    Version 2.30.0 weather module, stuck loading, worked fine before upgrade
    52 Posts 6 Posters 32.9k Views 7 Watching
      Rberry91 @sdetweil
      I reverted to the older version and I have tried updating using your command and other ones and still doesn’t update tell me that “pulling without specifying how to reconcile divergent branches is etc”
      The other problem I am having is the weather, the forecast works but the current Weather doesn’t and they are the same code.20250313_055015.jpg 20250313_055058.jpg
        sdetweil @Rberry91
        @Rberry91 divergent branches sounds like you have both modules trying to merge to the same folder
        delete then git clone again
        the nan says the apikey is wrong
        and you have a typo, MagicMirror is case sensitive
        • butchkemperB Offline
          butchkemper
          The configuration parameters I use are:
          module "MMM-OpenWeatherForecase"
          latitude and NOT lat
          longitude and NOT lon
          apikey and NOT apiKey   <----  Notice the "K"
          Some MM configuration keywords have abbreviations but not all. The module README file gives the values for the keywords.
          Also, since your apikey has been revealed to the world, you should cancel the posted key and generate a new key. Always keep the apikey secret.
          Butch
          Resistance is not Futile!
          It is voltage divided by current.
            butchkemper
            @sdetweil I noticed this discretion between the Weather module documentation:
            • The “Weather” documentation has “apiKey” - large case “K”,
            • The “MMM-OpenWeatherForecast” documentation has “apikey” - small case “k”.
            Butch
              sdetweil @butchkemper
              @butchkemper modules can go anything they want
              what is used internally can be anything required
              I looked at the doc for the default weather module before posting above. as there are two instances, one works the other doesn’t. apikey is the issue
              • S sdetweil marked this topic as a regular topic on
              • AssassinsA Offline
                Assassins
                Work on 2.29.0 with api2.5
                But now on 2.33.0
                It say “NaN”
                I get the error 401, it say the apiKey i wrong, but is write from my api key from the website.
                How can i get a apiKey to api3.0 without to paid for it. ???
                The api2.5 still work, but not on this modul.
                      module: 'weather',
                      position: 'bottom_left',
                      header: 'Ballerup',
                         lat: "55.7317",
                         lon: "12.3633",
                         apiKey: "xxxxx765xxxx98xxxjhx888"
                  sdetweil @Assassins
                  @Assassins you cannot get V3 apikey from open weather without providing a credit card.
                  they don’t charge unless you go over 1000/request per day.
                  now, you CAN make 2.5 work (if they still accept api requests they keep telling us they are going to do (have done!!)) just be warned that they can/will end this function sometime…
                  in the module config section
                  apiKey: 2.5_key
                  apiVersion: 2.5
                  and
                  weatherEndpoint: “current” OR “forecast”
                  edited
                  AssassinsA 1 Reply Last reply Reply Quote 0
                    Assassins @sdetweil
                    I can only see the header now, where is write Ballerup
                      module: 'weather',
                      header: 'Ballerup',
                        apiVersion: "2.5",
                        weatherEndpoint: "/current",
                         lat: "55.7317",
                         lon: "12.3633",
                      sdetweil @Assassins
                      @Assassins
                      sorry
                      weatherEndpoint: “current” or 'forecast" , no /
                      also, the old api use location or locationID, not lat/lon
                      and I see you can’t look them up anymore on OWM site
                      here is from the old doc
                      locationID	Location ID from OpenWeatherMap This will override anything you put in location.
                      Leave blank if you want to use location. <------=======
                      Example: 1234567
                      Default value: false
                      Note: When the location and locationID are both not set, the location will be based on the information provided by the calendar module. The first upcoming event with location data will be used.
                      location	The location used for weather information.
                      Example: 'Amsterdam,Netherlands'
                      so it ‘seems’ that location by itself would do it.
                        Assassins @sdetweil
                        This is the same, can only see the header.
                        Is work yesterday on MM 2.29.0
                          module: 'weather',
                          header: 'Ballerup',
                            apiVersion: '2.5',
                           apiBase: 'https://api.openweathermap.org/data/',
                            weatherEndpoint: '/no',
                            locationID: '2624341',
                            apiKey: 'BBnjsdnsdfnsdj8789dsfjsdnfnXX',
                            showHumidity: true,
                            initialLoadDelay: 1500
                          sdetweil @Assassins
                          @Assassins said in Version 2.30.0 weather module, stuck loading, worked fine before upgrade:
                          apiBase: ‘https://api.openweathermap.org/data/’,
                          weatherEndpoint: ‘/no’,
                          no apiBase, that didn’t change
                          the weatherEndpoint is either “current” OR “forecast”
                          I originally gave them to you with leading / , so my comment was without the / (no /)
                            Assassins @sdetweil
                            Is the same mate
                              module: 'weather',
                              header: 'Ballerup',
                                apiVersion: '2.5',
                                weatherEndpoint: 'current',    // i have try the forecast to
                                apiKey: 'xxjljkjsksldjkj3478bjjk',
                                showHumidity: true,
                              sdetweil @Assassins
                              @Assassins seems it doesn’t work anymore… using my old 2.5 key I get code failure with openweathermap
                              but we changed the sample defaults to a free provider that might work
                              			module: "weather",
                              				weatherProvider: "openmeteo",
                              				type: "current",
                              				lat: 40.776676,
                              				lon: -73.971321
                              			module: "weather",
                              			header: "Weather Forecast",
                              				type: "forecast",
                              				lat: 40.776676,
                              				lon: -73.971321
                                Assassins @sdetweil
                                @sdetweil said in Version 2.30.0 weather module, stuck loading, worked fine before upgrade:
                                Strange, works on my sd card with MM2.29.0 and also works on MMM-DynamicWeather and on MMM-WeatherOrNot with MM2.33.0.
                                Don’t know why openweathermap doesn’t work with MM2.33.0.
                                Besides that, it may have something to do with the code in MM2.33.0 that has been rewritten.
                                • S SdR referenced this topic on
                                • 3 / 3
