    update package list
    45 Posts 2 Posters 17.4k Views 2 Watching
      pat59
      pi@raspberrypi:~/MagicMirror $ pm2 status
      │ id │ name               │ mode     │ ↺    │ status    │ cpu      │ memory   │
      │ 1  │ MagicMirror        │ fork     │ 0    │ online    │ 0%       │ 2.5mb    │
      │ 0  │ mm                 │ fork     │ 0    │ online    │ 0%       │ 2.3mb    │
      so you have two instances
      pi@raspberrypi:~/MagicMirror $ ps -ef|grep MagicMirror
      pi        1037   818  0 14:29 ?        00:00:00 bash /home/pi/MagicMirror/installers/mm.sh
      pi        1096  1075 26 14:29 ?        00:00:56 /home/pi/MagicMirror/node_modules/electron/dist/electron js/electron.js
      pi        1097  1077 24 14:29 ?        00:00:52 /home/pi/MagicMirror/node_modules/electron/dist/electron js/electron.js
      pi        1102  1097  0 14:29 ?        00:00:00 /home/pi/MagicMirror/node_modules/electron/dist/electron --type=zygote --no-zygote-sandbox
      pi        1103  1096  0 14:29 ?        00:00:00 /home/pi/MagicMirror/node_modules/electron/dist/electron --type=zygote --no-zygote-sandbox
      pi        1104  1096  0 14:29 ?        00:00:00 /home/pi/MagicMirror/node_modules/electron/dist/electron --type=zygote
      pi        1106  1097  0 14:29 ?        00:00:00 /home/pi/MagicMirror/node_modules/electron/dist/electron --type=zygote
      pi        1109  1104  0 14:29 ?        00:00:00 /home/pi/MagicMirror/node_modules/electron/dist/electron --type=zygote
      pi        1110  1106  0 14:29 ?        00:00:00 /home/pi/MagicMirror/node_modules/electron/dist/electron --type=zygote
      pi        1407  1103  1 14:31 ?        00:00:01 /home/pi/MagicMirror/node_modules/electron/dist/electron --type=gpu-process --enable-crash-reporter=d92a2a3b-ea77-4f26-9bb3-aaab877f322e,no_channel --user-data-dir=/home/pi/.config/Electron --gpu-preferences=WAAAAAAAAAAgAAAEAAAAAAAAAAAAAAAAAABgAAAAAAA4AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABAAAAGAAAAAAAAAAYAAAAAAAAAAgAAAAAAAAACAAAAAAAAAAIAAAAAAAAAA== --use-gl=angle --use-angle=swiftshader-webgl --shared-files --field-trial-handle=0,i,17126282988831355409,13634691343321116781,262144 --enable-features=kWebSQLAccess --disable-features=SpareRendererForSitePerProcess --variations-seed-version
      pi        1408  1102  0 14:31 ?        00:00:00 /home/pi/MagicMirror/node_modules/electron/dist/electron --type=gpu-process --enable-crash-reporter=d92a2a3b-ea77-4f26-9bb3-aaab877f322e,no_channel --user-data-dir=/home/pi/.config/Electron --gpu-preferences=WAAAAAAAAAAgAAAEAAAAAAAAAAAAAAAAAABgAAAAAAA4AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABAAAAGAAAAAAAAAAYAAAAAAAAAAgAAAAAAAAACAAAAAAAAAAIAAAAAAAAAA== --use-gl=angle --use-angle=swiftshader-webgl --shared-files --field-trial-handle=0,i,4975378740503322807,8852675362163135929,262144 --enable-features=kWebSQLAccess --disable-features=SpareRendererForSitePerProcess --variations-seed-version
      pi        1478  1097  0 14:31 ?        00:00:00 /home/pi/MagicMirror/node_modules/electron/dist/electron --type=utility --utility-sub-type=network.mojom.NetworkService --lang=fr --service-sandbox-type=none --enable-crash-reporter=d92a2a3b-ea77-4f26-9bb3-aaab877f322e,no_channel --user-data-dir=/home/pi/.config/Electron --shared-files=v8_context_snapshot_data:100 --field-trial-handle=0,i,4975378740503322807,8852675362163135929,262144 --enable-features=kWebSQLAccess --disable-features=SpareRendererForSitePerProcess --variations-seed-version
      pi        1498  1096  1 14:31 ?        00:00:01 /home/pi/MagicMirror/node_modules/electron/dist/electron --type=utility --utility-sub-type=network.mojom.NetworkService --lang=fr --service-sandbox-type=none --enable-crash-reporter=d92a2a3b-ea77-4f26-9bb3-aaab877f322e,no_channel --user-data-dir=/home/pi/.config/Electron --shared-files=v8_context_snapshot_data:100 --field-trial-handle=0,i,17126282988831355409,13634691343321116781,262144 --enable-features=kWebSQLAccess --disable-features=SpareRendererForSitePerProcess --variations-seed-version
      pi        1517  1109  4 14:31 ?        00:00:04 /home/pi/MagicMirror/node_modules/electron/dist/electron --type=renderer --enable-crash-reporter=d92a2a3b-ea77-4f26-9bb3-aaab877f322e,no_channel --user-data-dir=/home/pi/.config/Electron --app-path=/home/pi/MagicMirror/js --enable-sandbox --autoplay-policy=no-user-gesture-required --disable-gpu-compositing --lang=fr --num-raster-threads=2 --enable-main-frame-before-activation --renderer-client-id=4 --time-ticks-at-unix-epoch=-1757680110193681 --launch-time-ticks=192347868 --shared-files=v8_context_snapshot_data:100 --field-trial-handle=0,i,17126282988831355409,13634691343321116781,262144 --enable-features=kWebSQLAccess --disable-features=SpareRendererForSitePerProcess --variations-seed-version
      pi        1662  1367  0 14:33 pts/1    00:00:00 grep --color=auto MagicMirror
        pat59
        Hello, I stopped it with smartphone remote control.
