    update package list
    45 Posts 2 Posters 16.9k Views 2 Watching
      sdetweil @pat59
      @pat59
      Ok,
      Because you are using pm2 makes getting log a little more interesting
      Do
      pm2 stop all
      pm2 flush
      pm2 start MagicMirror
      Wait til MagicMirror comes up and modules show loading
      Then do
      pm2 logs —lines=100.
      The n look thru the listing and see if there are any errors reported
      Also can you post the configuration from config.js for those two modules
      Note the calendar module url needs to be mangled, xxx part so it doesn’t expose the full url
        pat59
        Hello, here is the error it gives me.
        pi@raspberrypi:~/MagicMirror $ pm2 stop all
        [PM2] Applying action stopProcessId on app [all](ids: [ 0, 1 ])
        [PM2] mm ✓
        [PM2] MagicMirror ✓
        │ id │ name │ mode │ ↺ │ status │ cpu │ memory │
        │ 1 │ MagicMirror │ fork │ 0 │ stopped │ 0% │ 0b │
        │ 0 │ mm │ fork │ 0 │ stopped │ 0% │ 0b │
        pi@raspberrypi:~/MagicMirror $ pm2 flush
        [PM2] Flushing /home/pi/.pm2/pm2.log
        [PM2] Flushing:
        [PM2] /home/pi/.pm2/logs/mm-out.log
        [PM2] /home/pi/.pm2/logs/mm-error.log
        [PM2] Flushing:
        [PM2] /home/pi/.pm2/logs/MagicMirror-out.log
        [PM2] /home/pi/.pm2/logs/MagicMirror-error.log
        [PM2] Logs flushed
        pi@raspberrypi:~/MagicMirror $ pm2 start MagicMirror
        [PM2] Applying action restartProcessId on app [MagicMirror](ids: [ 1 ])
        [PM2] MagicMirror ✓
        [PM2] Process successfully started
        │ 1 │ MagicMirror │ fork │ 0 │ online │ 0% │ 2.4mb │
        pi@raspberrypi:~/MagicMirror $ pm2 logs -lines=100.
        error: unknown option `-=’
          sdetweil @pat59
          @pat59 it’s 2 dashes
          —lines
          You could have seen this in the help from pm2
            pat59
            yes indeed not seen
            pi@raspberrypi:~/MagicMirror $ pm2 logs --lines=100.
            PM2 | 2025-09-13T13:56:57: PM2 log: App [MagicMirror:1] starting in -fork mode-
            PM2 | 2025-09-13T13:56:57: PM2 log: App [MagicMirror:1] online
            /home/pi/.pm2/logs/MagicMirror-error.log last 100 lines:
            1|MagicMir | [2025-09-13 13:57:11.358] [WARN] You’re using a full whitelist configuration to allow for all IPs
            1|MagicMir | [2025-09-13 13:57:24.583] [ERROR] ERROR! Could not find main module js file for MMM-Linky
            1|MagicMir | [2025-09-13 13:57:24.875] [ERROR] ERROR! Could not find main module js file for MMM-PrixCarburants
            1|MagicMir | [2025-09-13 13:57:26.522] [ERROR] ERROR! Could not find main module js file for save-remote
            1|MagicMir | [2025-09-13 13:57:40.888] [ERROR] We expected a redirect to guce.yahoo.com, but got https://finance.yahoo.com/quote/AAPL/
            1|MagicMir | [2025-09-13 13:57:40.889] [ERROR] We’ll try to continue anyway - you can safely ignore this if the request succeeds
            1|MagicMir | [2025-09-13 13:57:41.531] [ERROR] Trace: [GPHOTOS:CORE] request fail with URL albums
            1|MagicMir | at GPhotos.logTrace (/home/pi/MagicMirror/modules/MMM-GooglePhotos/GPhotos.js:127:13)
