    update package list
    45 Posts 2 Posters 17.4k Views 2 Watching
      pat59
      yes indeed not seen
      pi@raspberrypi:~/MagicMirror $ pm2 logs --lines=100.
      PM2 | 2025-09-13T13:56:57: PM2 log: App [MagicMirror:1] starting in -fork mode-
      PM2 | 2025-09-13T13:56:57: PM2 log: App [MagicMirror:1] online
      /home/pi/.pm2/logs/MagicMirror-error.log last 100 lines:
      1|MagicMir | [2025-09-13 13:57:11.358] [WARN] You’re using a full whitelist configuration to allow for all IPs
      1|MagicMir | [2025-09-13 13:57:24.583] [ERROR] ERROR! Could not find main module js file for MMM-Linky
      1|MagicMir | [2025-09-13 13:57:24.875] [ERROR] ERROR! Could not find main module js file for MMM-PrixCarburants
      1|MagicMir | [2025-09-13 13:57:26.522] [ERROR] ERROR! Could not find main module js file for save-remote
      1|MagicMir | [2025-09-13 13:57:40.888] [ERROR] We expected a redirect to guce.yahoo.com, but got https://finance.yahoo.com/quote/AAPL/
      1|MagicMir | [2025-09-13 13:57:40.889] [ERROR] We’ll try to continue anyway - you can safely ignore this if the request succeeds
      1|MagicMir | [2025-09-13 13:57:41.531] [ERROR] Trace: [GPHOTOS:CORE] request fail with URL albums
      1|MagicMir | at GPhotos.logTrace (/home/pi/MagicMirror/modules/MMM-GooglePhotos/GPhotos.js:127:13)
      1|MagicMir | at GPhotos.request (/home/pi/MagicMirror/modules/MMM-GooglePhotos/GPhotos.js:168:12)
      1|MagicMir | at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
      1|MagicMir | at async getAlbum (/home/pi/MagicMirror/modules/MMM-GooglePhotos/GPhotos.js:208:24)
      1|MagicMir | at async GPhotos.getAlbums (/home/pi/MagicMirror/modules/MMM-GooglePhotos/GPhotos.js:180:18)
      1|MagicMir | at async Class.getAlbums (/home/pi/MagicMirror/modules/MMM-GooglePhotos/node_helper.js:263:15)
      1|MagicMir | at async Class.getAlbumList (/home/pi/MagicMirror/modules/MMM-GooglePhotos/node_helper.js:313:18)
      1|MagicMir | at async Class.scanJob (/home/pi/MagicMirror/modules/MMM-GooglePhotos/node_helper.js:294:5)
      1|MagicMir | [2025-09-13 13:57:41.537] [ERROR] Trace: [GPHOTOS:CORE] params {“pageSize”:50,“pageToken”:“”}
      1|MagicMir | at GPhotos.request (/home/pi/MagicMirror/modules/MMM-GooglePhotos/GPhotos.js:169:12)
      1|MagicMir | [2025-09-13 13:57:41.542] [ERROR] Trace: [GPHOTOS:CORE] data null
      1|MagicMir | at GPhotos.request (/home/pi/MagicMirror/modules/MMM-GooglePhotos/GPhotos.js:170:12)
      1|MagicMir | [2025-09-13 13:57:41.572] [ERROR] [GPHOTOS:CORE] response.data:
      1|MagicMir | {“error”:{“code”:403,“message”:“Request had insufficient authentication scopes.”,“status”:“PERMISSION_DENIED”}}
      1|MagicMir | response.status:
      1|MagicMir | 403
      1|MagicMir | headers:
      1|MagicMir | {“vary”:“Origin, X-Origin, Referer”,“content-type”:“application/json; charset=UTF-8”,“date”:“Sat, 13 Sep 2025 11:57:40 GMT”,“server”:“ESF”,“x-xss-protection”:“0”,“x-frame-options”:“SAMEORIGIN”,“x-content-type-options”:“nosniff”,“alt-svc”:“h3=":443"; ma=2592000,h3-29=":443"; ma=2592000”,“transfer-encoding”:“chunked”}
      1|MagicMir | config:
