    Request: Flight tracker using PiAware
    14 Posts 4 Posters 4.0k Views 4 Watching
      sdetweil @Exndfan
      @Exndfan sure. What do you mean can be read. Is it a file or output of a command or?
      We could create a repo and discuss thru issues
        Open an issue w the json file attached and describe how you got it
        Open another and describe how you want to results to look
        And what additional info you want and where you might get it
        Open another with your ideas
          JohnGalt @Exndfan
          @Exndfan
          Maybe the best way to move this forward is to tell us what module you are referring to when you say something used to work but went dark some time ago.
          If we can see or reference what you are talking about, you have a better chance of getting help.
            sdetweil @JohnGalt
            @JohnGalt I think he was talking about
            https://github.com/E3V3A/MMM-FlightsAbove
            J 1 Reply Last reply
              JohnGalt @sdetweil
              AHA - I see. It looks like that module is/was quite involved! I’m not sure I can add much to answer the original question, but i did note that the OP described the data as being/like JSON, but the module difers:
              Bugs and Warnings
              ℹ️ The data provided by the flightradar24-client, is not JSON, even if it resembles it.
              It is actually an Array of JavaScript objects.
              For an example of the raw data, look at the demo.json file.
              • E
                Exndfan @Exndfan
                Well…I managed to come up with a viable alternative for what I was wanting to display. I will continue to clean it up and let everyone know
                  Richard238
                  +1 for this, please. I have a Pi Aware in the loft and would be interested in adding its data to MM.
                  E 1 Reply Last reply
                  • E
                    Exndfan @Richard238
                    @Richard238 Let me know if you need help.
                      sdetweil @Exndfan
                      @Exndfan you didn’t post the new module link here
                      • E
                        Exndfan @sdetweil
                        @sdetweil Oops…The. repo is at http://github.com/kds54/MMM-Planefinder
                        I also put it in the listing. of 3rd party modules
                          JohnGalt @Exndfan
                          @Exndfan – Interesting!
                          Query: The original question was in regards to seeing data collected by a PiAware receiver. It looks like Plane Finder and PiAware both run dump1090, but beyond that I don’t know how they work, or how the data gets passed.
                          Will this module also display data received by a PiAware?
                          • E
                            Exndfan @JohnGalt
                            @JohnGalt No, this won’t display the 1090 dump from PiAware. It. uses the software from planefinder.net. The planefinder software is an addon to the Raspberry Pi OS and runs in the background. I use it on a Pi 4 Bookworm
                              JohnGalt @Exndfan
                              @Exndfan – ok, thanks.
