    How I got my Magic Mirror working on a Raspberry Pi 0 (zero)
    raspberry pipi0zeropizeropi1
    204 Posts 47 Posters 649.0k Views 47 Watching
      Mar
      I have MM2 running quite well on my Pi3 but I’d like to free up the Pi3 and use my zero for the MM2. Has anyone seen any real downsides to using the Pi Zero over the Pi3?
      • W Offline
        Wieber @Mar
        @Mar compared to the Pi3 the processing power is way lower, so from that point of view some modules wouldnt work properly. That said, for the ‘stock’ modules and API driven modules it should all work fine. Besides that the installing process is a bit more difficult as you can read above ;)
          Mar @Wieber
          @Wieber Thanks, I would be using the Button module, PIR sensor module, Wunderlist module, and I want to try adding the Alexa module once i transfer it over to the Pi?
          Another thing I was thinking would be to integrate this into my openhab setup to bring in the status of various sensors.
            SebTota
            I have another question. How could i get into the terminal when the pi goes right into the browser? I cant ssh into it for some reason so is there anyway to exit the browser and go into the terminal?
              bhepler Module Developer @SebTota
              @SebTota Try CTRL+ALT+F2 (note: I have not tried this myself, but it works on other systems I use)
                SebTota
                Yet another question. I tried all other forums but i cant find my answer so I figured id ask here. If i have jessie lite with just the terminal, can I open up a file explorer to copy and paste a folder. I need to copy two folders over but I cant figure out how to do it.
                • Y Offline
                  yawns Moderator @SebTota
                  @SebTota
                  cp -r source destination
                    SebTota
                    Did anyone get
                    https://github.com/HackerHouseYT/AI-Smart-Mirror
                    working on a pi zero. I know its made for a Mac but I`ve been trying somethings and cant succeed to replicate it on the Pi 0. People claim they got it working by following those instructions but im lost on how to install ffmpeg. If anyone got it working on the Pi 0 please share how.
                      Mar
                      If i don’t currently have a monitor is there a way for me to test the output of the MM when running on the zero with Raspbian lite via VNC ?
                        SebTota @Mar
                        @Mar if your running Jessie full you can SSH into the RPI and enable vnc
                          Mar @SebTota
                          @SebTota yeah i realized that, but have a pi zero running lite as i dont require full. was hoping that if i did install vnc and all the dependencies if it would be possible to vnc in and see the mirror as it would in a monitor?
                            SebTota @Mar
                            @Mar I have tried myself with no success. Let me know if you figure it out.
                              Mar @SebTota
                              @SebTota Will do but first…
                              If i make a backup of my memory card and i mess up what im doing now can i just copy the backup back on with finder/explorer and be right back where i was?
                              thanks @SebTota
                                SebTota @Mar
                                @Mar you can’t just copy and paste the drive. Download win32diskimager and read the SD card to a new .ISO file on your pc
                                  bmarofsky @Wieber
                                    Mar
                                    So I had a few errors along the way and had to install some libraries etc and managed to get past a bunch of errors. (libgconf-2-4 and libxss1 for anyone who ends up here!)
                                    But now im at the point where midori loads but has a connection refused page. When I ssh in i can put the command “node serveronly” and it starts up and has a nice log going, or I can use the “DISPLAY=:0 npm start” and it seems all fine with the following lines and no more errors:
                                    magicmirror@2.1.0 start /home/pi/MagicMirror
                                    electron js/electron.js
                                    just not sure whats happening as midori is showing connection refused…maybe the startup script “startMagicMirror” is not actually executing the node serveronly command???
                                    Any help would be appreciated.
                                    Update: Ok so running the “node serveronly” command from ssh and then pointing my laptop browser to the rpi:8080 loads up the MM. But Midori on the Pi is still showing that connection refused. Also…i followed the guide fully so why is the serveronly command not executed by the startup script we put in init.d?
                                    Also is there a way for me to see this node serveronly log on the MM screen (say i dont start midori and leave it on the command line?)
                                    W B 2 Replies Last reply Reply Quote 0
                                      Mar @SebTota
                                        Mar
                                        So I’ve managed to get MM to start using PM2 and can access the page via my laptop.
                                        Only problem I have now is I cant get Midori to auto start, I’m using the same commands from the startmidori script in the mm.sh script for pm2.
                                          SebTota @Mar
                                          @Mar if you want I can share my image with you so all you have to do is download my image into your SD card
                                            Mar @SebTota
                                            @SebTota that would be absolutely amazing… i’ve spent days trying to get this working. I was being pretty persistent wanting to figure this out myself but its just getting to be a little too much time wasted.
                                            I’d appreciate it very much if you could. Thanks.
                                            • 10
                                            • 11
                                            • 3 / 11
