is restarted I found an error in logfile, stating that there is a version mismatch…
      0|MagicMir | [2025-08-06 21:13:55.302] [ERROR] 2025-08-06T21:13:55 <error> [MMM-Pir] [LIB] [PIR] [GPIOD] Error: The module '/home/pi/MagicMirror/modules/MMM-PresenceScreenControl/node_modules/node-libgpiod/build/Release/node-libgpiod.node'
      0|MagicMir | was compiled against a different Node.js version using
      0|MagicMir | NODE_MODULE_VERSION 115. This version of Node.js requires
      0|MagicMir | NODE_MODULE_VERSION 128. Please try re-compiling or re-installing
      0|MagicMir | the module (for instance, using `npm rebuild` or `npm install`). (/home/pi/MagicMirror/modules/MMM-PresenceScreenControl/pirLib.js:163 PIR.gpiodDetect)
      My Node Version is:
      pi@MagicMirrorPi5:~ $ node -v
      v20.18.1
      Information of Mirror:
      pm2 info MagicMirror
       Describing process with id 0 - name MagicMirror
      │ status            │ online                                   │
      │ name              │ MagicMirror                              │
      │ namespace         │ default                                  │
      │ version           │ 2.31.0-develop                           │
      │ restarts          │ 40                                       │
      │ uptime            │ 59s                                      │
      │ script path       │ /home/pi/MagicMirror/installers/mm.sh    │
      │ script args       │ N/A                                      │
      │ error log path    │ /home/pi/.pm2/logs/MagicMirror-error.log │
      │ out log path      │ /home/pi/.pm2/logs/MagicMirror-out.log   │
      │ pid path          │ /home/pi/.pm2/pids/MagicMirror-0.pid     │
      │ interpreter       │ bash                                     │
      │ interpreter args  │ N/A                                      │
      │ script id         │ 0                                        │
      │ exec cwd          │ /home/pi                                 │
      │ exec mode         │ fork_mode                                │
      │ node.js version   │ N/A                                      │
      │ node env          │ N/A                                      │
      │ watch & reload    │ ✔                                        │
      │ unstable restarts │ 0                                        │
      │ created at        │ 2025-08-06T19:42:31.312Z                 │
       Divergent env variables from local env
      │ SSH_CONNECTION │ 172.23.56.21 53109 172.23.56.157 22 │
      │ TERM           │ xterm                               │
      │ SHLVL          │ 2                                   │
      │ XDG_SESSION_ID │ 4                                   │
      │ SSH_CLIENT     │ 172.23.56.21 53109 22               │
      │ OLDPWD         │ /home/pi/MagicMirror/splashscreen   │
      An “idea” is that there is a mismatch between node version in my terminal and node version used by mirror.
      Mirror gave me no information about it’s version…
      Maybe I’m completely on a wrong way…
      Can somebody please guide me?
      Thanks a LOT!
      Warmest regards,
      Ralf
        sdetweil @rkorell
        @rkorell
        so, if, in the module folder you do
        npm rebuild
        it will fix the version to the standalone node engine
        if you do
        electron-rebuild
        it should fix the version to the electron embedded node engine
        if the engine is the same, only one of those is required
          sdetweil @rkorell
          @rkorell yes, that is what @electron/rebuild does
          recompiles the module (from source) to match
          in the magicmirror folder , if not already installed
          (my install and upgrade scripts install it for you )
          npm install @electron/rebuild
          then in the module folder do
          ../../node_modules/.bin/electron-rebuild
          a module needing this should have a postinstall script in package.json to invoke this command
            @sdetweil Dear Sam,
            thanks for this information.
            Can you please enlighten me?
            I can read what you wrote and I got a light idea - but didn’t understand …
            I definitely have used your install script.
            what is @electron and
            what correlation is between node-libgpiod and @electron ? and what will this
            do?
            Sorry for these questions - I would like to understand, what happens.
            If this is “neccessary” I will try to automate this for others with a postinstall script.