          sdetweil @pat59
          @pat59 you have two instances… pick one… delete the other
          pm2 --help
          will give you the command options
          what is the remote control function to stop it?
            pat59
            I used restart RPII used restart RPI
              pat59
              pi@raspberrypi:~/MagicMirror $ pm2 --help
              Usage: pm2 [cmd] app
              Options:
              -V, --version                                                output the version number
              -v --version                                                 print pm2 version
              -s --silent                                                  hide all messages
              --ext <extensions>                                           watch only this file extensions
              -n --name <name>                                             set a name for the process in the process list
              -m --mini-list                                               display a compacted list without formatting
              --interpreter <interpreter>                                  set a specific interpreter to use for executing app, default: node
              --interpreter-args <arguments>                               set arguments to pass to the interpreter (alias of --node-args)
              --node-args <node_args>                                      space delimited arguments to pass to node
              -o --output <path>                                           specify log file for stdout
              -e --error <path>                                            specify log file for stderr
              -l --log [path]                                              specify log file which gathers both stdout and stderr
              --filter-env [envs]                                          filter out outgoing global values that contain provided strings (default: )
              --log-type <type>                                            specify log output style (raw by default, json optional)
              --log-date-format <date format>                              add custom prefix timestamp to logs
              --time                                                       enable time logging
              --disable-logs                                               disable all logs storage
              --env <environment_name>                                     specify which set of environment variables from ecosystem file must be injected
              -a --update-env                                              force an update of the environment with restart/reload (-a <=> apply)
              -f --force                                                   force actions
              -i --instances <number>                                      launch [number] instances (for networked app)(load balanced)
              --parallel <number>                                          number of parallel actions (for restart/reload)
              --shutdown-with-message                                      shutdown an application with process.send('shutdown') instead of process.kill(pid, SIGINT)
              -p --pid <pid>                                               specify pid file
              -k --kill-timeout <delay>                                    delay before sending final SIGKILL signal to process
              --listen-timeout <delay>                                     listen timeout on application reload
              --max-memory-restart <memory>                                Restart the app if an amount of memory is exceeded (in bytes)
              --restart-delay <delay>                                      specify a delay between restarts (in milliseconds)
              --exp-backoff-restart-delay <delay>                          specify a delay between restarts (in milliseconds)
              -x --execute-command                                         execute a program using fork system
              --max-restarts [count]                                       only restart the script COUNT times
              -u --user <username>                                         define user when generating startup script
              --uid <uid>                                                  run target script with <uid> rights
              --gid <gid>                                                  run target script with <gid> rights
              --namespace <ns>                                             start application within specified namespace
              --cwd <path>                                                 run target script from path <cwd>
              --hp <home path>                                             define home path when generating startup script
              --wait-ip                                                    override systemd script to wait for full internet connectivity to launch pm2
              --service-name <name>                                        define service name when generating startup script
              -c --cron <cron_pattern>                                     restart a running process based on a cron pattern
              -c --cron-restart <cron_pattern>                             (alias) restart a running process based on a cron pattern
              -w --write                                                   write configuration in local folder
              --no-daemon                                                  run pm2 daemon in the foreground if it doesn't exist already
              --source-map-support                                         force source map support
              --only <application-name>                                    with json declaration, allow to only act on one application
              --disable-source-map-support                                 force source map support
              --wait-ready                                                 ask pm2 to wait for ready event from your app
              --merge-logs                                                 merge logs from different instances but keep error and out separated
              --watch [paths]                                              watch application folder for changes (default: )
              --ignore-watch <folders|files>                               List of paths to ignore (name or regex)
              --watch-delay <delay>                                        specify a restart delay after changing files (--watch-delay 4 (in sec) or 4000ms)
              --no-color                                                   skip colors
              --no-vizion                                                  start an app without vizion feature (versioning control)
              --no-autostart                                               add an app without automatic start
              --no-autorestart                                             start an app without automatic restart
              --stop-exit-codes <exit_codes...>                            specify a list of exit codes that should skip automatic restart
              --no-treekill                                                Only kill the main process, not detached children
              --no-pmx                                                     start an app without pmx
              --no-automation                                              start an app without pmx
              --trace                                                      enable transaction tracing with km
              --disable-trace                                              disable transaction tracing with km
              --sort <field_name:sort>                                     sort process according to field's name
              --attach                                                     attach logging after your start/restart/stop/reload
              --v8                                                         enable v8 data collecting
              --event-loop-inspector                                       enable event-loop-inspector dump in pmx
              --deep-monitoring                                            enable all monitoring tools (equivalent to --v8 --event-loop-inspector --trace)
              -h, --help                                                   output usage information
              Commands:
              start [options] [name|namespace|file|ecosystem|id...]        start and daemonize an app