            1|MagicMir | at GPhotos.request (/home/pi/MagicMirror/modules/MMM-GooglePhotos/GPhotos.js:168:12)
            1|MagicMir | at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
            1|MagicMir | at async getAlbum (/home/pi/MagicMirror/modules/MMM-GooglePhotos/GPhotos.js:208:24)
            1|MagicMir | at async GPhotos.getAlbums (/home/pi/MagicMirror/modules/MMM-GooglePhotos/GPhotos.js:180:18)
            1|MagicMir | at async Class.getAlbums (/home/pi/MagicMirror/modules/MMM-GooglePhotos/node_helper.js:263:15)
            1|MagicMir | at async Class.getAlbumList (/home/pi/MagicMirror/modules/MMM-GooglePhotos/node_helper.js:313:18)
            1|MagicMir | at async Class.scanJob (/home/pi/MagicMirror/modules/MMM-GooglePhotos/node_helper.js:294:5)
            1|MagicMir | [2025-09-13 13:57:41.537] [ERROR] Trace: [GPHOTOS:CORE] params {“pageSize”:50,“pageToken”:“”}
            1|MagicMir | at GPhotos.request (/home/pi/MagicMirror/modules/MMM-GooglePhotos/GPhotos.js:169:12)
            1|MagicMir | [2025-09-13 13:57:41.542] [ERROR] Trace: [GPHOTOS:CORE] data null
            1|MagicMir | at GPhotos.request (/home/pi/MagicMirror/modules/MMM-GooglePhotos/GPhotos.js:170:12)
            1|MagicMir | [2025-09-13 13:57:41.572] [ERROR] [GPHOTOS:CORE] response.data:
            1|MagicMir | {“error”:{“code”:403,“message”:“Request had insufficient authentication scopes.”,“status”:“PERMISSION_DENIED”}}
            1|MagicMir | response.status:
            1|MagicMir | 403
            1|MagicMir | headers:
            1|MagicMir | {“vary”:“Origin, X-Origin, Referer”,“content-type”:“application/json; charset=UTF-8”,“date”:“Sat, 13 Sep 2025 11:57:40 GMT”,“server”:“ESF”,“x-xss-protection”:“0”,“x-frame-options”:“SAMEORIGIN”,“x-content-type-options”:“nosniff”,“alt-svc”:“h3=":443"; ma=2592000,h3-29=":443"; ma=2592000”,“transfer-encoding”:“chunked”}
            1|MagicMir | config:
            1|MagicMir | {“transitional”:{“silentJSONParsing”:true,“forcedJSONParsing”:true,“clarifyTimeoutError”:false},“adapter”:[“xhr”,“http”,“fetch”],“transformRequest”:[null],“transformResponse”:[null],“timeout”:0,“xsrfCookieName”:“XSRF-TOKEN”,“xsrfHeaderName”:“X-XSRF-TOKEN”,“maxContentLength”:-1,“maxBodyLength”:-1,“env”:{},“headers”:{“Accept”:“application/json, text/plain, /”,“Authorization”:“Bearer ya29.a0AS3H6NyA7ONxL8SRsM2CzAn9MUyYAqUCVW3B66xtCW2iYEouumznAvH6Cve50JLI09-Vv3BbpaygzUvAeRREgNp9Uq66mrEzgbyFNulxBYw4zTUYwlMyZCftrKFC5yyKbV24vNXGXG9j2Dw7ddPJ7106HcXXNgrZ6BMLZlLTj9c9hWRGWkQU-IoT9_6PoQKDeeyTUtIYdgaCgYKAcUSARISFQHGX2MiruMSTrfXs6E2e2yPY2ullg0209”,“User-Agent”:“axios/1.8.2”,“Accept-Encoding”:“gzip, compress, deflate, br”},“method”:“get”,“url”:“albums”,“baseURL”:“https://photoslibrary.googleapis.com/v1/“,“params”:{“pageSize”:50,“pageToken”:”"},"allowAbsoluteUrls”:true}
            1|MagicMir | [2025-09-13 13:57:41.578] [ERROR] [GPHOTOS:CORE] AxiosError: Request failed with status code 403
            1|MagicMir | [2025-09-13 13:57:41.593] [ERROR] [GPHOTOS] [node_helper] response.data:
            1|MagicMir | 403
            1|MagicMir | [2025-09-13 13:57:41.637] [ERROR] (node:1783) UnhandledPromiseRejectionWarning: AxiosError: Request failed with status code 403
            1|MagicMir | at settle (/home/pi/MagicMirror/modules/MMM-GooglePhotos/node_modules/axios/dist/node/axios.cjs:2031:12)
