    How I got my Magic Mirror working on a Raspberry Pi 0 (zero)
    raspberry pipi0zeropizeropi1
    204 Posts 47 Posters 671.1k Views 47 Watching
    • bheplerB
      bhepler Module Developer @SebTota
      @SebTota Try CTRL+ALT+F2 (note: I have not tried this myself, but it works on other systems I use)
        SebTota
        Yet another question. I tried all other forums but i cant find my answer so I figured id ask here. If i have jessie lite with just the terminal, can I open up a file explorer to copy and paste a folder. I need to copy two folders over but I cant figure out how to do it.
        yawnsY 1 Reply Last reply
        • yawnsY
          yawns Moderator @SebTota
          @SebTota
          cp -r source destination
            SebTota
            Did anyone get
            https://github.com/HackerHouseYT/AI-Smart-Mirror
            working on a pi zero. I know its made for a Mac but I`ve been trying somethings and cant succeed to replicate it on the Pi 0. People claim they got it working by following those instructions but im lost on how to install ffmpeg. If anyone got it working on the Pi 0 please share how.
              Mar
              If i don’t currently have a monitor is there a way for me to test the output of the MM when running on the zero with Raspbian lite via VNC ?
                SebTota @Mar
                @Mar if your running Jessie full you can SSH into the RPI and enable vnc
                M 1 Reply Last reply
                  Mar @SebTota
                  @SebTota yeah i realized that, but have a pi zero running lite as i dont require full. was hoping that if i did install vnc and all the dependencies if it would be possible to vnc in and see the mirror as it would in a monitor?
                    SebTota @Mar
                    @Mar I have tried myself with no success. Let me know if you figure it out.
                    M 2 Replies Last reply
                      Mar @SebTota
                      @SebTota Will do but first…
                      If i make a backup of my memory card and i mess up what im doing now can i just copy the backup back on with finder/explorer and be right back where i was?
                      thanks @SebTota
                        SebTota @Mar
                        @Mar you can’t just copy and paste the drive. Download win32diskimager and read the SD card to a new .ISO file on your pc
                          bmarofsky @Wieber
                          W 1 Reply Last reply
                            Mar
                            So I had a few errors along the way and had to install some libraries etc and managed to get past a bunch of errors. (libgconf-2-4 and libxss1 for anyone who ends up here!)
                            But now im at the point where midori loads but has a connection refused page. When I ssh in i can put the command “node serveronly” and it starts up and has a nice log going, or I can use the “DISPLAY=:0 npm start” and it seems all fine with the following lines and no more errors:
                            magicmirror@2.1.0 start /home/pi/MagicMirror
                            electron js/electron.js
                            just not sure whats happening as midori is showing connection refused…maybe the startup script “startMagicMirror” is not actually executing the node serveronly command???
                            Any help would be appreciated.
                            Update: Ok so running the “node serveronly” command from ssh and then pointing my laptop browser to the rpi:8080 loads up the MM. But Midori on the Pi is still showing that connection refused. Also…i followed the guide fully so why is the serveronly command not executed by the startup script we put in init.d?
                            Also is there a way for me to see this node serveronly log on the MM screen (say i dont start midori and leave it on the command line?)
                            W B 2 Replies Last reply
                              Mar @SebTota
                                Mar
                                So I’ve managed to get MM to start using PM2 and can access the page via my laptop.
                                Only problem I have now is I cant get Midori to auto start, I’m using the same commands from the startmidori script in the mm.sh script for pm2.
                                  SebTota @Mar
                                  @Mar if you want I can share my image with you so all you have to do is download my image into your SD card
                                    Mar @SebTota
                                    @SebTota that would be absolutely amazing… i’ve spent days trying to get this working. I was being pretty persistent wanting to figure this out myself but its just getting to be a little too much time wasted.
                                    I’d appreciate it very much if you could. Thanks.
                                    • W
                                      Wieber @Mar
                                      @Mar Going out on a limb here: Are you sure you got the names of your scripts and their locations right?
                                      You’re talking about ‘startMagicMirror’ which could either refer to what I called ‘/home/pi/start.sh’ and ‘/home/pi/startMidori’.
                                      In the response you’re getting from your Pi it is referring to Electron, the browsing environment used in the default MM2 system, but which sadly doesn’t work on the Pi Zero. Running MM2 in server only mode would eliminate the whole of Electron I think.
                                      Possible solutions from the top of my mind would be to check your names and paths, and to make sure the ‘start.sh’ script is an executable by using the ‘chmod a+x /home/pi/start.sh’ command, again, names and paths could differ.
                                      This MIGHT also solve the connection refused issue, but I doubt it, for that we might need some more info ;)
                                      Edit: On a side note, I thought I had commented on your question like yesterday, but silly me didn’t press the ‘submit’ button, sorry!
                                      • W
                                        Wieber @bmarofsky
                                        @bmarofsky I don’t recall such errors when I finally did things right to be honest.
                                        Like the error states, it might be because you’re behind a proxy or a firewall, in which case you should look further on the interweb for help, cause I can’t help you with that!
                                        If you aren’t however, I would recommend trying to update NPM to a newer version, as this topic on another forum says it helped for some people.
                                        B 1 Reply Last reply
                                          Mar @Wieber
                                          @Wieber Thanks for the response wieber. Im actually using randombullets guide where he moves the file into the init.d folder.
                                          Thing is i cant get MM to run the server and use a laptop to connect to the pi@8080 and it shows the mirror. I can also run the following commands via SSH to get the MM running on the pi!!! …but i cant AT ALL get the MM window up on the pi automatically using the shell scripts.
                                          Its obviously running the server command as I can access via another computer on the network (which has access via ip whitelist in the config file)
                                          I just need to know why none of the commands after node serveronly arent executing?
                                            bmarofsky @Wieber
                                            • 10
                                            • 11
                                            • 3 / 11