            Thanks for your effort!
            warmest regards,
            Ralf
            S 2 Replies Last reply Reply Quote 1
              sdetweil @rkorell
              @rkorell javascript is compiled to a byteform by the nodejs engine
              there is one embedded inside electron and one outside,
              nodejs
              the bytecode has a version number.
              the engine needs the proper version to execute it
              like version 21 added a new instruction, but vers 20 engine cant execute it
              i dont know the version differences
              anyhow, the electron-rebuild application will rebuild the parts of the js code used in the node_helper to match the internal/embedded node engine inside electron
              because startup is using the electron app
              in server mode we use the mode app
              you should know if you run
              node serveronly, then the bytecode has to match the nodejs standalone engine version
              this is why we try to keep the nodejs/electron internal node versions the same
              (there is a node rebuild too)
                sdetweil @rkorell
                @rkorell here is the postinstall i provide for a couple modules
                #!/bin/bash
                base=~/MagicMirror
                logfile=/dev/null
                if [ ! -e $base/node_modules/@electron/rebuild ];  then
                    cd $base
                    if [ -e $base/node_modules/.bin/electron-rebuild ]; then
                	# remove the old version
                      npm uninstall electron-rebuild >>$logfile 2>&1
                    fi
                    # install the new version
                    npm install @electron/rebuild >>$logfile 2>&1
                    cd - >/dev/null
                fi
                they changed the name of the npm package
                but as i install it as part of install/upgrade
                its correct most of the time
                and in package.json, in the scripts section add
                "postinstall":"./postinstall"
                  OK, thanks.
                  It seems that rebuild have corrected the error for the module.
                  When I try to run a node-command in the shell (terminal) then I get an similar error message as above.
                  Is this caused by your explanation part above?
                  Different versions needed for either terminal or inside mirror?
                  Can you tell me HOW the magic mirror is started (when I have used your install script)?
                  Is there a way to test something which had to run in the mirror (like the module) on commandline?
                  To illustrate what I mean:
                  I have a very short test-script test-gpiod.js
                  // test-gpiod.js , Aug 2025, Dr. Ralf Korell
                  const { Chip } = require("node-libgpiod");
                  try {
                    const chip = new Chip(0);
                    console.log("Chip label:", chip.getChipLabel());
                  } catch (err) {
                    console.error("Error loading chip:", err);
                  which I try to run with
                  node test-gpiod.js
                  But this produces error message:
                  /home/pi/MagicMirror/modules/MMM-PresenceScreenControl/node_modules/bindings/bindings.js:121
                  throw e;
                  NODE_MODULE_VERSION 128. This version of Node.js requires
                  NODE_MODULE_VERSION 115. Please try re-compiling or re-installing
                  at Module._extensions..node (node:internal/modules/cjs/loader:1586:18)
                  at Module.load (node:internal/modules/cjs/loader:1288:32)
                  at Module._load (node:internal/modules/cjs/loader:1104:12)
                  at Module.require (node:internal/modules/cjs/loader:1311:19)
                  at require (node:internal/modules/helpers:179:18)
                  at bindings (/home/pi/MagicMirror/modules/MMM-PresenceScreenControl/node_modules/bindings/bindings.js:112:48)
                  at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-PresenceScreenControl/node_modules/node-libgpiod/lib/misc.js:1:37)
                  at Module._compile (node:internal/modules/cjs/loader:1469:14)
                  at Module._extensions..js (node:internal/modules/cjs/loader:1548:10)
                  at Module.load (node:internal/modules/cjs/loader:1288:32) {
                  code: 'ERR_DLOPEN_FAILED'
                  Node.js v20.18.1
                  Thanks for any help!
                  Warmest regards,
                  Ralf
                    sdetweil @rkorell
                    @rkorell MM is started by doing node --run or npm start or npm run start
                    that matches a script in the scripts section of package.json
                    the MagicMirror installed files support 3 different runtimes
                    npm start - full using electron
                    		"start:x11": "DISPLAY=\"${DISPLAY:=:0}\" ./node_modules/.bin/electron  js/electron.js",
                    npm run server - server mode only , using node engine
                    		"server": "node ./serveronly",
                    npm run client - UI mode using electron
                    node clientonly --address 192.168.1.5 --port 8080
                    which does this to launch electron, not it doesn’t use the module node_helpers, as its the UI portion
                    only… the server side (under full, or server only) does that
                    const child = require("node:child_process").spawn(electron, elecParams, options);
                    as I said before, the electron embedded node engines CAN be different than the install standalone nodejs version
                    node -v
                    will tell you the standalone node js version.
                    the problem you have, I mentioned in the prior post, if the node versions don’t match, then
                    you MAY have to recompile when switching runtime choices…
                    npm rebuild
                    will fix the standalone node version
                    electron-rebuild
                    will fix the electron version
                    I believe the current electron version is 22, and the node version we require is 22
                    this is because the standalone node version of 24 has dropped support for 32 bit runtimes… and knocks out using the
                    32 bit legacy raspi OS images that some use…
                    we put out a message to tell the versions when you start MM
                    VERSIONS: electron: 36.6.0; used node: 22.15.0; installed node: 22.15.0; npm: 10.9.2; pm2: 6.0.8
                    SO… fun times… keeping the node versions synched will avoid the problem you are encountering
                      Dear Sam, OK, thanks for this.