              trigger <id|proc_name|namespace|all> <action_name> [params]  trigger process action
              deploy <file|environment>                                    deploy your json
              startOrRestart <json>                                        start or restart JSON file
              startOrReload <json>                                         start or gracefully reload JSON file
              pid [app_name]                                               return pid of [app_name] or all
              create                                                       return pid of [app_name] or all
              startOrGracefulReload <json>                                 start or gracefully reload JSON file
              stop [options] <id|name|namespace|all|json|stdin...>         stop a process
              restart [options] <id|name|namespace|all|json|stdin...>      restart a process
              scale <app_name> <number>                                    scale up/down a process in cluster mode depending on total_number param
              profile:mem [time]                                           Sample PM2 heap memory
              profile:cpu [time]                                           Profile PM2 cpu
              reload <id|name|namespace|all>                               reload processes (note that its for app using HTTP/HTTPS)
              id <name>                                                    get process id by name
              inspect <name>                                               inspect a process
              delete|del <name|id|namespace|script|all|json|stdin...>      stop and delete a process from pm2 process list
              sendSignal <signal> <pm2_id|name>                            send a system signal to the target process
              ping                                                         ping pm2 daemon - if not up it will launch it
              updatePM2                                                    update in-memory PM2 with local PM2
              update                                                       (alias) update in-memory PM2 with local PM2
              install|module:install [options] <module|git:/>              install or update a module and run it forever
              module:update <module|git:/>                                 update a module and run it forever
              module:generate [app_name]                                   Generate a sample module in current folder
              uninstall|module:uninstall <module>                          stop and uninstall a module
              package [target]                                             Check & Package TAR type module
              publish|module:publish [options] [folder]                    Publish the module you are currently on
              set [key] [value]                                            sets the specified config <key> <value>
              multiset <value>                                             multiset eg "key1 val1 key2 val2
              get [key]                                                    get value for <key>
              conf [key] [value]                                           get / set module config values
              config <key> [value]                                         get / set module config values
              unset <key>                                                  clears the specified config <key>
              report                                                       give a full pm2 report for https://github.com/Unitech/pm2/issues
              link [options] [secret] [public] [name]                      link with the pm2 monitoring dashboard
              unlink                                                       unlink with the pm2 monitoring dashboard
              monitor [name]                                               monitor target process
              unmonitor [name]                                             unmonitor target process
              open                                                         open the pm2 monitoring dashboard
              plus|register [options] [command] [option]                   enable pm2 plus
              login                                                        Login to pm2 plus
              logout                                                       Logout from pm2 plus
              dump|save [options]                                          dump all processes for resurrecting them later
              cleardump                                                    Create empty dump file
              send <pm_id> <line>                                          send stdin to <pm_id>
              attach <pm_id> [comman]                                      attach stdin/stdout to application identified by <pm_id>
              resurrect                                                    resurrect previously dumped processes
              unstartup [platform]                                         disable the pm2 startup hook
              startup [platform]                                           enable the pm2 startup hook
              logrotate                                                    copy default logrotate configuration
              ecosystem|init [mode]                                        generate a process conf file. (mode = null or simple)
              reset <name|id|all>                                          reset counters for process
              describe <name|id>                                           describe all parameters of a process
              desc <name|id>                                               (alias) describe all parameters of a process
              info <name|id>                                               (alias) describe all parameters of a process
              show <name|id>                                               (alias) describe all parameters of a process
              env <id>                                                     list all environment variables of a process id
              list|ls                                                      list all processes
              l                                                            (alias) list all processes
              ps                                                           (alias) list all processes
              status                                                       (alias) list all processes
              jlist                                                        list all processes in JSON format
              sysmonit                                                     start system monitoring daemon
              slist|sysinfos [options]                                     list system infos in JSON
              prettylist                                                   print json in a prettified JSON
              monit                                                        launch termcaps monitoring
              imonit                                                       launch legacy termcaps monitoring
              dashboard|dash                                               launch dashboard with monitoring and logs
              flush [api]                                                  flush logs
              reloadLogs                                                   reload all logs
              logs [options] [id|name|namespace]                           stream logs file. Default stream all logs
              kill                                                         kill daemon
              pull <name> [commit_id]                                      updates repository for a given app
              forward <name>                                               updates repository to the next commit for a given app
              backward <name>                                              downgrades repository to the previous commit for a given app
              deepUpdate                                                   performs a deep update of PM2
              serve|expose [options] [path] [port]                         serve a directory over http via port
              autoinstall
              examples                                                     display pm2 usage examples
                sdetweil @pat59
                @pat59 said in update package list:
                I don’t know what that means in reality under the covers
                so, you need to delete one of the apps… unless you intentionally have two instances.
