    update package list
    45 Posts 2 Posters 17.4k Views 2 Watching
      sdetweil @pat59
      @pat59 im 74… so its never too late
      try this
      pm2 stop mm
      pm2 restart MagicMirror
        pat59
        pi@raspberrypi:~/MagicMirror $ pm2 stop mm
        [PM2] Applying action stopProcessId on app [mm](ids: [ 0 ])
        [PM2] mm ✓
        │ id │ name               │ mode     │ ↺    │ status    │ cpu      │ memory   │
        │ 1  │ MagicMirror        │ fork     │ 0    │ online    │ 0%       │ 2.4mb    │
        │ 0  │ mm                 │ fork     │ 0    │ stopped   │ 0%       │ 0b       │
        pi@raspberrypi:~/MagicMirror $ pm2 restart MagicMirror
        [PM2] Applying action restartProcessId on app [MagicMirror](ids: [ 1 ])
        [PM2] MagicMirror ✓
        │ 1  │ MagicMirror        │ fork     │ 1    │ online    │ 0%       │ 2.4mb    │
          pat59
          Congratulations on your courage
          Do I have to restart after that?
            sdetweil @pat59
            @pat59 is it working? after the pm2 restart?
              pat59
              Hello
              No, I have the other apps working fine except for Calendar, which is still loading, and Newsfeed, which is also loading.
                sdetweil @pat59
                @pat59
                Ok,
                Because you are using pm2 makes getting log a little more interesting
                Do
                pm2 stop all
                pm2 flush
                pm2 start MagicMirror
                Wait til MagicMirror comes up and modules show loading
                Then do
                pm2 logs —lines=100.
                The n look thru the listing and see if there are any errors reported
                Also can you post the configuration from config.js for those two modules
                Note the calendar module url needs to be mangled, xxx part so it doesn’t expose the full url
                  pat59
                  Hello, here is the error it gives me.
                  pi@raspberrypi:~/MagicMirror $ pm2 stop all
                  [PM2] Applying action stopProcessId on app [all](ids: [ 0, 1 ])
                  [PM2] mm ✓
                  [PM2] MagicMirror ✓
                  │ 1 │ MagicMirror │ fork │ 0 │ stopped │ 0% │ 0b │
                  pi@raspberrypi:~/MagicMirror $ pm2 flush
                  [PM2] Flushing /home/pi/.pm2/pm2.log
                  [PM2] Flushing:
                  [PM2] /home/pi/.pm2/logs/mm-out.log
                  [PM2] /home/pi/.pm2/logs/mm-error.log
                  [PM2] Flushing:
                  [PM2] /home/pi/.pm2/logs/MagicMirror-out.log
                  [PM2] /home/pi/.pm2/logs/MagicMirror-error.log
                  [PM2] Logs flushed
                  pi@raspberrypi:~/MagicMirror $ pm2 start MagicMirror
                  [PM2] MagicMirror ✓
                  [PM2] Process successfully started
                  pi@raspberrypi:~/MagicMirror $ pm2 logs -lines=100.
                  error: unknown option `-=’
                    sdetweil @pat59
                    @pat59 it’s 2 dashes
                    —lines
                    You could have seen this in the help from pm2
                      pat59
                      yes indeed not seen
                      pi@raspberrypi:~/MagicMirror $ pm2 logs --lines=100.