                      Not fully understood…
                      How can I
                      1. figure out, how my mirror is started? (looooong ago I‘ve used your install script and (if I remember correctly) I‘ve answered „yes“ to „do you want automatically start your mirror at system startup“ - or something similar. - Never took care about, what is done - it worked (and still works)…)
                      2. double check the above „VERSIONS“ - message - is this message in logfile?
                      3. can I get „keeping the node versions synched“?
                      Thanks for further advise!
                      Warmest regards,
                      Ralf
                        sdetweil @rkorell
                        @rkorell 1. my pm2 setup uses the file
                        ~/MagicMirror/installers/mm.sh
                        you can see that by using the
                        pm2 info xxxx
                        command, where xxx is the name or number of the app row in
                        pm2 status
                        output, from my desktop , note you CAN setup the SAME NAMED app multiple times,
                        so the pm2 start app_name
                        might be ambiguous
                        so pm2 start 8 would target the app on line 8
                        │ id │ name                │ namespace   │ version │ mode    │ pid      │ uptime │ ↺    │ status    │ cpu      │ mem      │ user     │ watching │
                        │ 8  │ MagicMirror         │ default     │ 2.32.0… │ fork    │ N/A      │ 0      │ 245… │ stopped   │ 0%       │ 0b       │ sam      │ disabled │
                        │ 7  │ MagicMirror 8       │ default     │ 2.31.0… │ fork    │ N/A      │ 0      │ 8    │ stopped   │ 0%       │ 0b       │ sam      │ disabled │
                        │ 6  │ MagicMirror1        │ default     │ 2.31.0… │ fork    │ N/A      │ 0      │ 13   │ stopped   │ 0%       │ 0b       │ sam      │ disabled │
                        │ 0  │ Smart Mirror        │ default     │ 0.0.30  │ fork    │ N/A      │ 0      │ 31   │ stopped   │ 0%       │ 0b       │ sam      │ disabled │
                        │ 2  │ checkarec           │ default     │ N/A     │ fork    │ 2870     │ 19D    │ 0    │ online    │ 0%       │ 3.4mb    │ sam      │ disabled │
                        │ 5  │ smart-mirror        │ default     │ 0.0.31  │ fork    │ N/A      │ 0      │ 8    │ stopped   │ 0%       │ 0b       │ sam      │ disabled │
                        │ 4  │ smart-mirror ttt    │ default     │ 0.0.30  │ fork    │ N/A      │ 0      │ 10   │ stopped   │ 0%       │ 0b       │ sam      │ disabled │
                        │ 3  │ start_alexa_bk      │ default     │ N/A     │ fork    │ 2871     │ 19D    │ 0    │ online    │ 0%       │ 2.4mb    │ sam      │ disabled │
                        │ 1  │ startspot           │ default     │ N/A     │ fork    │ 6315     │ 19D    │ 439  │ online    │ 0%       │ 2.5mb    │ sam      │ disabled │
                        │ 9  │ testups             │ default     │ N/A     │ fork    │ 2885     │ 19D    │ 0    │ online    │ 0%       │ 3.2mb    │ sam
                        using pm2, you can view the log with
                        pm2 logs yyy --lines=xxxx
                        yyy is the name or number of the app from status above), if not supplied,
                        output from all managed apps is displayed, 1 after the others
                        xxxx is the count of most recent lines to display (default 15)
                        you can also see the files(.out and .err, by app) in the
                        ~/.pm2/logs
                        folder
                        MM puts out a messages at runtime (this from my desktop system)
                        [2025-08-09 09:47:38.743] [INFO]  System information:
                        ### SYSTEM:   manufacturer: System manufacturer; model: System Product Name; virtual: false
                        ### OS:       platform: linux; distro: Ubuntu; release: 22.04.5 LTS; arch: x64; kernel: 5.15.0-144-generic
                        ### VERSIONS: electron: 36.6.0; used node: 22.15.0; installed node: 22.15.0; npm: 10.9.2; pm2: 6.0.8
                        ### OTHER:    timeZone: America/Chicago; ELECTRON_ENABLE_GPU: undefined
                        notice the versions line
                        keep the node versions synced… yes manually (I use the nodejs version of nvm, called n )
                        if installed this will show the versions installed
                        n list
                        and
                        n
                        will show the list AND the current one, but you have to type q to exit the list
                        (because n updates the /usr/local/bin folder, you have to use sudo to actually install or change the active version)
                        or
                        if you use my install/upgrade script they will make sure the correct standalone version is installed
                        my scripts install and use n if needed to change versions
                          @sdetweil Dear Sam,
                          thanks again for this long explanation!
