    update package list
    45 Posts 2 Posters 17.4k Views 2 Watching
      pat59
      nothing happens when I try
      pi@raspberrypi:~/MagicMirror $ pm2 logs --lines=100 >somefile.txt
        sdetweil @pat59
        @pat59 it does. The command runs and all the output is sent to the file
        Nothing to see
          pat59
          @sdetweil said in update package list:
          alors envoie-moi somefile.txt
          mon même identifiant sur Gmail
            pat59
            Hello
            Thank you. You’re asking me a question; I don’t understand your previous answers.
              pat59
              When I do
              open “somefile.txt”
              nothing happens
                sdetweil @pat59
                @pat59 open doesn’t work
                You need to use some text editor like nano
                nano somefile.txt
                  sdetweil @pat59
                  @pat59
                  My user id here is sdetweil
                  My email is that user id at gmail
                    pat59
                    TAILING] Tailing last 100 lines for [all] processes (change the value with --l$
                    PM2 | 2025-09-14T16:28:36: PM2 log: pid=1022 msg=failed to kill - retryi$
                    PM2 | 2025-09-14T16:28:37: PM2 log: pid=1022 msg=failed to kill - retryi$
                    PM2 | 2025-09-14T16:28:37: PM2 log: Process with pid 1022 still alive af$
                    PM2 | 2025-09-14T16:28:37: PM2 log: App [MagicMirror:1] exited with code$
                    PM2 | 2025-09-14T16:28:37: PM2 log: pid=1022 msg=process killed
                    PM2 | 2025-09-14T16:28:46: PM2 log: [Watch] Start watching MagicMirror
                    PM2 | 2025-09-14T16:28:46: PM2 log: App [MagicMirror:2] starting in -for$
                    PM2 | 2025-09-14T16:28:46: PM2 log: App [MagicMirror:2] online
                    [ Lecture de 931 lignes ]
                    ^G Aide ^O Écrire ^W Chercher ^K Couper ^J Justifier ^C Pos. cur.
                    ^X Quitter ^R Lire fich.^\ Remplacer ^U Coller ^T Orthograp.^_ Aller lig.
                      sdetweil @pat59
                      @pat59 yeh, those aren’t helpful
                        pat59
                        What I don’t understand is that this morning it worked fine, I turned it back on at the beginning of the afternoon, no more calendar or newfeed.
                          sdetweil @pat59
                          @pat59 I agree weird
                          But need lots more info
                            pat59
                            Yes, of course, I understand.
                            Do you want to talk about the file somefile.txt?
                              sdetweil @pat59
                              @pat59 somefile.txt is just the name of a file that will hold the contents of some command.
                              For example, —lines=100 means 100 lines of content are going to be produced. But the terminal window app can only scroll back about 50 lines.
                              The others are lost
                              If you send the output to a file, then you can move around, top of file to bottom of file, repeatedly too. Without having to run the command again
                                pat59
                                Hello
                                Thank you for what you did for me. Now it’s bothering me. We’ll stop there and close the session. Thank you again. Thank you for your help. You are a fantastic person. Thank you for your time spent on our problems. Thank you and thank you again.
                                • 3 / 3