      1|MagicMir | {“transitional”:{“silentJSONParsing”:true,“forcedJSONParsing”:true,“clarifyTimeoutError”:false},“adapter”:[“xhr”,“http”,“fetch”],“transformRequest”:[null],“transformResponse”:[null],“timeout”:0,“xsrfCookieName”:“XSRF-TOKEN”,“xsrfHeaderName”:“X-XSRF-TOKEN”,“maxContentLength”:-1,“maxBodyLength”:-1,“env”:{},“headers”:{“Accept”:“application/json, text/plain, /”,“Authorization”:“Bearer ya29.a0AS3H6NyA7ONxL8SRsM2CzAn9MUyYAqUCVW3B66xtCW2iYEouumznAvH6Cve50JLI09-Vv3BbpaygzUvAeRREgNp9Uq66mrEzgbyFNulxBYw4zTUYwlMyZCftrKFC5yyKbV24vNXGXG9j2Dw7ddPJ7106HcXXNgrZ6BMLZlLTj9c9hWRGWkQU-IoT9_6PoQKDeeyTUtIYdgaCgYKAcUSARISFQHGX2MiruMSTrfXs6E2e2yPY2ullg0209”,“User-Agent”:“axios/1.8.2”,“Accept-Encoding”:“gzip, compress, deflate, br”},“method”:“get”,“url”:“albums”,“baseURL”:“https://photoslibrary.googleapis.com/v1/“,“params”:{“pageSize”:50,“pageToken”:”"},"allowAbsoluteUrls”:true}
      1|MagicMir | [2025-09-13 13:57:41.578] [ERROR] [GPHOTOS:CORE] AxiosError: Request failed with status code 403
      1|MagicMir | [2025-09-13 13:57:41.593] [ERROR] [GPHOTOS] [node_helper] response.data:
      1|MagicMir | 403
      1|MagicMir | [2025-09-13 13:57:41.637] [ERROR] (node:1783) UnhandledPromiseRejectionWarning: AxiosError: Request failed with status code 403
      1|MagicMir | at settle (/home/pi/MagicMirror/modules/MMM-GooglePhotos/node_modules/axios/dist/node/axios.cjs:2031:12)
      1|MagicMir | at Unzip.handleStreamEnd (/home/pi/MagicMirror/modules/MMM-GooglePhotos/node_modules/axios/dist/node/axios.cjs:3148:11)
      1|MagicMir | at Unzip.emit (node:events:526:35)
      1|MagicMir | at endReadableNT (node:internal/streams/readable:1408:12)
      1|MagicMir | at process.processTicksAndRejections (node:internal/process/task_queues:82:21)
      1|MagicMir | at Axios.request (/home/pi/MagicMirror/modules/MMM-GooglePhotos/node_modules/axios/dist/node/axios.cjs:4258:41)
      1|MagicMir | at async GPhotos.request (/home/pi/MagicMirror/modules/MMM-GooglePhotos/GPhotos.js:165:19)
      1|MagicMir | (Use electron --trace-warnings ... to show where the warning was created)
      1|MagicMir | [2025-09-13 13:57:41.646] [ERROR] (node:1783) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag --unhandled-rejections=strict (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 13)
      1|MagicMir | [1783:0913/135904.363177:ERROR:atom_cache.cc(229)] Add WM_CHANGE_STATE to kAtomsToCache
      /home/pi/.pm2/logs/MagicMirror-out.log last 100 lines:
      1|MagicMir |
      1|MagicMir | > magicmirror@2.27.0 start
      1|MagicMir | > DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js
      1|MagicMir |
      1|MagicMir | [2025-09-13 13:57:07.053] [LOG] Starting MagicMirror: v2.27.0
      1|MagicMir | [2025-09-13 13:57:07.131] [LOG] Loading config …
      1|MagicMir | [2025-09-13 13:57:07.145] [LOG] config template file not exists, no envsubst
      1|MagicMir | [2025-09-13 13:57:07.167] [LOG] Loading module helpers …
      1|MagicMir | [2025-09-13 13:57:07.488] [LOG] Initializing new module helper …
      1|MagicMir | [2025-09-13 13:57:07.490] [LOG] Module helper loaded: MMM-Remote-Control
      1|MagicMir | [2025-09-13 13:57:07.495] [LOG] No helper found for module: alert.
      1|MagicMir | [2025-09-13 13:57:07.510] [LOG] Initializing new module helper …
      1|MagicMir | [2025-09-13 13:57:07.513] [LOG] Module helper loaded: MMM-Saint
      1|MagicMir | [2025-09-13 13:57:07.521] [LOG] Initializing new module helper …
      1|MagicMir | [2025-09-13 13:57:07.523] [LOG] Module helper loaded: MMM-BME280
      1|MagicMir | [2025-09-13 13:57:07.527] [LOG] No helper found for module: MMM-FlipClock.