                      PM2 | 2025-09-13T13:56:57: PM2 log: App [MagicMirror:1] starting in -fork mode-
                      PM2 | 2025-09-13T13:56:57: PM2 log: App [MagicMirror:1] online
                      /home/pi/.pm2/logs/MagicMirror-error.log last 100 lines:
                      1|MagicMir | [2025-09-13 13:57:11.358] [WARN] You’re using a full whitelist configuration to allow for all IPs
                      1|MagicMir | [2025-09-13 13:57:24.583] [ERROR] ERROR! Could not find main module js file for MMM-Linky
                      1|MagicMir | [2025-09-13 13:57:24.875] [ERROR] ERROR! Could not find main module js file for MMM-PrixCarburants
                      1|MagicMir | [2025-09-13 13:57:26.522] [ERROR] ERROR! Could not find main module js file for save-remote
                      1|MagicMir | [2025-09-13 13:57:40.888] [ERROR] We expected a redirect to guce.yahoo.com, but got https://finance.yahoo.com/quote/AAPL/
                      1|MagicMir | [2025-09-13 13:57:40.889] [ERROR] We’ll try to continue anyway - you can safely ignore this if the request succeeds
                      1|MagicMir | [2025-09-13 13:57:41.531] [ERROR] Trace: [GPHOTOS:CORE] request fail with URL albums
                      1|MagicMir | at GPhotos.logTrace (/home/pi/MagicMirror/modules/MMM-GooglePhotos/GPhotos.js:127:13)
                      1|MagicMir | at GPhotos.request (/home/pi/MagicMirror/modules/MMM-GooglePhotos/GPhotos.js:168:12)
                      1|MagicMir | at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
                      1|MagicMir | at async getAlbum (/home/pi/MagicMirror/modules/MMM-GooglePhotos/GPhotos.js:208:24)
                      1|MagicMir | at async GPhotos.getAlbums (/home/pi/MagicMirror/modules/MMM-GooglePhotos/GPhotos.js:180:18)
                      1|MagicMir | at async Class.getAlbums (/home/pi/MagicMirror/modules/MMM-GooglePhotos/node_helper.js:263:15)
                      1|MagicMir | at async Class.getAlbumList (/home/pi/MagicMirror/modules/MMM-GooglePhotos/node_helper.js:313:18)
                      1|MagicMir | at async Class.scanJob (/home/pi/MagicMirror/modules/MMM-GooglePhotos/node_helper.js:294:5)
                      1|MagicMir | [2025-09-13 13:57:41.537] [ERROR] Trace: [GPHOTOS:CORE] params {“pageSize”:50,“pageToken”:“”}
                      1|MagicMir | at GPhotos.request (/home/pi/MagicMirror/modules/MMM-GooglePhotos/GPhotos.js:169:12)
                      1|MagicMir | [2025-09-13 13:57:41.542] [ERROR] Trace: [GPHOTOS:CORE] data null
                      1|MagicMir | at GPhotos.request (/home/pi/MagicMirror/modules/MMM-GooglePhotos/GPhotos.js:170:12)
                      1|MagicMir | [2025-09-13 13:57:41.572] [ERROR] [GPHOTOS:CORE] response.data:
                      1|MagicMir | {“error”:{“code”:403,“message”:“Request had insufficient authentication scopes.”,“status”:“PERMISSION_DENIED”}}
                      1|MagicMir | response.status:
                      1|MagicMir | 403
                      1|MagicMir | headers:
                      1|MagicMir | {“vary”:“Origin, X-Origin, Referer”,“content-type”:“application/json; charset=UTF-8”,“date”:“Sat, 13 Sep 2025 11:57:40 GMT”,“server”:“ESF”,“x-xss-protection”:“0”,“x-frame-options”:“SAMEORIGIN”,“x-content-type-options”:“nosniff”,“alt-svc”:“h3=":443"; ma=2592000,h3-29=":443"; ma=2592000”,“transfer-encoding”:“chunked”}
                      1|MagicMir | config:
