    MMM-Chores - Manage and keep track of your household Chores
    104 Posts 19 Posters 38.7k Views 20 Watching
    • E Offline
      ewingfox @sdetweil
      @sdetweil - Thanks! I’m a total hack, so I appreciate the heads up. MUCH CLEANER. I’m not used to passing code blocks in chats, usually I’m in an SCM somewhere, causing trouble… giving my devs a headache… :D
      • E Offline
        ewingfox @ewingfox
        I’ve done a lot of testing and submitted PR-220 . It turns out there are some really complicated date functions that worked—unless they didn’t (edge cases with creating a weekday only task, setting start date on a Weekend, etc).
        else if (recurring === "daily-weekdays") {
            // We ignore the d.setDate(+1) and just find the next valid weekday from today
            let testDate = new Date();
            testDate.setDate(testDate.getDate() + 1);
            while (testDate.getDay() === 0 || testDate.getDay() === 6) {
            // Force 'd' to be this specific date, bypassing module interference
            d.setTime(testDate.getTime());
          } else if (recurring === "daily-weekends") {
            while (testDate.getDay() >= 1 && testDate.getDay() <= 5) {
        The logic is working (finally)- I wish I was better at this stuff, I’m a DevOps guy, so I’m lazy and not particularly talented at coding unless I can break thousands of servers with automation (then I’m a pro lol).
        I also went through and added the requisite language support for the 10 supported languages for the two new elements included in admin.html
                              <div class="col-sm-auto">
                                <select id="taskRecurring" class="form-select">
                                  <option value="">One time</option>
                                  <option value="daily">Daily</option>
                                  <option value="weekly">Weekly</option>
                                  <option value="daily-weekdays">Daily (Weekdays Only)</option>
                                  <option value="daily-weekends">Daily (Weekends Only)</option>
                                  <option value="monthly">Monthly</option>
                                  <option value="yearly">Yearly</option>
                                  <option value="every_X_days_2">Every 2 Days</option>
                                  <option value="every_X_days_3">Every 3 Days</option>
                                  <option value="every_X_weeks_2">Every 2 Weeks</option>
                                  <option value="every_X_weeks_3">Every 3 Weeks</option>
                                  <option value="first_monday_month">First Monday of Month</option>
                                </select>
                              </div>
        I’m testing a few .css changes to improve touchscreen support - you can see plenty of other .css issues I’ll nave to sort out, sreenshots from chrome of the MM page shows it’s not adjusting well to different browsers…
        I also put together a mini-module to provide a placard showing the options in the ‘reward store’ - My kid is super goal oriented, so being able to take advantage of @pierregode 's awesome reward system is going to be a big win!
        I’m going to look further into making this interactive and set up some kind of email to us to indicate she’s redeemed her coins on a particular reward.
        The current MMM-ChoreRewards is super crude and rude - you can see plenty of other .css issues I’ll have to sort out. @sdetweil hopefully I’ve formatted this post better - thank you for the #mod help!
        htilburgsH 1 Reply Last reply Reply Quote 1
        • htilburgsH Offline
          htilburgs @ewingfox
          @pierregode
          I’m using dateFormatting: “” in my config, but I stil got the date on the dashboard. Do I somethine wrong?
                            module: "MMM-Chores",
                            header: "Takenlijst",
                                  updateInterval: 60 * 1000,
                                  adminPort: 5003,
                                  showDays: 365,
                                  showPast: true,
                                  dateFormatting: "",
          (still trying to learn JS, but not afraid to ask and AI is my best friend) ☺
          S PierreGodeP 2 Replies Last reply Reply Quote 0
            sdetweil @htilburgs
            @htilburgs try
            dateFormatting:null
            • PierreGodeP Offline
              PierreGode Module Developer @htilburgs
              @htilburgs
              You can set it in the web in config page > Display Settings > Date format > Unassigned > Save
              htilburgsH 2 Replies Last reply Reply Quote 1
                htilburgs @PierreGode
                @PierreGode said in MMM-Chores - Manage and keep track of your household Chores:
                @htilburgs
                I’m sorry for this late reaction. I’ll try this tomorrow (monday) when I have access to my mirror. Currently not at home. I let you Guys know the results.