      1|MagicMir | [2025-09-13 13:57:07.656] [LOG] Initializing new module helper …
      1|MagicMir | [2025-09-13 13:57:07.658] [LOG] Module helper loaded: MMM-network-signal
      1|MagicMir | [2025-09-13 13:57:08.139] [LOG] Initializing new module helper …
      1|MagicMir | [2025-09-13 13:57:08.141] [LOG] Module helper loaded: calendar
      1|MagicMir | [2025-09-13 13:57:09.550] [LOG] Initializing new module helper …
      1|MagicMir | [2025-09-13 13:57:09.551] [LOG] Module helper loaded: MMM-Jast
      1|MagicMir | [2025-09-13 13:57:10.936] [LOG] Initializing new module helper …
      1|MagicMir | [2025-09-13 13:57:10.938] [LOG] Module helper loaded: MMM-GooglePhotos
      1|MagicMir | [2025-09-13 13:57:10.946] [LOG] No helper found for module: MMM-WiFiPassword.
      1|MagicMir | [2025-09-13 13:57:10.949] [LOG] No helper found for module: MMM-OpenmapWeather.
      1|MagicMir | [2025-09-13 13:57:10.950] [LOG] No helper found for module: MMM-WeatherOrNot.
      1|MagicMir | [2025-09-13 13:57:11.319] [LOG] Initializing new module helper …
      1|MagicMir | [2025-09-13 13:57:11.320] [LOG] Module helper loaded: newsfeed
      1|MagicMir | [2025-09-13 13:57:11.321] [LOG] All module helpers loaded.
      1|MagicMir | [2025-09-13 13:57:11.345] [LOG] Starting server on port 8080 …
      1|MagicMir | [2025-09-13 13:57:13.570] [LOG] Server started …
      1|MagicMir | [2025-09-13 13:57:13.583] [LOG] Connecting socket for: MMM-Remote-Control
      1|MagicMir | [2025-09-13 13:57:13.586] [LOG] Starting node helper for: MMM-Remote-Control
      1|MagicMir | [2025-09-13 13:57:13.718] [LOG] Connecting socket for: MMM-Saint
      1|MagicMir | [2025-09-13 13:57:13.749] [LOG] [SAINT] MMM-Saint Version: 1.0.1
      1|MagicMir | [2025-09-13 13:57:13.751] [LOG] Connecting socket for: MMM-BME280
      1|MagicMir | [2025-09-13 13:57:13.774] [LOG] BME280 helper started …
      1|MagicMir | [2025-09-13 13:57:13.778] [LOG] Connecting socket for: MMM-network-signal
      1|MagicMir | [2025-09-13 13:57:13.781] [LOG] MMM-network-signal helper started …
      1|MagicMir | [2025-09-13 13:57:13.805] [LOG] Connecting socket for: calendar
      1|MagicMir | [2025-09-13 13:57:13.827] [LOG] Starting node helper for: calendar
      1|MagicMir | [2025-09-13 13:57:13.843] [LOG] Connecting socket for: MMM-Jast
      1|MagicMir | [2025-09-13 13:57:13.848] [LOG] MMM-Jast helper method started…
      1|MagicMir | [2025-09-13 13:57:13.849] [LOG] Connecting socket for: MMM-GooglePhotos
      1|MagicMir | [2025-09-13 13:57:13.851] [LOG] Connecting socket for: newsfeed
      1|MagicMir | [2025-09-13 13:57:13.871] [LOG] Starting node helper for: newsfeed
      1|MagicMir | [2025-09-13 13:57:13.896] [LOG] Sockets connected & modules started …
      1|MagicMir | [2025-09-13 13:57:17.746] [LOG] Launching application.
      1|MagicMir | [2025-09-13 13:57:34.314] [INFO] System information:
      1|MagicMir | ### SYSTEM: manufacturer: Raspberry Pi Foundation; model: Raspberry Pi 3 Model B Plus Rev 1.3; raspberry: [object Object]; virtual: false
      1|MagicMir | ### OS: platform: linux; distro: Raspbian GNU/Linux; release: 10; arch: arm; kernel: 6.12.45-v7+
      1|MagicMir | ### VERSIONS: electron: 29.1.6; used node: 20.9.0; installed node: 18.18.0; npm: 9.8.1; pm2: 5.3.1
      1|MagicMir | ### OTHER: timeZone: Europe/Paris; ELECTRON_ENABLE_GPU: undefined
      1|MagicMir | [2025-09-13 13:57:34.482] [LOG] Create new calendarfetcher for url: https://calendar.google.com/xxx - Interval: 3600000
      1|MagicMir | [2025-09-13 13:57:34.715] [LOG] Please consider completing the survey at https://bit.ly/yahoo-finance-api-feedback if you haven’t already; for more info see https://github.com/gadicc/node-yahoo-finance2/issues/764#issuecomment-2056623851.