                they show online, and no restarts, which is weird
                  pat59
                  Well, thank you, I’m going to stop now. I’m 65 years old and I don’t always understand what to do. I’m a novice. I don’t know which application to delete. Thanks again for your help.
                    sdetweil @pat59
                    @pat59 im 74… so its never too late
                    try this
                    pm2 stop mm
                    pm2 restart MagicMirror
                      pat59
                      pi@raspberrypi:~/MagicMirror $ pm2 stop mm
                      [PM2] Applying action stopProcessId on app [mm](ids: [ 0 ])
                      [PM2] mm ✓
                      │ 1  │ MagicMirror        │ fork     │ 0    │ online    │ 0%       │ 2.4mb    │
                      │ 0  │ mm                 │ fork     │ 0    │ stopped   │ 0%       │ 0b       │
                      pi@raspberrypi:~/MagicMirror $ pm2 restart MagicMirror
                      [PM2] Applying action restartProcessId on app [MagicMirror](ids: [ 1 ])
                      [PM2] MagicMirror ✓
                      │ 1  │ MagicMirror        │ fork     │ 1    │ online    │ 0%       │ 2.4mb    │
                        pat59
                        Congratulations on your courage
                        Do I have to restart after that?
                          sdetweil @pat59
                          @pat59 is it working? after the pm2 restart?
                            pat59
                            Hello
                            No, I have the other apps working fine except for Calendar, which is still loading, and Newsfeed, which is also loading.
                              sdetweil @pat59
                              @pat59
                              Ok,
                              Because you are using pm2 makes getting log a little more interesting
                              Do
                              pm2 stop all
                              pm2 flush
                              pm2 start MagicMirror
                              Wait til MagicMirror comes up and modules show loading
                              Then do
                              pm2 logs —lines=100.
                              The n look thru the listing and see if there are any errors reported
                              Also can you post the configuration from config.js for those two modules
                              Note the calendar module url needs to be mangled, xxx part so it doesn’t expose the full url
                                pat59
                                Hello, here is the error it gives me.
                                pi@raspberrypi:~/MagicMirror $ pm2 stop all
                                [PM2] Applying action stopProcessId on app [all](ids: [ 0, 1 ])
                                [PM2] mm ✓
                                [PM2] MagicMirror ✓
                                │ 1 │ MagicMirror │ fork │ 0 │ stopped │ 0% │ 0b │
                                pi@raspberrypi:~/MagicMirror $ pm2 flush
                                [PM2] Flushing /home/pi/.pm2/pm2.log
                                [PM2] Flushing:
                                [PM2] /home/pi/.pm2/logs/mm-out.log
                                [PM2] /home/pi/.pm2/logs/mm-error.log
                                [PM2] Flushing:
                                [PM2] /home/pi/.pm2/logs/MagicMirror-out.log
                                [PM2] /home/pi/.pm2/logs/MagicMirror-error.log
                                [PM2] Logs flushed
                                pi@raspberrypi:~/MagicMirror $ pm2 start MagicMirror
                                [PM2] MagicMirror ✓
                                [PM2] Process successfully started
                                pi@raspberrypi:~/MagicMirror $ pm2 logs -lines=100.
                                error: unknown option `-=’
                                  sdetweil @pat59
                                  @pat59 it’s 2 dashes
                                  —lines
                                  You could have seen this in the help from pm2
                                    pat59
                                    yes indeed not seen
                                    pi@raspberrypi:~/MagicMirror $ pm2 logs --lines=100.