            1|MagicMir | at Unzip.handleStreamEnd (/home/pi/MagicMirror/modules/MMM-GooglePhotos/node_modules/axios/dist/node/axios.cjs:3148:11)
            1|MagicMir | at Unzip.emit (node:events:526:35)
            1|MagicMir | at endReadableNT (node:internal/streams/readable:1408:12)
            1|MagicMir | at process.processTicksAndRejections (node:internal/process/task_queues:82:21)
            1|MagicMir | at Axios.request (/home/pi/MagicMirror/modules/MMM-GooglePhotos/node_modules/axios/dist/node/axios.cjs:4258:41)
            1|MagicMir | at async GPhotos.request (/home/pi/MagicMirror/modules/MMM-GooglePhotos/GPhotos.js:165:19)
            1|MagicMir | (Use electron --trace-warnings ... to show where the warning was created)
            1|MagicMir | [2025-09-13 13:57:41.646] [ERROR] (node:1783) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag --unhandled-rejections=strict (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 13)
            1|MagicMir | [1783:0913/135904.363177:ERROR:atom_cache.cc(229)] Add WM_CHANGE_STATE to kAtomsToCache
            /home/pi/.pm2/logs/MagicMirror-out.log last 100 lines:
            1|MagicMir |
            1|MagicMir | > magicmirror@2.27.0 start
            1|MagicMir | > DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js
            1|MagicMir |
            1|MagicMir | [2025-09-13 13:57:07.053] [LOG] Starting MagicMirror: v2.27.0
            1|MagicMir | [2025-09-13 13:57:07.131] [LOG] Loading config …
            1|MagicMir | [2025-09-13 13:57:07.145] [LOG] config template file not exists, no envsubst
            1|MagicMir | [2025-09-13 13:57:07.167] [LOG] Loading module helpers …
            1|MagicMir | [2025-09-13 13:57:07.488] [LOG] Initializing new module helper …
            1|MagicMir | [2025-09-13 13:57:07.490] [LOG] Module helper loaded: MMM-Remote-Control
            1|MagicMir | [2025-09-13 13:57:07.495] [LOG] No helper found for module: alert.
            1|MagicMir | [2025-09-13 13:57:07.510] [LOG] Initializing new module helper …
            1|MagicMir | [2025-09-13 13:57:07.513] [LOG] Module helper loaded: MMM-Saint
            1|MagicMir | [2025-09-13 13:57:07.521] [LOG] Initializing new module helper …
            1|MagicMir | [2025-09-13 13:57:07.523] [LOG] Module helper loaded: MMM-BME280
            1|MagicMir | [2025-09-13 13:57:07.527] [LOG] No helper found for module: MMM-FlipClock.
            1|MagicMir | [2025-09-13 13:57:07.656] [LOG] Initializing new module helper …
            1|MagicMir | [2025-09-13 13:57:07.658] [LOG] Module helper loaded: MMM-network-signal
            1|MagicMir | [2025-09-13 13:57:08.139] [LOG] Initializing new module helper …
            1|MagicMir | [2025-09-13 13:57:08.141] [LOG] Module helper loaded: calendar
            1|MagicMir | [2025-09-13 13:57:09.550] [LOG] Initializing new module helper …
            1|MagicMir | [2025-09-13 13:57:09.551] [LOG] Module helper loaded: MMM-Jast
            1|MagicMir | [2025-09-13 13:57:10.936] [LOG] Initializing new module helper …
            1|MagicMir | [2025-09-13 13:57:10.938] [LOG] Module helper loaded: MMM-GooglePhotos
            1|MagicMir | [2025-09-13 13:57:10.946] [LOG] No helper found for module: MMM-WiFiPassword.
