    Help with mmm-systemtemperature error messages
    11 Posts 3 Posters 2.1k Views 3 Watching
    • T Offline
      thartley @sdetweil
      @sdetweil - Thank you for the reply. I don’t know if I did or not because it was some time back. Is that a step I can do now without messing things up if it turns out I already did it earlier? Or is there a way to tell if the npm step was done previously before running it now?
        sdetweil @thartley
        @thartley you can do it now…
        go to the module folder
        cd ~/MagicMirror/modules/mmm-systemtemperature
        npm install
        then restart MagicMirror
        from the module readme
        In your terminal, go to your MagicMirror's Module folder:
        Clone this repository:
        git clone https://github.com/MichMich/mmm-systemtemperature.git
        Install dependencies:
        this leaves out the important step
        cd mmm-systemtemperature
        then
        npm install
        • T Offline
          thartley @sdetweil
          @sdetweil - Thank you for the assistance. There are no longer any errors for that module. The system did need to update npm install to a newer version on my system first. After that it the remaining steps went just fine.
            sdetweil @thartley
            @thartley you did NOT need to update npm
            T 2 Replies Last reply Reply Quote 0
            • T Offline
              thartley @sdetweil
              @sdetweil - Maybe I misspoke when I used the word “update”. When I keyed in npm install per your instructions, it came back with several lines, each starting with “npm WARN old lockfile…”.
              It took care of something, so maybe it was just doing some sort of cleanup?
              • T Offline
                thartley @sdetweil
                @sdetweil - Hi. Please mark this as resolved since I don’t think I have rights to do that yet.
                  sdetweil @thartley
                  @thartley you do,
                  Find the post which best resolves the issue
                  Hit the 3 dots in the lower right corner
                  Select
                  Mark this post as the best answer
                    sdetweil @thartley
                    @thartley ok, understood. It upgraded the lock file format,
                    Useless user message in my opinion, as there is no way to fall back to an older npm which can’t use the new format
                    • T thartley has marked this topic as solved on
                    • KristjanESPERANTOK Offline
                      FYI: I’ve created a fork, refactored it and optimized the README. It should be easier to install :-)