                  @PierreGode
                  Tested and works. Thanks!
                    jtillinghast
                    Hey all-- I’m trying to get MMM-Chores working, but no matter what I do, the module shows up in the mirror as “No tasks to show (emoji).” I have populated the list with tasks, and confirmed that they appear in the data.json file. And I can reach the admin panel for Chores, so I know the server is running. Relevant codeblock from config.js:
                    					position: "bottom_left",
                    					classes: "overview",
                    					header: "Chores",
                    						adminPort: 5003,
                        					settings: "unlocked",
                    						dateFormatting: "",
                    						login: false,
                    						users: [{ username: "dad", password: "", permission: "read" }],
                    I’m sure it’s something simple, so I appreciate your help! TIA.
                    PierreGodeP 1 Reply Last reply Reply Quote 0
                      PierreGode Module Developer @jtillinghast
                      @jtillinghast
                      What does the command pm2 logs give you?
                        jtillinghast @PierreGode
                        @PierreGode And of course, today it works for seemingly no other reason. I don’t believe I have touched anything in the module or the config since it wasn’t working, but now it looks good! I will continue to monitor. Thanks.
                          jtillinghast
                          Question: Is it possible to set the config in some way to only show chores for one person? I’m using MMM-Pages to give each kid their own dashboard, for example, and I’m wondering if the page could just show the chores for that one person.
                            sdetweil @jtillinghast
                            @jtillinghast and then you need multiple instances in config.js
                              jtillinghast @sdetweil
                              @sdetweil Sure-- I have the multiple instances, but I’m just not sure what to put into the config to filter each instance down.
                                @jtillinghast ok, takes a little extra coding for multiple instances. Just making sure that is handled too
                                  @sdetweil Can you say more about the extra coding? I created multiple instances, and assigned them to the unique pages via the class. Is there more unique configuration that needs to get handled?
                                    @jtillinghast it’s inside the module, nothing you can do.
                                    Currently the module does not do this extra
                                    The module with a node helper sends a request to the helper
                                    The helper gets done and sends the response back
                                    But, the method we use which is fast and flexible,
                                    goes to ALL the same modules at once
                                    So read chore list, send back, all instances get the One list
                                    MagicMirror provides a unique identifier for each module entry in config.js . The trick is to send that identifier with the request
                                    And the helper sends it back with the data AND The modules checks to see if the identifier in the response matches its identifier.
                                    If not just ignore it.
                                      @sdetweil Thanks-- I just want to be sure I’m understanding you correctly. You’re saying that it is not possible to filter the to-do list by individual person as the module is currently constructed. To do so, we would have to add a function which would be able to take in the person parameter from config and filter the data accordingly. If I’m following, that could be done in the module since it’s already performing a check to see if the information matches, but that would require further development.
                                      Am I on track?
                                        @jtillinghast yes, AND it needs to add the this.identifier to the data it sends to the node_helper,
                                        and the node helper has to send that identifier back as part of the returned data, AND the module needs to check the identifier to make sure it matches
                                        else, filter for tasks Sue, send it back and ALL instance will get the tasks for Sue, even tho they asked for Bob or Bill.
                                        so the module needs to be enhanced for 2 different things…
                                          BreanneDolphin
                                          This is great, I am just learning so I might have missed this earlier. I have a touch screen magic mirror, I am able to click off the task on the mirror but it does not seem to save the task as being completed and a few seconds later it just reappears. Is it supposed to do that or are you still only able to check off tasks in the admin portal?
                                          Secondly, can you have the chores grouped by person in the magic mirror display?
                                          • E Offline
                                            ewingfox @BreanneDolphin
                                            @BreanneDolphin
                                            I use a touch screen magic mirror and Pierre’s module and haven’t seen this behavior - can you paste the module’s contents from the config.js as a place to start? Perhaps also a screenshot of this part of the settings in the admin portal?
                                            • 5 / 6