            1|MagicMir | [2025-09-13 13:57:10.949] [LOG] No helper found for module: MMM-OpenmapWeather.
            1|MagicMir | [2025-09-13 13:57:10.950] [LOG] No helper found for module: MMM-WeatherOrNot.
            1|MagicMir | [2025-09-13 13:57:11.319] [LOG] Initializing new module helper …
            1|MagicMir | [2025-09-13 13:57:11.320] [LOG] Module helper loaded: newsfeed
            1|MagicMir | [2025-09-13 13:57:11.321] [LOG] All module helpers loaded.
            1|MagicMir | [2025-09-13 13:57:11.345] [LOG] Starting server on port 8080 …
            1|MagicMir | [2025-09-13 13:57:13.570] [LOG] Server started …
            1|MagicMir | [2025-09-13 13:57:13.583] [LOG] Connecting socket for: MMM-Remote-Control
            1|MagicMir | [2025-09-13 13:57:13.586] [LOG] Starting node helper for: MMM-Remote-Control
            1|MagicMir | [2025-09-13 13:57:13.718] [LOG] Connecting socket for: MMM-Saint
            1|MagicMir | [2025-09-13 13:57:13.749] [LOG] [SAINT] MMM-Saint Version: 1.0.1
            1|MagicMir | [2025-09-13 13:57:13.751] [LOG] Connecting socket for: MMM-BME280
            1|MagicMir | [2025-09-13 13:57:13.774] [LOG] BME280 helper started …
            1|MagicMir | [2025-09-13 13:57:13.778] [LOG] Connecting socket for: MMM-network-signal
            1|MagicMir | [2025-09-13 13:57:13.781] [LOG] MMM-network-signal helper started …
            1|MagicMir | [2025-09-13 13:57:13.805] [LOG] Connecting socket for: calendar
            1|MagicMir | [2025-09-13 13:57:13.827] [LOG] Starting node helper for: calendar
            1|MagicMir | [2025-09-13 13:57:13.843] [LOG] Connecting socket for: MMM-Jast
            1|MagicMir | [2025-09-13 13:57:13.848] [LOG] MMM-Jast helper method started…
            1|MagicMir | [2025-09-13 13:57:13.849] [LOG] Connecting socket for: MMM-GooglePhotos
            1|MagicMir | [2025-09-13 13:57:13.851] [LOG] Connecting socket for: newsfeed
            1|MagicMir | [2025-09-13 13:57:13.871] [LOG] Starting node helper for: newsfeed
            1|MagicMir | [2025-09-13 13:57:13.896] [LOG] Sockets connected & modules started …
            1|MagicMir | [2025-09-13 13:57:17.746] [LOG] Launching application.
            1|MagicMir | [2025-09-13 13:57:34.314] [INFO] System information:
            1|MagicMir | ### SYSTEM: manufacturer: Raspberry Pi Foundation; model: Raspberry Pi 3 Model B Plus Rev 1.3; raspberry: [object Object]; virtual: false
            1|MagicMir | ### OS: platform: linux; distro: Raspbian GNU/Linux; release: 10; arch: arm; kernel: 6.12.45-v7+
            1|MagicMir | ### VERSIONS: electron: 29.1.6; used node: 20.9.0; installed node: 18.18.0; npm: 9.8.1; pm2: 5.3.1
            1|MagicMir | ### OTHER: timeZone: Europe/Paris; ELECTRON_ENABLE_GPU: undefined
            1|MagicMir | [2025-09-13 13:57:34.482] [LOG] Create new calendarfetcher for url: https://calendar.google.com/xxx - Interval: 3600000
            1|MagicMir | [2025-09-13 13:57:34.715] [LOG] Please consider completing the survey at https://bit.ly/yahoo-finance-api-feedback if you haven’t already; for more info see https://github.com/gadicc/node-yahoo-finance2/issues/764#issuecomment-2056623851.