                      1|MagicMir | {“transitional”:{“silentJSONParsing”:true,“forcedJSONParsing”:true,“clarifyTimeoutError”:false},“adapter”:[“xhr”,“http”,“fetch”],“transformRequest”:[null],“transformResponse”:[null],“timeout”:0,“xsrfCookieName”:“XSRF-TOKEN”,“xsrfHeaderName”:“X-XSRF-TOKEN”,“maxContentLength”:-1,“maxBodyLength”:-1,“env”:{},“headers”:{“Accept”:“application/json, text/plain, /”,“Authorization”:“Bearer ya29.a0AS3H6NyA7ONxL8SRsM2CzAn9MUyYAqUCVW3B66xtCW2iYEouumznAvH6Cve50JLI09-Vv3BbpaygzUvAeRREgNp9Uq66mrEzgbyFNulxBYw4zTUYwlMyZCftrKFC5yyKbV24vNXGXG9j2Dw7ddPJ7106HcXXNgrZ6BMLZlLTj9c9hWRGWkQU-IoT9_6PoQKDeeyTUtIYdgaCgYKAcUSARISFQHGX2MiruMSTrfXs6E2e2yPY2ullg0209”,“User-Agent”:“axios/1.8.2”,“Accept-Encoding”:“gzip, compress, deflate, br”},“method”:“get”,“url”:“albums”,“baseURL”:“https://photoslibrary.googleapis.com/v1/“,“params”:{“pageSize”:50,“pageToken”:”"},"allowAbsoluteUrls”:true}
                      1|MagicMir | [2025-09-13 13:57:41.578] [ERROR] [GPHOTOS:CORE] AxiosError: Request failed with status code 403
                      1|MagicMir | [2025-09-13 13:57:41.593] [ERROR] [GPHOTOS] [node_helper] response.data:
                      1|MagicMir | 403
                      1|MagicMir | [2025-09-13 13:57:41.637] [ERROR] (node:1783) UnhandledPromiseRejectionWarning: AxiosError: Request failed with status code 403
                      1|MagicMir | at settle (/home/pi/MagicMirror/modules/MMM-GooglePhotos/node_modules/axios/dist/node/axios.cjs:2031:12)
                      1|MagicMir | at Unzip.handleStreamEnd (/home/pi/MagicMirror/modules/MMM-GooglePhotos/node_modules/axios/dist/node/axios.cjs:3148:11)
                      1|MagicMir | at Unzip.emit (node:events:526:35)
                      1|MagicMir | at endReadableNT (node:internal/streams/readable:1408:12)
                      1|MagicMir | at process.processTicksAndRejections (node:internal/process/task_queues:82:21)
                      1|MagicMir | at Axios.request (/home/pi/MagicMirror/modules/MMM-GooglePhotos/node_modules/axios/dist/node/axios.cjs:4258:41)
                      1|MagicMir | at async GPhotos.request (/home/pi/MagicMirror/modules/MMM-GooglePhotos/GPhotos.js:165:19)
                      1|MagicMir | (Use electron --trace-warnings ... to show where the warning was created)
                      1|MagicMir | [2025-09-13 13:57:41.646] [ERROR] (node:1783) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag --unhandled-rejections=strict (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 13)
                      1|MagicMir | [1783:0913/135904.363177:ERROR:atom_cache.cc(229)] Add WM_CHANGE_STATE to kAtomsToCache
                      /home/pi/.pm2/logs/MagicMirror-out.log last 100 lines:
                      1|MagicMir |
                      1|MagicMir | > magicmirror@2.27.0 start
                      1|MagicMir | > DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js
                      1|MagicMir |
                      1|MagicMir | [2025-09-13 13:57:07.053] [LOG] Starting MagicMirror: v2.27.0
                      1|MagicMir | [2025-09-13 13:57:07.131] [LOG] Loading config …
                      1|MagicMir | [2025-09-13 13:57:07.145] [LOG] config template file not exists, no envsubst
                      1|MagicMir | [2025-09-13 13:57:07.167] [LOG] Loading module helpers …
                      1|MagicMir | [2025-09-13 13:57:07.488] [LOG] Initializing new module helper …
                      1|MagicMir | [2025-09-13 13:57:07.490] [LOG] Module helper loaded: MMM-Remote-Control
                      1|MagicMir | [2025-09-13 13:57:07.495] [LOG] No helper found for module: alert.
                      1|MagicMir | [2025-09-13 13:57:07.510] [LOG] Initializing new module helper …
                      1|MagicMir | [2025-09-13 13:57:07.513] [LOG] Module helper loaded: MMM-Saint
                      1|MagicMir | [2025-09-13 13:57:07.521] [LOG] Initializing new module helper …
                      1|MagicMir | [2025-09-13 13:57:07.523] [LOG] Module helper loaded: MMM-BME280
                      1|MagicMir | [2025-09-13 13:57:07.527] [LOG] No helper found for module: MMM-FlipClock.