                                    PM2 | 2025-09-13T13:56:57: PM2 log: App [MagicMirror:1] starting in -fork mode-
                                    PM2 | 2025-09-13T13:56:57: PM2 log: App [MagicMirror:1] online
                                    /home/pi/.pm2/logs/MagicMirror-error.log last 100 lines:
                                    1|MagicMir | [2025-09-13 13:57:11.358] [WARN] You’re using a full whitelist configuration to allow for all IPs
                                    1|MagicMir | [2025-09-13 13:57:24.583] [ERROR] ERROR! Could not find main module js file for MMM-Linky
                                    1|MagicMir | [2025-09-13 13:57:24.875] [ERROR] ERROR! Could not find main module js file for MMM-PrixCarburants
                                    1|MagicMir | [2025-09-13 13:57:26.522] [ERROR] ERROR! Could not find main module js file for save-remote
                                    1|MagicMir | [2025-09-13 13:57:40.888] [ERROR] We expected a redirect to guce.yahoo.com, but got https://finance.yahoo.com/quote/AAPL/
                                    1|MagicMir | [2025-09-13 13:57:40.889] [ERROR] We’ll try to continue anyway - you can safely ignore this if the request succeeds
                                    1|MagicMir | [2025-09-13 13:57:41.531] [ERROR] Trace: [GPHOTOS:CORE] request fail with URL albums
                                    1|MagicMir | at GPhotos.logTrace (/home/pi/MagicMirror/modules/MMM-GooglePhotos/GPhotos.js:127:13)
                                    1|MagicMir | at GPhotos.request (/home/pi/MagicMirror/modules/MMM-GooglePhotos/GPhotos.js:168:12)
                                    1|MagicMir | at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
                                    1|MagicMir | at async getAlbum (/home/pi/MagicMirror/modules/MMM-GooglePhotos/GPhotos.js:208:24)
                                    1|MagicMir | at async GPhotos.getAlbums (/home/pi/MagicMirror/modules/MMM-GooglePhotos/GPhotos.js:180:18)
                                    1|MagicMir | at async Class.getAlbums (/home/pi/MagicMirror/modules/MMM-GooglePhotos/node_helper.js:263:15)
                                    1|MagicMir | at async Class.getAlbumList (/home/pi/MagicMirror/modules/MMM-GooglePhotos/node_helper.js:313:18)
                                    1|MagicMir | at async Class.scanJob (/home/pi/MagicMirror/modules/MMM-GooglePhotos/node_helper.js:294:5)
                                    1|MagicMir | [2025-09-13 13:57:41.537] [ERROR] Trace: [GPHOTOS:CORE] params {“pageSize”:50,“pageToken”:“”}
                                    1|MagicMir | at GPhotos.request (/home/pi/MagicMirror/modules/MMM-GooglePhotos/GPhotos.js:169:12)
                                    1|MagicMir | [2025-09-13 13:57:41.542] [ERROR] Trace: [GPHOTOS:CORE] data null
                                    1|MagicMir | at GPhotos.request (/home/pi/MagicMirror/modules/MMM-GooglePhotos/GPhotos.js:170:12)
                                    1|MagicMir | [2025-09-13 13:57:41.572] [ERROR] [GPHOTOS:CORE] response.data:
                                    1|MagicMir | {“error”:{“code”:403,“message”:“Request had insufficient authentication scopes.”,“status”:“PERMISSION_DENIED”}}
                                    1|MagicMir | response.status:
                                    1|MagicMir | 403
                                    1|MagicMir | headers:
                                    1|MagicMir | {“vary”:“Origin, X-Origin, Referer”,“content-type”:“application/json; charset=UTF-8”,“date”:“Sat, 13 Sep 2025 11:57:40 GMT”,“server”:“ESF”,“x-xss-protection”:“0”,“x-frame-options”:“SAMEORIGIN”,“x-content-type-options”:“nosniff”,“alt-svc”:“h3=":443"; ma=2592000,h3-29=":443"; ma=2592000”,“transfer-encoding”:“chunked”}
                                    1|MagicMir | config:
                                    1|MagicMir | {“transitional”:{“silentJSONParsing”:true,“forcedJSONParsing”:true,“clarifyTimeoutError”:false},“adapter”:[“xhr”,“http”,“fetch”],“transformRequest”:[null],“transformResponse”:[null],“timeout”:0,“xsrfCookieName”:“XSRF-TOKEN”,“xsrfHeaderName”:“X-XSRF-TOKEN”,“maxContentLength”:-1,“maxBodyLength”:-1,“env”:{},“headers”:{“Accept”:“application/json, text/plain, /”,“Authorization”:“Bearer ya29.a0AS3H6NyA7ONxL8SRsM2CzAn9MUyYAqUCVW3B66xtCW2iYEouumznAvH6Cve50JLI09-Vv3BbpaygzUvAeRREgNp9Uq66mrEzgbyFNulxBYw4zTUYwlMyZCftrKFC5yyKbV24vNXGXG9j2Dw7ddPJ7106HcXXNgrZ6BMLZlLTj9c9hWRGWkQU-IoT9_6PoQKDeeyTUtIYdgaCgYKAcUSARISFQHGX2MiruMSTrfXs6E2e2yPY2ullg0209”,“User-Agent”:“axios/1.8.2”,“Accept-Encoding”:“gzip, compress, deflate, br”},“method”:“get”,“url”:“albums”,“baseURL”:“https://photoslibrary.googleapis.com/v1/“,“params”:{“pageSize”:50,“pageToken”:”"},"allowAbsoluteUrls”:true}