            1|MagicMir | [2025-09-13 13:57:35.087] [INFO] [GPHOTOS] [node_helper] Starting Initialization
            1|MagicMir | [2025-09-13 13:57:35.109] [LOG] Create new newsfetcher for url: https://www.lemonde.fr/europe/rss_full.xml - Interval: 300000
            1|MagicMir | [2025-09-13 13:57:35.129] [LOG] Fetching crumb and cookies from https://finance.yahoo.com/quote/AAPL…
            1|MagicMir | [2025-09-13 13:57:36.151] [LOG] fetch https://guce.yahoo.com/consent?brandType=nonEu&gcrumb=Sgaifog&done=https%3A%2F%2Ffinance.yahoo.com%2Fquote%2FAAPL
            1|MagicMir | [2025-09-13 13:57:36.878] [INFO] [GPHOTOS] [node_helper] Config or token has changed. Ignore cache
            1|MagicMir | [2025-09-13 13:57:36.897] [INFO] [GPHOTOS] [node_helper] Initialization complete!
            1|MagicMir | [2025-09-13 13:57:36.900] [INFO] [GPHOTOS] [node_helper] Start first scanning.
            1|MagicMir | [2025-09-13 13:57:36.909] [INFO] [GPHOTOS] [node_helper] Start Album scanning
            1|MagicMir | [2025-09-13 13:57:36.915] [INFO] [GPHOTOS] [node_helper] Getting album list
            1|MagicMir | [2025-09-13 13:57:37.785] [LOG] fetch https://consent.yahoo.com/v2/collectConsent?sessionId=3_cc-session_3a9e4e96-b9eb-4aab-84b3-6fbfbbe4e547
            1|MagicMir | [2025-09-13 13:57:38.158] [INFO] Newsfeed-Fetcher: Broadcasting 20 items.
            1|MagicMir | [2025-09-13 13:57:39.230] [INFO] Calendar-Fetcher: Broadcasting 30 events from https://calendar.google.com/calendarxxx
            1|MagicMir | [2025-09-13 13:57:39.482] [INFO] [GPHOTOS:CORE] Getting Album info chunks.
            1|MagicMir | [2025-09-13 13:57:40.285] [LOG] fetch https://consent.yahoo.com/v2/collectConsent?sessionId=3_cc-session_3a9e4e96-b9eb-4aab-84b3-6fbfbbe4e547
            1|MagicMir | [2025-09-13 13:57:40.481] [LOG] fetch https://guce.yahoo.com/copyConsent?sessionId=3_cc-session_3a9e4e96-b9eb-4aab-84b3-6fbfbbe4e547&lang=fr-FR
            1|MagicMir | [2025-09-13 13:57:40.721] [LOG] Fetching crumb and cookies from https://finance.yahoo.com/quote/AAPL?guccounter=1…
            1|MagicMir | [2025-09-13 13:57:40.918] [LOG] Success. Cookie expires on Infinity
            1|MagicMir | [2025-09-13 13:57:40.941] [LOG] fetch https://query1.finance.yahoo.com/v1/test/getcrumb
            1|MagicMir | [2025-09-13 13:57:41.310] [LOG] New crumb: XcgD8zd85Vp
            1|MagicMir | [2025-09-13 13:57:47.900] [LOG] [SAINT] Config: { debug: true, update: 60000 }
            1|MagicMir | [2025-09-13 13:57:47.910] [LOG] [SAINT] MMM-Saint is now initialized!
            1|MagicMir | [2025-09-13 13:57:47.918] [LOG] [SAINT] Actual Day: 13 In memory: 13
            1|MagicMir | [2025-09-13 13:57:47.920] [LOG] [SAINT] Today 13/9: St Aimé
            1|MagicMir | [2025-09-13 13:57:47.921] [LOG] [SAINT] Send Data to module: St Aimé
            1|MagicMir | [2025-09-13 14:02:39.198] [INFO] Newsfeed-Fetcher: Broadcasting 20 items.
            1|MagicMir | [2025-09-13 14:07:39.774] [INFO] Newsfeed-Fetcher: Broadcasting 20 items.
            1|MagicMir | [2025-09-13 14:12:40.245] [INFO] Newsfeed-Fetcher: Broadcasting 20 items.
            1|MagicMir | [2025-09-13 14:17:40.655] [INFO] Newsfeed-Fetcher: Broadcasting 20 items.