      1|MagicMir | [2025-09-13 13:57:35.087] [INFO] [GPHOTOS] [node_helper] Starting Initialization
      1|MagicMir | [2025-09-13 13:57:35.109] [LOG] Create new newsfetcher for url: https://www.lemonde.fr/europe/rss_full.xml - Interval: 300000
      1|MagicMir | [2025-09-13 13:57:35.129] [LOG] Fetching crumb and cookies from https://finance.yahoo.com/quote/AAPL…
      1|MagicMir | [2025-09-13 13:57:36.151] [LOG] fetch https://guce.yahoo.com/consent?brandType=nonEu&gcrumb=Sgaifog&done=https%3A%2F%2Ffinance.yahoo.com%2Fquote%2FAAPL
      1|MagicMir | [2025-09-13 13:57:36.878] [INFO] [GPHOTOS] [node_helper] Config or token has changed. Ignore cache
      1|MagicMir | [2025-09-13 13:57:36.897] [INFO] [GPHOTOS] [node_helper] Initialization complete!
      1|MagicMir | [2025-09-13 13:57:36.900] [INFO] [GPHOTOS] [node_helper] Start first scanning.
      1|MagicMir | [2025-09-13 13:57:36.909] [INFO] [GPHOTOS] [node_helper] Start Album scanning
      1|MagicMir | [2025-09-13 13:57:36.915] [INFO] [GPHOTOS] [node_helper] Getting album list
      1|MagicMir | [2025-09-13 13:57:37.785] [LOG] fetch https://consent.yahoo.com/v2/collectConsent?sessionId=3_cc-session_3a9e4e96-b9eb-4aab-84b3-6fbfbbe4e547
      1|MagicMir | [2025-09-13 13:57:38.158] [INFO] Newsfeed-Fetcher: Broadcasting 20 items.
      1|MagicMir | [2025-09-13 13:57:39.230] [INFO] Calendar-Fetcher: Broadcasting 30 events from https://calendar.google.com/calendarxxx
      1|MagicMir | [2025-09-13 13:57:39.482] [INFO] [GPHOTOS:CORE] Getting Album info chunks.
      1|MagicMir | [2025-09-13 13:57:40.285] [LOG] fetch https://consent.yahoo.com/v2/collectConsent?sessionId=3_cc-session_3a9e4e96-b9eb-4aab-84b3-6fbfbbe4e547
      1|MagicMir | [2025-09-13 13:57:40.481] [LOG] fetch https://guce.yahoo.com/copyConsent?sessionId=3_cc-session_3a9e4e96-b9eb-4aab-84b3-6fbfbbe4e547&lang=fr-FR
      1|MagicMir | [2025-09-13 13:57:40.721] [LOG] Fetching crumb and cookies from https://finance.yahoo.com/quote/AAPL?guccounter=1…
      1|MagicMir | [2025-09-13 13:57:40.918] [LOG] Success. Cookie expires on Infinity
      1|MagicMir | [2025-09-13 13:57:40.941] [LOG] fetch https://query1.finance.yahoo.com/v1/test/getcrumb
      1|MagicMir | [2025-09-13 13:57:41.310] [LOG] New crumb: XcgD8zd85Vp
      1|MagicMir | [2025-09-13 13:57:47.900] [LOG] [SAINT] Config: { debug: true, update: 60000 }
      1|MagicMir | [2025-09-13 13:57:47.910] [LOG] [SAINT] MMM-Saint is now initialized!
      1|MagicMir | [2025-09-13 13:57:47.918] [LOG] [SAINT] Actual Day: 13 In memory: 13
      1|MagicMir | [2025-09-13 13:57:47.920] [LOG] [SAINT] Today 13/9: St Aimé
      1|MagicMir | [2025-09-13 13:57:47.921] [LOG] [SAINT] Send Data to module: St Aimé
      1|MagicMir | [2025-09-13 14:02:39.198] [INFO] Newsfeed-Fetcher: Broadcasting 20 items.
      1|MagicMir | [2025-09-13 14:07:39.774] [INFO] Newsfeed-Fetcher: Broadcasting 20 items.