                                    1|MagicMir | [2025-09-13 13:57:41.578] [ERROR] [GPHOTOS:CORE] AxiosError: Request failed with status code 403
                                    1|MagicMir | [2025-09-13 13:57:41.593] [ERROR] [GPHOTOS] [node_helper] response.data:
                                    1|MagicMir | 403
                                    1|MagicMir | [2025-09-13 13:57:41.637] [ERROR] (node:1783) UnhandledPromiseRejectionWarning: AxiosError: Request failed with status code 403
                                    1|MagicMir | at settle (/home/pi/MagicMirror/modules/MMM-GooglePhotos/node_modules/axios/dist/node/axios.cjs:2031:12)
                                    1|MagicMir | at Unzip.handleStreamEnd (/home/pi/MagicMirror/modules/MMM-GooglePhotos/node_modules/axios/dist/node/axios.cjs:3148:11)
                                    1|MagicMir | at Unzip.emit (node:events:526:35)
                                    1|MagicMir | at endReadableNT (node:internal/streams/readable:1408:12)
                                    1|MagicMir | at process.processTicksAndRejections (node:internal/process/task_queues:82:21)
                                    1|MagicMir | at Axios.request (/home/pi/MagicMirror/modules/MMM-GooglePhotos/node_modules/axios/dist/node/axios.cjs:4258:41)
                                    1|MagicMir | at async GPhotos.request (/home/pi/MagicMirror/modules/MMM-GooglePhotos/GPhotos.js:165:19)
                                    1|MagicMir | (Use electron --trace-warnings ... to show where the warning was created)
                                    1|MagicMir | [2025-09-13 13:57:41.646] [ERROR] (node:1783) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag --unhandled-rejections=strict (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 13)
                                    1|MagicMir | [1783:0913/135904.363177:ERROR:atom_cache.cc(229)] Add WM_CHANGE_STATE to kAtomsToCache
                                    /home/pi/.pm2/logs/MagicMirror-out.log last 100 lines:
                                    1|MagicMir |
                                    1|MagicMir | > magicmirror@2.27.0 start
                                    1|MagicMir | > DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js
                                    1|MagicMir |
                                    1|MagicMir | [2025-09-13 13:57:07.053] [LOG] Starting MagicMirror: v2.27.0
                                    1|MagicMir | [2025-09-13 13:57:07.131] [LOG] Loading config …
                                    1|MagicMir | [2025-09-13 13:57:07.145] [LOG] config template file not exists, no envsubst
                                    1|MagicMir | [2025-09-13 13:57:07.167] [LOG] Loading module helpers …
                                    1|MagicMir | [2025-09-13 13:57:07.488] [LOG] Initializing new module helper …
                                    1|MagicMir | [2025-09-13 13:57:07.490] [LOG] Module helper loaded: MMM-Remote-Control
                                    1|MagicMir | [2025-09-13 13:57:07.495] [LOG] No helper found for module: alert.
                                    1|MagicMir | [2025-09-13 13:57:07.510] [LOG] Initializing new module helper …
                                    1|MagicMir | [2025-09-13 13:57:07.513] [LOG] Module helper loaded: MMM-Saint
                                    1|MagicMir | [2025-09-13 13:57:07.521] [LOG] Initializing new module helper …
                                    1|MagicMir | [2025-09-13 13:57:07.523] [LOG] Module helper loaded: MMM-BME280
                                    1|MagicMir | [2025-09-13 13:57:07.527] [LOG] No helper found for module: MMM-FlipClock.
                                    1|MagicMir | [2025-09-13 13:57:07.656] [LOG] Initializing new module helper …
                                    1|MagicMir | [2025-09-13 13:57:07.658] [LOG] Module helper loaded: MMM-network-signal
                                    1|MagicMir | [2025-09-13 13:57:08.139] [LOG] Initializing new module helper …
                                    1|MagicMir | [2025-09-13 13:57:08.141] [LOG] Module helper loaded: calendar
                                    1|MagicMir | [2025-09-13 13:57:09.550] [LOG] Initializing new module helper …
                                    1|MagicMir | [2025-09-13 13:57:09.551] [LOG] Module helper loaded: MMM-Jast
                                    1|MagicMir | [2025-09-13 13:57:10.936] [LOG] Initializing new module helper …
                                    1|MagicMir | [2025-09-13 13:57:10.938] [LOG] Module helper loaded: MMM-GooglePhotos
                                    1|MagicMir | [2025-09-13 13:57:10.946] [LOG] No helper found for module: MMM-WiFiPassword.
                                    1|MagicMir | [2025-09-13 13:57:10.949] [LOG] No helper found for module: MMM-OpenmapWeather.
