    Trixie/node v24 - timeouts on request to the internet
    6 Posts 2 Posters 672 Views 2 Watching
    • Mr.SpontiM Offline
      Mr.Sponti
      I’ve migrated my MagigMirror installation on a RPI 4 from Bullseye to Trixie, running now MM V2.33.0 and node v24.11.1.
      After solving some smaller issues with the NetworkManager configuration, everything is now running fine, except that I observe sometimes timeouts on requests to the internet. Fetching Goggle calendar entries or access to Spotify endpoints sometimes end up in timeouts, particularly visible at startup of MagicMirror. (and no, it’s not related to any wrong URL )
      The same MM config is running under Bullseye, MM v2.26.0 and node v20.18.0 without any network issues. It also not a problem of wayland, as I get the same error messages running the config under x11. It seems that this behaviour is related to node V24. Is this a known issue? Is there someone who is fighting with similar issues? Has someone a sustainable solution for that problem?
      [2025-12-01 11:52:18.102] [LOG]   Launching application.
      [2025-12-01 11:52:22.644] [INFO]
      ####  System Information  ####
      - SYSTEM:   manufacturer: Raspberry Pi Foundation; model: Raspberry Pi 4 Model B Rev 1.1; virtual: false; MM: 2.33.0
      - OS:       platform: linux; distro: Debian GNU/Linux; release: 13; arch: arm64; kernel: 6.12.47+rpt-rpi-v8
      - VERSIONS: electron: 39.2.3; used node: 22.21.1; installed node: 24.11.1; npm: 11.6.2; pm2: 6.0.13
      - ENV:      XDG_SESSION_TYPE: tty; MM_CONFIG_FILE: undefined
                  WAYLAND_DISPLAY:  wayland-0; DISPLAY: undefined; ELECTRON_ENABLE_GPU: undefined
      - RAM:      total: 905.64 MB; free: 397.65 MB; used: 507.99 MB
      - OTHERS:   uptime: 23 minutes; timeZone: Europe/Berlin
      [2025-12-01 11:52:23.927] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx%40group.calendar.google.com/private-xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx/basic.ics - Interval: 5400000
      [2025-12-01 11:52:24.132] [LOG]   Create new calendarfetcher for url: https://www.schulferien.org/media/ical/deutschland/ferien_nordrhein-westfalen_2025.ics?k=wMVRLvKrstqVXYv0MZJF9BwhEW4cGfQFjuutfjiALP5Hj700di6oEuYaFGd4tDTvYrLNzQgB7m-GlFC60I4jasaxLk6nJd_OY70AeBteoOU - Interval: 900000
      [2025-12-01 11:52:24.136] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/de.german%23holiday%40group.v.calendar.google.com/public/basic.ics - Interval: 900000
      [2025-12-01 11:52:24.788] [ERROR] Calendar Error. Could not fetch calendar:  https://calendar.google.com/calendar/ical/xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx%40group.calendar.google.com/private-xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx/basic.ics TypeError: fetch failed
          at node:internal/deps/undici/undici:14900:13
          at processTicksAndRejections (node:internal/process/task_queues:105:5)
          at runNextTicks (node:internal/process/task_queues:69:3)
          at process.processTimers (node:internal/timers:520:9) {
        [cause]: AggregateError [ETIMEDOUT]:
            at internalConnectMultiple (node:net:1134:18)
            at internalConnectMultiple (node:net:1210:5)
            at Timeout.internalConnectMultipleTimeout (node:net:1742:5)
            at listOnTimeout (node:internal/timers:590:11)
            at process.processTimers (node:internal/timers:523:7) {
          code: 'ETIMEDOUT',
          [errors]: [ [Error], [Error] ]
        sdetweil @Mr.Sponti
        @Mr.Sponti our code uses a 30 second timeout, but it can be changed by setting an environment variable , here 45 seconds
        export mmFetchTimeout=45000
        In the script used to launch MagicMirror
        See the doc here
        https://docs.magicmirror.builders/configuration/introduction.html#advanced-configuration-and-frequently-asked-how-to-configure-examples
        I submitted a change to fix the doc which has two defaults specified
        But I think you need to fix you network
          Mr.Sponti
          Hi Sam, thank you for your fast response and support!
          I’ve played with the mmFetchTimout parameter without success. As I didn’t had any network issues with Bullseye, MM v2.26.0 and node v20.18.0, I downgraded node to v22.18 and the network issues are gone.
          But I’m now faced with another big issue under Trixie. If I schedule modules using graphic functions like vlc, the CPU load increase dramatically. There is one electron process with parameterer –type=zygote consuming the whole CPU capacity.
          From copilot I got the answer: High CPU usage from electron --type=zygote is usually tied to Chromium’s zygote process, which forks renderer processes.
          Do you have any idea how to get this problem under control?
            sdetweil @Mr.Sponti
            @Mr.Sponti thanks for the feedback, hadn’t expected node to be the problem .
            As for the vlc perf issue , not sure . There have been vlc issues in electron before.
            You might try the next release develop branch
            See https://forum.magicmirror.builders/topic/14327/testing-new-fixes-or-solving-current-problems-with-next-release-code
            A quick way without touching your existing setup use my backup script to save the module list , config and css
            Rename the MagicMirror folder
            git clone the repo, checkout the develop branch
            Oh it needs node 24 (use n or nvm to switch version)
            npm install
            Run the restore script to put the modules, config and css in the new MagicMirror folder
            https://github.com/sdetweil/MagicMirror-backup-restore
              Mr.Sponti
              After further investigations I found the reason for the heavy CPU load. Originator for this behaviour ist the parameter “ELECTRON_ENABLE_GPU=1”. If this parameter is undefined my CPU load is as expected.
              I’ve also had a deeper look to run the “VLC video player” with RTSP streams from my cameras. Using the following command line parameter leads in my environment to best results:
              var opts = { detached: false, env: environ }
              var args = ["-I dummy",
                 "-q",
                 "--zoom=" + this.window.zoom.toString(),
                 "--video-x=" + this.window.x.toString(),		//	x,y-positioning does't work
                 "--video-y=" + this.window.y.toString(),		//	...
                 "--no-audio",
                 "--video-on-top",
                 "--no-video-deco",
                 "--no-osd",
                 "--no-video-title-show",
                 "--network-caching=1000",
                 "--rtsp-tcp",
                 `${this.streams[stream].url}`
              //console.log(playerPath + this.player, args)
              this.streaming.player = spawn(playerPath + this.player, args, opts)
                sdetweil @Mr.Sponti
                @Mr.Sponti do you have the gpu hardware enabled?
                If not then I think electron tries to emulate it, probably w the vlc content