      1|MagicMir | [2025-09-13 14:12:40.245] [INFO] Newsfeed-Fetcher: Broadcasting 20 items.
      1|MagicMir | [2025-09-13 14:17:40.655] [INFO] Newsfeed-Fetcher: Broadcasting 20 items.
      1|MagicMir | [2025-09-13 14:22:41.110] [INFO] Newsfeed-Fetcher: Broadcasting 20 items.
        sdetweil @pat59
        @pat59
        I edited out your calendar URL from the log above.
        seems other modules are failing for no/old credentials…
        google photos is broken as Google changed the way it works.
        calendar and newsfeed modules say they are doing their thing…
        there IS an old system runtime bug in here ‘possibly’ , you are 5 releases behind, 6 come Oct 1. fix is in the October release…
        1|MagicMir | [2025-09-13 13:57:39.230] [INFO] Calendar-Fetcher: Broadcasting 30 events from https://calendar.google.com/calendar/xxx
          pat59
          Hello, what I don’t understand is that it works sometimes and other times it doesn’t.
          Will the correction be done automatically in October? Thank you.
            sdetweil @pat59
            @pat59 I’d like to see the log when it doesn’t work
            pm2 logs --lines=100 >somefile.txt
            ctrl-c
            then send me somefile.txt
            my same userid at gmail
              pat59
              nothing happens when I try
              pi@raspberrypi:~/MagicMirror $ pm2 logs --lines=100 >somefile.txt
                sdetweil @pat59
                @pat59 it does. The command runs and all the output is sent to the file
                Nothing to see
                  pat59
                  @sdetweil said in update package list:
                  alors envoie-moi somefile.txt
                  mon même identifiant sur Gmail
                    pat59
                    Hello
                    Thank you. You’re asking me a question; I don’t understand your previous answers.
                      pat59
                      When I do
                      open “somefile.txt”
                      nothing happens
                        sdetweil @pat59
                        @pat59 open doesn’t work
                        You need to use some text editor like nano
                        nano somefile.txt
                          sdetweil @pat59
                          @pat59
                          My user id here is sdetweil
                          My email is that user id at gmail
                            pat59
                            TAILING] Tailing last 100 lines for [all] processes (change the value with --l$
                            PM2 | 2025-09-14T16:28:36: PM2 log: pid=1022 msg=failed to kill - retryi$
                            PM2 | 2025-09-14T16:28:37: PM2 log: pid=1022 msg=failed to kill - retryi$
                            PM2 | 2025-09-14T16:28:37: PM2 log: Process with pid 1022 still alive af$
                            PM2 | 2025-09-14T16:28:37: PM2 log: App [MagicMirror:1] exited with code$
                            PM2 | 2025-09-14T16:28:37: PM2 log: pid=1022 msg=process killed
                            PM2 | 2025-09-14T16:28:46: PM2 log: [Watch] Start watching MagicMirror
                            PM2 | 2025-09-14T16:28:46: PM2 log: App [MagicMirror:2] starting in -for$
                            PM2 | 2025-09-14T16:28:46: PM2 log: App [MagicMirror:2] online
                            [ Lecture de 931 lignes ]
                            ^G Aide ^O Écrire ^W Chercher ^K Couper ^J Justifier ^C Pos. cur.
                            ^X Quitter ^R Lire fich.^\ Remplacer ^U Coller ^T Orthograp.^_ Aller lig.
                              sdetweil @pat59
                              @pat59 yeh, those aren’t helpful
                                pat59
                                What I don’t understand is that this morning it worked fine, I turned it back on at the beginning of the afternoon, no more calendar or newfeed.
                                  sdetweil @pat59
                                  @pat59 I agree weird
                                  But need lots more info
                                    pat59
                                    Yes, of course, I understand.
                                    Do you want to talk about the file somefile.txt?
                                      sdetweil @pat59
                                      @pat59 somefile.txt is just the name of a file that will hold the contents of some command.
                                      For example, —lines=100 means 100 lines of content are going to be produced. But the terminal window app can only scroll back about 50 lines.
                                      The others are lost
                                      If you send the output to a file, then you can move around, top of file to bottom of file, repeatedly too. Without having to run the command again
                                        pat59
                                        Hello
                                        Thank you for what you did for me. Now it’s bothering me. We’ll stop there and close the session. Thank you again. Thank you for your help. You are a fantastic person. Thank you for your time spent on our problems. Thank you and thank you again.
                                        • 2 / 3
