    Version 2.30.0 weather module, stuck loading, worked fine before upgrade
    52 Posts 6 Posters 35.1k Views 7 Watching
      sdetweil @Rberry91
      @Rberry91 divergent branches sounds like you have both modules trying to merge to the same folder
      delete then git clone again
      the nan says the apikey is wrong
      and you have a typo, MagicMirror is case sensitive
      • butchkemperB
        butchkemper
        The configuration parameters I use are:
        module "MMM-OpenWeatherForecase"
        latitude and NOT lat
        longitude and NOT lon
        apikey and NOT apiKey   <----  Notice the "K"
        Some MM configuration keywords have abbreviations but not all. The module README file gives the values for the keywords.
        Also, since your apikey has been revealed to the world, you should cancel the posted key and generate a new key. Always keep the apikey secret.
        Butch
        Resistance is not Futile!
        It is voltage divided by current.
        • butchkemperB
          butchkemper
          @sdetweil I noticed this discretion between the Weather module documentation:
          • The “Weather” documentation has “apiKey” - large case “K”,
          • The “MMM-OpenWeatherForecast” documentation has “apikey” - small case “k”.
          Butch
            sdetweil @butchkemper
            @butchkemper modules can go anything they want
            what is used internally can be anything required
            I looked at the doc for the default weather module before posting above. as there are two instances, one works the other doesn’t. apikey is the issue
            • S sdetweil marked this topic as a regular topic on
            • AssassinsA
              Assassins
              Work on 2.29.0 with api2.5
              But now on 2.33.0
              It say “NaN”
              I get the error 401, it say the apiKey i wrong, but is write from my api key from the website.
              How can i get a apiKey to api3.0 without to paid for it. ???
              The api2.5 still work, but not on this modul.
                    module: 'weather',
                    position: 'bottom_left',
                    header: 'Ballerup',
                       lat: "55.7317",
                       lon: "12.3633",
                       apiKey: "xxxxx765xxxx98xxxjhx888"
                sdetweil @Assassins
                @Assassins you cannot get V3 apikey from open weather without providing a credit card.
                they don’t charge unless you go over 1000/request per day.
                now, you CAN make 2.5 work (if they still accept api requests they keep telling us they are going to do (have done!!)) just be warned that they can/will end this function sometime…
                in the module config section
                apiKey: 2.5_key
                apiVersion: 2.5
                and
                weatherEndpoint: “current” OR “forecast”
                edited
                AssassinsA 1 Reply Last reply
                • AssassinsA
                  Assassins @sdetweil
                  I can only see the header now, where is write Ballerup
                    module: 'weather',
                    header: 'Ballerup',
                      apiVersion: "2.5",
                      weatherEndpoint: "/current",
                       lat: "55.7317",
                       lon: "12.3633",
                    sdetweil @Assassins
                    @Assassins
                    sorry
                    weatherEndpoint: “current” or 'forecast" , no /
                    also, the old api use location or locationID, not lat/lon
                    and I see you can’t look them up anymore on OWM site
                    here is from the old doc
                    locationID	Location ID from OpenWeatherMap This will override anything you put in location.
                    Leave blank if you want to use location. <------=======
                    Example: 1234567
                    Default value: false
                    Note: When the location and locationID are both not set, the location will be based on the information provided by the calendar module. The first upcoming event with location data will be used.
                    location	The location used for weather information.
                    Example: 'Amsterdam,Netherlands'
                    so it ‘seems’ that location by itself would do it.
                    • AssassinsA
                      Assassins @sdetweil
                      This is the same, can only see the header.
                      Is work yesterday on MM 2.29.0
                        module: 'weather',
                        header: 'Ballerup',
                          apiVersion: '2.5',
                         apiBase: 'https://api.openweathermap.org/data/',
                          weatherEndpoint: '/no',
                          locationID: '2624341',
                          apiKey: 'BBnjsdnsdfnsdj8789dsfjsdnfnXX',
                          showHumidity: true,
                          initialLoadDelay: 1500
                        sdetweil @Assassins
                        @Assassins said in Version 2.30.0 weather module, stuck loading, worked fine before upgrade:
                        apiBase: ‘https://api.openweathermap.org/data/’,
                        weatherEndpoint: ‘/no’,
                        no apiBase, that didn’t change
                        the weatherEndpoint is either “current” OR “forecast”
                        I originally gave them to you with leading / , so my comment was without the / (no /)
                        • AssassinsA
                          Assassins @sdetweil
                          Is the same mate
                            module: 'weather',
                            header: 'Ballerup',
                              apiVersion: '2.5',
                              weatherEndpoint: 'current',    // i have try the forecast to
                              apiKey: 'xxjljkjsksldjkj3478bjjk',
                              showHumidity: true,
                            sdetweil @Assassins
                            @Assassins seems it doesn’t work anymore… using my old 2.5 key I get code failure with openweathermap
                            but we changed the sample defaults to a free provider that might work
                            			module: "weather",
                            				weatherProvider: "openmeteo",
                            				type: "current",
                            				lat: 40.776676,
                            				lon: -73.971321
                            			module: "weather",
                            			header: "Weather Forecast",
                            				type: "forecast",
                            				lat: 40.776676,
                            				lon: -73.971321
                            • AssassinsA
                              Assassins @sdetweil
                              @sdetweil said in Version 2.30.0 weather module, stuck loading, worked fine before upgrade:
                              Strange, works on my sd card with MM2.29.0 and also works on MMM-DynamicWeather and on MMM-WeatherOrNot with MM2.33.0.
                              Don’t know why openweathermap doesn’t work with MM2.33.0.
                              Besides that, it may have something to do with the code in MM2.33.0 that has been rewritten.
                              • S SdR referenced this topic on
                              • 3 / 3