                          My versions (if I interpret correctly) doesn’t mismatch :-(
                          0|MagicMir | ### SYSTEM:   manufacturer: ; model: ; virtual: false
                          0|MagicMir | ### OS:       platform: linux; distro: Debian GNU/Linux; release: 12; arch: arm64; kernel: 6.12.20+rpt-rpi-2712
                          0|MagicMir | ### VERSIONS: electron: 32.2.7; used node: 20.18.1; installed node: 20.18.1; npm: 10.8.2; pm2: 5.4.3
                          0|MagicMir | ### OTHER:    timeZone: Europe/Berlin; ELECTRON_ENABLE_GPU: undefined
                          So I’m not sure at all, what to do.
                          pi@MagicMirrorPi5:~ $ n list
                          node/20.18.1
                          Does show up exact this version, as well.
                          Where are my problems from ???
                          Thanks a LOT for any idea!
                          Ralf
                            sdetweil @rkorell
                            @rkorell
                            npm rebuild
                            if you do
                            electron-rebuild
                              @sdetweil OK; thanks.
                              I will stop to handle these mismatches.
                              Will try to get the MM-Module runnable .
                              Console/terminal runs with node may not be necessary …
                              Thanks anyway for your kind support!
                              Ralf
                                @sdetweil Dear Sam,
                                just FYI: I’ve just identified that my main problem is NOT the version mismatch but a major change in node-libgpiod’s handling of GPIO-ressources.
                                This was the main reason for mal-function of PIR sensor detection. “Version” was a side effect, not root-cause.
                                I’m nearly done with this and it seems that it will work as intended…
                                Thanks again for your support!
                                Regards,
                                Ralf
                                  sdetweil @rkorell
                                  @rkorell awesome. yes gpio changes are a pain!!
                                    @sdetweil yes, indeed …
                                      schlomm @rkorell
                                      @rkorell Do have any any resources for your current development? I’m also stucking at a similar problem handling GPIO for buttons using a Raspberry Pi 5.
                                      Do you have a Github Repository?
                                        rkorell Module Developer @schlomm
                                        @schlomm I’m absolute beginner …
                                        Had HEAVILY used AI to get this done and have recycled a LOT.
                                        GPIO part is from old (discontinued) module MMM-Pir from Bugsounet.
                                        This is reflected in pirLib.js - sliightly modified for my purposes.
                                        I do have a repository - pushed literally minutes ago …
                                        Feel free to have a look.
                                        Buttons should work with some modification. Essentiall for my purposes I simply query state of a single GPIO pin - to which a PIR sensor is connected. Code must be enhanced to handle more than one pin - if you are talking about “butons” - which signals plural…
                                        As mentioned such modification should be doable with AI as well.
                                        [ EDIT : My system is a raspi5 / bookworm as well - this is main reason for some difficulties. Some procedures simply doesn’t work anymore with new libraries and I had to change implementation…]
                                        Good luck!
                                        Warm regards,
                                        Ralf
                                          @sdetweil Dear Sam,
                                          I was able to get this done - to my big surprise …
                                          As announced, I just have pushed it to git and will post a corresponding message tomorrow.
                                          Do I get it right that it is recommended to edit the modules page as well?
                                          And the 3rd Party Modules page then will populate by itself, right?
                                          Thanks!
                                          Warmest regards,
                                          Ralf
                                            sdetweil @rkorell
                                            @rkorell yes, you edit the wiki page, and then the 3rd party list will pick up those changes on the next refresh (once a day)
                                            • R rkorell has marked this topic as solved on
                                              @sdetweil thx!