                                    1|MagicMir | [2025-09-13 13:57:10.950] [LOG] No helper found for module: MMM-WeatherOrNot.
                                    1|MagicMir | [2025-09-13 13:57:11.319] [LOG] Initializing new module helper …
                                    1|MagicMir | [2025-09-13 13:57:11.320] [LOG] Module helper loaded: newsfeed
                                    1|MagicMir | [2025-09-13 13:57:11.321] [LOG] All module helpers loaded.
                                    1|MagicMir | [2025-09-13 13:57:11.345] [LOG] Starting server on port 8080 …
                                    1|MagicMir | [2025-09-13 13:57:13.570] [LOG] Server started …
                                    1|MagicMir | [2025-09-13 13:57:13.583] [LOG] Connecting socket for: MMM-Remote-Control
                                    1|MagicMir | [2025-09-13 13:57:13.586] [LOG] Starting node helper for: MMM-Remote-Control
                                    1|MagicMir | [2025-09-13 13:57:13.718] [LOG] Connecting socket for: MMM-Saint
                                    1|MagicMir | [2025-09-13 13:57:13.749] [LOG] [SAINT] MMM-Saint Version: 1.0.1
                                    1|MagicMir | [2025-09-13 13:57:13.751] [LOG] Connecting socket for: MMM-BME280
                                    1|MagicMir | [2025-09-13 13:57:13.774] [LOG] BME280 helper started …
                                    1|MagicMir | [2025-09-13 13:57:13.778] [LOG] Connecting socket for: MMM-network-signal
                                    1|MagicMir | [2025-09-13 13:57:13.781] [LOG] MMM-network-signal helper started …
                                    1|MagicMir | [2025-09-13 13:57:13.805] [LOG] Connecting socket for: calendar
                                    1|MagicMir | [2025-09-13 13:57:13.827] [LOG] Starting node helper for: calendar
                                    1|MagicMir | [2025-09-13 13:57:13.843] [LOG] Connecting socket for: MMM-Jast
                                    1|MagicMir | [2025-09-13 13:57:13.848] [LOG] MMM-Jast helper method started…
                                    1|MagicMir | [2025-09-13 13:57:13.849] [LOG] Connecting socket for: MMM-GooglePhotos
                                    1|MagicMir | [2025-09-13 13:57:13.851] [LOG] Connecting socket for: newsfeed
                                    1|MagicMir | [2025-09-13 13:57:13.871] [LOG] Starting node helper for: newsfeed
                                    1|MagicMir | [2025-09-13 13:57:13.896] [LOG] Sockets connected & modules started …
                                    1|MagicMir | [2025-09-13 13:57:17.746] [LOG] Launching application.
                                    1|MagicMir | [2025-09-13 13:57:34.314] [INFO] System information:
                                    1|MagicMir | ### SYSTEM: manufacturer: Raspberry Pi Foundation; model: Raspberry Pi 3 Model B Plus Rev 1.3; raspberry: [object Object]; virtual: false
                                    1|MagicMir | ### OS: platform: linux; distro: Raspbian GNU/Linux; release: 10; arch: arm; kernel: 6.12.45-v7+
                                    1|MagicMir | ### VERSIONS: electron: 29.1.6; used node: 20.9.0; installed node: 18.18.0; npm: 9.8.1; pm2: 5.3.1
                                    1|MagicMir | ### OTHER: timeZone: Europe/Paris; ELECTRON_ENABLE_GPU: undefined
                                    1|MagicMir | [2025-09-13 13:57:34.482] [LOG] Create new calendarfetcher for url: https://calendar.google.com/xxx - Interval: 3600000
                                    1|MagicMir | [2025-09-13 13:57:34.715] [LOG] Please consider completing the survey at https://bit.ly/yahoo-finance-api-feedback if you haven’t already; for more info see https://github.com/gadicc/node-yahoo-finance2/issues/764#issuecomment-2056623851.
                                    1|MagicMir | [2025-09-13 13:57:35.087] [INFO] [GPHOTOS] [node_helper] Starting Initialization
                                    1|MagicMir | [2025-09-13 13:57:35.109] [LOG] Create new newsfetcher for url: https://www.lemonde.fr/europe/rss_full.xml - Interval: 300000
                                    1|MagicMir | [2025-09-13 13:57:35.129] [LOG] Fetching crumb and cookies from https://finance.yahoo.com/quote/AAPL…
                                    1|MagicMir | [2025-09-13 13:57:36.151] [LOG] fetch https://guce.yahoo.com/consent?brandType=nonEu&gcrumb=Sgaifog&done=https%3A%2F%2Ffinance.yahoo.com%2Fquote%2FAAPL
                                    1|MagicMir | [2025-09-13 13:57:36.878] [INFO] [GPHOTOS] [node_helper] Config or token has changed. Ignore cache
                                    1|MagicMir | [2025-09-13 13:57:36.897] [INFO] [GPHOTOS] [node_helper] Initialization complete!