            1|MagicMir | [2025-09-13 14:22:41.110] [INFO] Newsfeed-Fetcher: Broadcasting 20 items.
              sdetweil @pat59
              @pat59
              I edited out your calendar URL from the log above.
              seems other modules are failing for no/old credentials…
              google photos is broken as Google changed the way it works.
              calendar and newsfeed modules say they are doing their thing…
              there IS an old system runtime bug in here ‘possibly’ , you are 5 releases behind, 6 come Oct 1. fix is in the October release…
              1|MagicMir | [2025-09-13 13:57:39.230] [INFO] Calendar-Fetcher: Broadcasting 30 events from https://calendar.google.com/calendar/xxx
                pat59
                Hello, what I don’t understand is that it works sometimes and other times it doesn’t.
                Will the correction be done automatically in October? Thank you.
                  sdetweil @pat59
                  @pat59 I’d like to see the log when it doesn’t work
                  pm2 logs --lines=100 >somefile.txt
                  ctrl-c
                  then send me somefile.txt
                  my same userid at gmail
                    pat59
                    nothing happens when I try
                    pi@raspberrypi:~/MagicMirror $ pm2 logs --lines=100 >somefile.txt
                      sdetweil @pat59
                      @pat59 it does. The command runs and all the output is sent to the file
                      Nothing to see
                        pat59
                        @sdetweil said in update package list:
                        alors envoie-moi somefile.txt
                        mon même identifiant sur Gmail
                          pat59
                          Hello
                          Thank you. You’re asking me a question; I don’t understand your previous answers.
                            pat59
                            When I do
                            open “somefile.txt”
                            nothing happens
                              sdetweil @pat59
                              @pat59 open doesn’t work
                              You need to use some text editor like nano
                              nano somefile.txt
                                sdetweil @pat59
                                @pat59
                                My user id here is sdetweil
                                My email is that user id at gmail
                                  pat59
                                  TAILING] Tailing last 100 lines for [all] processes (change the value with --l$
                                  PM2 | 2025-09-14T16:28:36: PM2 log: pid=1022 msg=failed to kill - retryi$
                                  PM2 | 2025-09-14T16:28:37: PM2 log: pid=1022 msg=failed to kill - retryi$
                                  PM2 | 2025-09-14T16:28:37: PM2 log: Process with pid 1022 still alive af$
                                  PM2 | 2025-09-14T16:28:37: PM2 log: App [MagicMirror:1] exited with code$
                                  PM2 | 2025-09-14T16:28:37: PM2 log: pid=1022 msg=process killed
                                  PM2 | 2025-09-14T16:28:46: PM2 log: [Watch] Start watching MagicMirror
                                  PM2 | 2025-09-14T16:28:46: PM2 log: App [MagicMirror:2] starting in -for$
                                  PM2 | 2025-09-14T16:28:46: PM2 log: App [MagicMirror:2] online
                                  [ Lecture de 931 lignes ]
                                  ^G Aide ^O Écrire ^W Chercher ^K Couper ^J Justifier ^C Pos. cur.
                                  ^X Quitter ^R Lire fich.^\ Remplacer ^U Coller ^T Orthograp.^_ Aller lig.
                                    sdetweil @pat59
                                    @pat59 yeh, those aren’t helpful
                                      pat59
                                      What I don’t understand is that this morning it worked fine, I turned it back on at the beginning of the afternoon, no more calendar or newfeed.
                                        sdetweil @pat59
                                        @pat59 I agree weird
                                        But need lots more info
                                          pat59
                                          Yes, of course, I understand.
                                          Do you want to talk about the file somefile.txt?
                                            sdetweil @pat59
                                            @pat59 somefile.txt is just the name of a file that will hold the contents of some command.
                                            For example, —lines=100 means 100 lines of content are going to be produced. But the terminal window app can only scroll back about 50 lines.
                                            The others are lost
                                            If you send the output to a file, then you can move around, top of file to bottom of file, repeatedly too. Without having to run the command again
                                            • 2 / 3