                      1|MagicMir | [2025-09-13 13:57:07.656] [LOG] Initializing new module helper …
                      1|MagicMir | [2025-09-13 13:57:07.658] [LOG] Module helper loaded: MMM-network-signal
                      1|MagicMir | [2025-09-13 13:57:08.139] [LOG] Initializing new module helper …
                      1|MagicMir | [2025-09-13 13:57:08.141] [LOG] Module helper loaded: calendar
                      1|MagicMir | [2025-09-13 13:57:09.550] [LOG] Initializing new module helper …
                      1|MagicMir | [2025-09-13 13:57:09.551] [LOG] Module helper loaded: MMM-Jast
                      1|MagicMir | [2025-09-13 13:57:10.936] [LOG] Initializing new module helper …
                      1|MagicMir | [2025-09-13 13:57:10.938] [LOG] Module helper loaded: MMM-GooglePhotos
                      1|MagicMir | [2025-09-13 13:57:10.946] [LOG] No helper found for module: MMM-WiFiPassword.
                      1|MagicMir | [2025-09-13 13:57:10.949] [LOG] No helper found for module: MMM-OpenmapWeather.
                      1|MagicMir | [2025-09-13 13:57:10.950] [LOG] No helper found for module: MMM-WeatherOrNot.
                      1|MagicMir | [2025-09-13 13:57:11.319] [LOG] Initializing new module helper …
                      1|MagicMir | [2025-09-13 13:57:11.320] [LOG] Module helper loaded: newsfeed
                      1|MagicMir | [2025-09-13 13:57:11.321] [LOG] All module helpers loaded.
                      1|MagicMir | [2025-09-13 13:57:11.345] [LOG] Starting server on port 8080 …
                      1|MagicMir | [2025-09-13 13:57:13.570] [LOG] Server started …
                      1|MagicMir | [2025-09-13 13:57:13.583] [LOG] Connecting socket for: MMM-Remote-Control
                      1|MagicMir | [2025-09-13 13:57:13.586] [LOG] Starting node helper for: MMM-Remote-Control
                      1|MagicMir | [2025-09-13 13:57:13.718] [LOG] Connecting socket for: MMM-Saint
                      1|MagicMir | [2025-09-13 13:57:13.749] [LOG] [SAINT] MMM-Saint Version: 1.0.1
                      1|MagicMir | [2025-09-13 13:57:13.751] [LOG] Connecting socket for: MMM-BME280
                      1|MagicMir | [2025-09-13 13:57:13.774] [LOG] BME280 helper started …
                      1|MagicMir | [2025-09-13 13:57:13.778] [LOG] Connecting socket for: MMM-network-signal
                      1|MagicMir | [2025-09-13 13:57:13.781] [LOG] MMM-network-signal helper started …
                      1|MagicMir | [2025-09-13 13:57:13.805] [LOG] Connecting socket for: calendar
                      1|MagicMir | [2025-09-13 13:57:13.827] [LOG] Starting node helper for: calendar
                      1|MagicMir | [2025-09-13 13:57:13.843] [LOG] Connecting socket for: MMM-Jast
                      1|MagicMir | [2025-09-13 13:57:13.848] [LOG] MMM-Jast helper method started…
                      1|MagicMir | [2025-09-13 13:57:13.849] [LOG] Connecting socket for: MMM-GooglePhotos
                      1|MagicMir | [2025-09-13 13:57:13.851] [LOG] Connecting socket for: newsfeed
                      1|MagicMir | [2025-09-13 13:57:13.871] [LOG] Starting node helper for: newsfeed
                      1|MagicMir | [2025-09-13 13:57:13.896] [LOG] Sockets connected & modules started …
                      1|MagicMir | [2025-09-13 13:57:17.746] [LOG] Launching application.
                      1|MagicMir | [2025-09-13 13:57:34.314] [INFO] System information:
                      1|MagicMir | ### SYSTEM: manufacturer: Raspberry Pi Foundation; model: Raspberry Pi 3 Model B Plus Rev 1.3; raspberry: [object Object]; virtual: false
                      1|MagicMir | ### OS: platform: linux; distro: Raspbian GNU/Linux; release: 10; arch: arm; kernel: 6.12.45-v7+
                      1|MagicMir | ### VERSIONS: electron: 29.1.6; used node: 20.9.0; installed node: 18.18.0; npm: 9.8.1; pm2: 5.3.1
                      1|MagicMir | ### OTHER: timeZone: Europe/Paris; ELECTRON_ENABLE_GPU: undefined
                      1|MagicMir | [2025-09-13 13:57:34.482] [LOG] Create new calendarfetcher for url: https://calendar.google.com/xxx - Interval: 3600000
                      1|MagicMir | [2025-09-13 13:57:34.715] [LOG] Please consider completing the survey at https://bit.ly/yahoo-finance-api-feedback if you haven’t already; for more info see https://github.com/gadicc/node-yahoo-finance2/issues/764#issuecomment-2056623851.
