    Request: Flight tracker using PiAware
    14 Posts 4 Posters 305 Views 4 Watching
    • E Offline
      Exndfan
      I have missed having a module that lists the flights overhead since it went dark some time ago. I may have a solution but have no idea how to code it since JavaScript is pretty much like hieroglyphics to me.
      I am running PiAware on separate pi and the listing of overhead aircraft can be read as a json file but not all of the information that I would like displayed is in the json file. Would someone be willing to work on this with me?
      S J E 3 Replies Last reply Reply Quote 0
        sdetweil @Exndfan
        @Exndfan sure. What do you mean can be read. Is it a file or output of a command or?
        We could create a repo and discuss thru issues
          Open an issue w the json file attached and describe how you got it
          Open another and describe how you want to results to look
          And what additional info you want and where you might get it
          Open another with your ideas
            JohnGalt @Exndfan
            @Exndfan
            Maybe the best way to move this forward is to tell us what module you are referring to when you say something used to work but went dark some time ago.
            If we can see or reference what you are talking about, you have a better chance of getting help.
              sdetweil @JohnGalt
              @JohnGalt I think he was talking about
              https://github.com/E3V3A/MMM-FlightsAbove
                JohnGalt @sdetweil
                AHA - I see. It looks like that module is/was quite involved! I’m not sure I can add much to answer the original question, but i did note that the OP described the data as being/like JSON, but the module difers:
                Bugs and Warnings
                ℹ️ The data provided by the flightradar24-client, is not JSON, even if it resembles it.
                It is actually an Array of JavaScript objects.
                For an example of the raw data, look at the demo.json file.
                • E Offline
                  Exndfan @Exndfan
                  Well…I managed to come up with a viable alternative for what I was wanting to display. I will continue to clean it up and let everyone know
                    Richard238
                    +1 for this, please. I have a Pi Aware in the loft and would be interested in adding its data to MM.
                    • E Offline
                      Exndfan @Richard238
                      @Richard238 Let me know if you need help.
                        sdetweil @Exndfan
                        @Exndfan you didn’t post the new module link here
