    Script seems to be failing
    15 Posts 3 Posters 2.4k Views 3 Watching
    • ankonaskiff17A Offline
      ankonaskiff17 @sdetweil
      @sdetweil Sorry for the ultra-slow reply. I think this was a stumble at Raspberry Pi
      I had 3 separate Raspberry Pi 4B’s that I needed to do some tweaking on over the course of the last 2 - 3 weeks.
      Want to note that I have an app I use to delete partitions, format drives in any of the formats out there FAT,NTFS etc. I’ve used it forever but just want to mention I use that tool rather than the format tool in Windows.
      So, the first Pi4 was one set up to run Pi-Hole. I messed it up somehow but net result was I started over formatted SD card, used Pi Imager, chose the Pi 4 64 bit Pi OS and loaded Pi OS on this Pi4. No problems whatsoever. It was unknown to me at the time but an update to the Raspberry Pi Imager was right around the corner. The imager application GUI was slightly different but the OS install went just fine.
      A few days later I went to tackle Pi 4B number 2.
      Formatted the SD Card like I normally do and that went fine. Started the Imager tool and it immediately told me there was an update to the imager and to do the update. I did that with no problems.
      Just like the Pi4 above, I chose Pi4 64 bit Pi OS Full desktop version which I always do, even though I do not necessarily need to.
      The “new” Imager steps through the process a bit different than the older version did, but much of that seems to be just a glossy wrapper around raspi-config. Worked my way through the various steps. The last step is they tell the user there are updates ask if you want to update or skip. That is the last step, I did it a couple of times skipping the updates and doing the updates but it had no bearing on the Pi Imager problem that was going to hit me next.
      Once the update step is either completed or skipped the next window is Congratulations, installation is done, click to launch the Desktop.
      That click took me back to the first configuration step consistently. The two Pi4’s had been sitting in a drawer for a while so I thought maybe that Pi is doing something flaky. I have a 3D printer and those printers seem to like to destroy SD cards so I got a fresh SD card out along with the second Pi4. Did the whole install process with the Pi Imager tool and got the same exact result. Endless loop through the initial Pi setup. Called it a day at that point.
      Next day I got up and took a crack at seeing if I could get the Imager to make it through the entire process, which it did.
      I then tried to run the MM install script which gave me the failure I posted about.
      I have today, with the original Pi4 it had no issues installing the current version of Pi OS so went right to the MM install script and it all installed just fine.
      I went back to Github because you can see when things are updated and was curious about if any Imager or OS updates were taking place at the same time as my problems and yes, there were a bunch of updates that took place at the same time.
      I’m looking at the MM initial screen one gets telling me my overweight *** looks hot so l think this was an issue that was really a Pi Imager and OS image problem.
        sdetweil @ankonaskiff17
        @ankonaskiff17 thanks for the update. I use one of two
        Imagers and never have a problem .
        • karsten13K Offline
          karsten13 @sdetweil
          they changed several things in Nov./Dec. 2025
          • they now use cloud-init in Raspberry Pi OS
          • the new Pi Imager v2 does not allow customizations (user, ssh, wifi, …) when using an image file from disk
          Links:
          • Cloud-init on Raspberry Pi OS
          • How to add your own images to Imager
            sdetweil @karsten13
            @karsten13 interesting
            ankonaskiff17A 1 Reply Last reply Reply Quote 0
              @sdetweil The comments directly above by @karsten13 about some changes done are above my pay grade but I worry that in the quest to “make things better” RaspberryPi will build themselves right out of the niche Pi’s were created for.
                @ankonaskiff17 I hear yah
                they are trying to NOT build (and support) UNIQUE things… as they are buried in adding new stuff…
                so, I expect changes to keep happening, AND that the pi as it was, is no longer the ‘only’ SBC in town as the competition heats up with mini-pcs …
                all of the things in cloud_init are things the raspiconfig app could set,
                I try to stay away from all that system, config stuff, as there are too many platforms to keep track of whatever works…
                  @sdetweil Having installed the latest greatest Pi OS version, it is a lot more complicated process and some of it does not work.
                  Some of the items they do prior to writing to the sd card I have had to go into raspi-config to set. So doing the same configuration step twice is not good.
                  I suppose they are trying to capture a portion of the market they did not have before.
                  The curse of going public. Quarterly earnings.
                  I just looked at their ticker for the first time ever and not a stock I would ever buy .
                    @ankonaskiff17 hm, the 2.0 imager did all the setup right the other day, same as before, user, network, ssh
                      @sdetweil I’ve had to go in on my last two installs and reenter the locale stuff. I know you are not a fan of the old VNC option which Pi has built their own and brought screen sharing in-house with Connect but is a challenge to get up and running. I had to go into raspi-config to enable it. I’ve gotten it going on my my recent installs but not without fumbling around some to get there.
                      I think the warning one gets about using user Pi and that I should change it is overkill.
                      Connect, if I remember you can enable in the configuration before you actually write the image to the sd card but nope.
                      Last install I skipped over enabling Connect in the pre-configuration and did it in Raspi-config.
                      Notice this screen shot and Control Centre vs raspi-config . So enabling Connect and Locale were where I had problems.
                        @ankonaskiff17 I dont use vnc, only ssh
                        And dont have issues w locale