                      1|MagicMir | [2025-09-13 13:57:35.087] [INFO] [GPHOTOS] [node_helper] Starting Initialization
                      1|MagicMir | [2025-09-13 13:57:35.109] [LOG] Create new newsfetcher for url: https://www.lemonde.fr/europe/rss_full.xml - Interval: 300000
                      1|MagicMir | [2025-09-13 13:57:35.129] [LOG] Fetching crumb and cookies from https://finance.yahoo.com/quote/AAPL…
                      1|MagicMir | [2025-09-13 13:57:36.151] [LOG] fetch https://guce.yahoo.com/consent?brandType=nonEu&gcrumb=Sgaifog&done=https%3A%2F%2Ffinance.yahoo.com%2Fquote%2FAAPL
                      1|MagicMir | [2025-09-13 13:57:36.878] [INFO] [GPHOTOS] [node_helper] Config or token has changed. Ignore cache
                      1|MagicMir | [2025-09-13 13:57:36.897] [INFO] [GPHOTOS] [node_helper] Initialization complete!
                      1|MagicMir | [2025-09-13 13:57:36.900] [INFO] [GPHOTOS] [node_helper] Start first scanning.
                      1|MagicMir | [2025-09-13 13:57:36.909] [INFO] [GPHOTOS] [node_helper] Start Album scanning
                      1|MagicMir | [2025-09-13 13:57:36.915] [INFO] [GPHOTOS] [node_helper] Getting album list
                      1|MagicMir | [2025-09-13 13:57:37.785] [LOG] fetch https://consent.yahoo.com/v2/collectConsent?sessionId=3_cc-session_3a9e4e96-b9eb-4aab-84b3-6fbfbbe4e547
                      1|MagicMir | [2025-09-13 13:57:38.158] [INFO] Newsfeed-Fetcher: Broadcasting 20 items.
                      1|MagicMir | [2025-09-13 13:57:39.230] [INFO] Calendar-Fetcher: Broadcasting 30 events from https://calendar.google.com/calendarxxx
                      1|MagicMir | [2025-09-13 13:57:39.482] [INFO] [GPHOTOS:CORE] Getting Album info chunks.
                      1|MagicMir | [2025-09-13 13:57:40.285] [LOG] fetch https://consent.yahoo.com/v2/collectConsent?sessionId=3_cc-session_3a9e4e96-b9eb-4aab-84b3-6fbfbbe4e547
                      1|MagicMir | [2025-09-13 13:57:40.481] [LOG] fetch https://guce.yahoo.com/copyConsent?sessionId=3_cc-session_3a9e4e96-b9eb-4aab-84b3-6fbfbbe4e547&lang=fr-FR
                      1|MagicMir | [2025-09-13 13:57:40.721] [LOG] Fetching crumb and cookies from https://finance.yahoo.com/quote/AAPL?guccounter=1…
                      1|MagicMir | [2025-09-13 13:57:40.918] [LOG] Success. Cookie expires on Infinity
                      1|MagicMir | [2025-09-13 13:57:40.941] [LOG] fetch https://query1.finance.yahoo.com/v1/test/getcrumb
                      1|MagicMir | [2025-09-13 13:57:41.310] [LOG] New crumb: XcgD8zd85Vp
                      1|MagicMir | [2025-09-13 13:57:47.900] [LOG] [SAINT] Config: { debug: true, update: 60000 }
                      1|MagicMir | [2025-09-13 13:57:47.910] [LOG] [SAINT] MMM-Saint is now initialized!