                                    1|MagicMir | [2025-09-13 13:57:36.900] [INFO] [GPHOTOS] [node_helper] Start first scanning.
                                    1|MagicMir | [2025-09-13 13:57:36.909] [INFO] [GPHOTOS] [node_helper] Start Album scanning
                                    1|MagicMir | [2025-09-13 13:57:36.915] [INFO] [GPHOTOS] [node_helper] Getting album list
                                    1|MagicMir | [2025-09-13 13:57:37.785] [LOG] fetch https://consent.yahoo.com/v2/collectConsent?sessionId=3_cc-session_3a9e4e96-b9eb-4aab-84b3-6fbfbbe4e547
                                    1|MagicMir | [2025-09-13 13:57:38.158] [INFO] Newsfeed-Fetcher: Broadcasting 20 items.
                                    1|MagicMir | [2025-09-13 13:57:39.230] [INFO] Calendar-Fetcher: Broadcasting 30 events from https://calendar.google.com/calendarxxx
                                    1|MagicMir | [2025-09-13 13:57:39.482] [INFO] [GPHOTOS:CORE] Getting Album info chunks.
                                    1|MagicMir | [2025-09-13 13:57:40.285] [LOG] fetch https://consent.yahoo.com/v2/collectConsent?sessionId=3_cc-session_3a9e4e96-b9eb-4aab-84b3-6fbfbbe4e547
                                    1|MagicMir | [2025-09-13 13:57:40.481] [LOG] fetch https://guce.yahoo.com/copyConsent?sessionId=3_cc-session_3a9e4e96-b9eb-4aab-84b3-6fbfbbe4e547&lang=fr-FR
                                    1|MagicMir | [2025-09-13 13:57:40.721] [LOG] Fetching crumb and cookies from https://finance.yahoo.com/quote/AAPL?guccounter=1…
                                    1|MagicMir | [2025-09-13 13:57:40.918] [LOG] Success. Cookie expires on Infinity
                                    1|MagicMir | [2025-09-13 13:57:40.941] [LOG] fetch https://query1.finance.yahoo.com/v1/test/getcrumb
                                    1|MagicMir | [2025-09-13 13:57:41.310] [LOG] New crumb: XcgD8zd85Vp
                                    1|MagicMir | [2025-09-13 13:57:47.900] [LOG] [SAINT] Config: { debug: true, update: 60000 }
                                    1|MagicMir | [2025-09-13 13:57:47.910] [LOG] [SAINT] MMM-Saint is now initialized!
                                    1|MagicMir | [2025-09-13 13:57:47.918] [LOG] [SAINT] Actual Day: 13 In memory: 13
                                    1|MagicMir | [2025-09-13 13:57:47.920] [LOG] [SAINT] Today 13/9: St Aimé
                                    1|MagicMir | [2025-09-13 13:57:47.921] [LOG] [SAINT] Send Data to module: St Aimé
                                    1|MagicMir | [2025-09-13 14:02:39.198] [INFO] Newsfeed-Fetcher: Broadcasting 20 items.
                                    1|MagicMir | [2025-09-13 14:07:39.774] [INFO] Newsfeed-Fetcher: Broadcasting 20 items.
                                    1|MagicMir | [2025-09-13 14:12:40.245] [INFO] Newsfeed-Fetcher: Broadcasting 20 items.
                                    1|MagicMir | [2025-09-13 14:17:40.655] [INFO] Newsfeed-Fetcher: Broadcasting 20 items.
                                    1|MagicMir | [2025-09-13 14:22:41.110] [INFO] Newsfeed-Fetcher: Broadcasting 20 items.
                                      sdetweil @pat59
                                      @pat59
                                      I edited out your calendar URL from the log above.
                                      seems other modules are failing for no/old credentials…
                                      google photos is broken as Google changed the way it works.
                                      calendar and newsfeed modules say they are doing their thing…
                                      there IS an old system runtime bug in here ‘possibly’ , you are 5 releases behind, 6 come Oct 1. fix is in the October release…
                                      1|MagicMir | [2025-09-13 13:57:39.230] [INFO] Calendar-Fetcher: Broadcasting 30 events from https://calendar.google.com/calendar/xxx
                                        pat59
                                        Hello, what I don’t understand is that it works sometimes and other times it doesn’t.
                                        Will the correction be done automatically in October? Thank you.
                                          sdetweil @pat59
                                          @pat59 I’d like to see the log when it doesn’t work
                                          pm2 logs --lines=100 >somefile.txt
                                          ctrl-c
                                          then send me somefile.txt
                                          my same userid at gmail
                                            pat59
                                            nothing happens when I try
                                            pi@raspberrypi:~/MagicMirror $ pm2 logs --lines=100 >somefile.txt
                                            • 2 / 3