                      1|MagicMir | [2025-09-13 13:57:47.918] [LOG] [SAINT] Actual Day: 13 In memory: 13
                      1|MagicMir | [2025-09-13 13:57:47.920] [LOG] [SAINT] Today 13/9: St Aimé
                      1|MagicMir | [2025-09-13 13:57:47.921] [LOG] [SAINT] Send Data to module: St Aimé
                      1|MagicMir | [2025-09-13 14:02:39.198] [INFO] Newsfeed-Fetcher: Broadcasting 20 items.
                      1|MagicMir | [2025-09-13 14:07:39.774] [INFO] Newsfeed-Fetcher: Broadcasting 20 items.
                      1|MagicMir | [2025-09-13 14:12:40.245] [INFO] Newsfeed-Fetcher: Broadcasting 20 items.
                      1|MagicMir | [2025-09-13 14:17:40.655] [INFO] Newsfeed-Fetcher: Broadcasting 20 items.
                      1|MagicMir | [2025-09-13 14:22:41.110] [INFO] Newsfeed-Fetcher: Broadcasting 20 items.
                        sdetweil @pat59
                        @pat59
                        I edited out your calendar URL from the log above.
                        seems other modules are failing for no/old credentials…
                        google photos is broken as Google changed the way it works.
                        calendar and newsfeed modules say they are doing their thing…
                        there IS an old system runtime bug in here ‘possibly’ , you are 5 releases behind, 6 come Oct 1. fix is in the October release…
                        1|MagicMir | [2025-09-13 13:57:39.230] [INFO] Calendar-Fetcher: Broadcasting 30 events from https://calendar.google.com/calendar/xxx
                          pat59
                          Hello, what I don’t understand is that it works sometimes and other times it doesn’t.
                          Will the correction be done automatically in October? Thank you.
                            sdetweil @pat59
                            @pat59 I’d like to see the log when it doesn’t work
                            pm2 logs --lines=100 >somefile.txt
                            ctrl-c
                            then send me somefile.txt
                            my same userid at gmail
                              pat59
                              nothing happens when I try
                              pi@raspberrypi:~/MagicMirror $ pm2 logs --lines=100 >somefile.txt
                                sdetweil @pat59
                                @pat59 it does. The command runs and all the output is sent to the file
                                Nothing to see
                                  pat59
                                  @sdetweil said in update package list:
                                  alors envoie-moi somefile.txt
                                  mon même identifiant sur Gmail
                                    pat59
                                    Hello
                                    Thank you. You’re asking me a question; I don’t understand your previous answers.
                                      pat59
                                      When I do
                                      open “somefile.txt”
                                      nothing happens
                                        sdetweil @pat59
                                        @pat59 open doesn’t work
                                        You need to use some text editor like nano
                                        nano somefile.txt
                                          sdetweil @pat59
                                          @pat59
                                          My user id here is sdetweil
                                          My email is that user id at gmail
                                            pat59
                                            TAILING] Tailing last 100 lines for [all] processes (change the value with --l$
                                            PM2 | 2025-09-14T16:28:36: PM2 log: pid=1022 msg=failed to kill - retryi$
                                            PM2 | 2025-09-14T16:28:37: PM2 log: pid=1022 msg=failed to kill - retryi$
                                            PM2 | 2025-09-14T16:28:37: PM2 log: Process with pid 1022 still alive af$
                                            PM2 | 2025-09-14T16:28:37: PM2 log: App [MagicMirror:1] exited with code$
                                            PM2 | 2025-09-14T16:28:37: PM2 log: pid=1022 msg=process killed
                                            PM2 | 2025-09-14T16:28:46: PM2 log: [Watch] Start watching MagicMirror
                                            PM2 | 2025-09-14T16:28:46: PM2 log: App [MagicMirror:2] starting in -for$
                                            PM2 | 2025-09-14T16:28:46: PM2 log: App [MagicMirror:2] online
                                            [ Lecture de 931 lignes ]
                                            ^G Aide ^O Écrire ^W Chercher ^K Couper ^J Justifier ^C Pos. cur.
                                            ^X Quitter ^R Lire fich.^\ Remplacer ^U Coller ^T Orthograp.^_ Aller lig.
                                            • 2 / 3
