Solved Creating a module to display daily horoscopes
@morozgrafix
Hi!
I am a rank NOOB who has just managed to get the Magic Mirror going.
I then tried to add the Horoscope Module , but it only displays: “Aligning Stars …”.I have placed all the extracted files from Github , in the: /home/pi/MagicMirror/modules/MMM-horoscope/ folder.
Then I edited the config.js to include:
module: ‘MMM-horoscope’,
position: ‘top_right’, // This can be any of the regions.
// See ‘Configuration options’ for additional options and more information.
sign: ‘aries’, // Zodiac sign
}What else should I be doing?
I’ll be grateful for any help!
Danie Bosman
@djbosman Hi Danie,
In the code snippet that you’ve posted (it’s a good idea to use markdown for code snippets) it looks like you are possibly using “fancy quotes”. Make sure that your
config.js
file has these'
or"
and not these‘
or“
(it’s possible that they were only converted in your post on the forum and your config is ok). Additionally make sure you have a comma after last}
bracket as shown below:{ module: 'MMM-horoscope', position: 'top_right', // This can be any of the regions. config: { // See ‘Configuration options’ for additional options and more information. sign: 'aries', // Zodiac sign } },
Also since this module is using
node helper
you may need to restart electron app for MM to pickup module helper for horoscopes.
You should see these lines in the console log when you donpm start
:Connecting socket for: MMM-horoscope Starting NodeHelper for MMM-horoscopemodule.
Hope this helps and thanks for trying out my module.
P.S. I just added instructions about restarting MM in the README
i add this and get black screen only when i add the horoscope. maybe i dont know hot to install it lol. am i doing something wrong? any help is appreciated.
/* Magic Mirror Config Sample * * By Michael Teeuw http://michaelteeuw.nl * MIT Licensed. */ var config = { port: 8080, ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", ], language: 'en', timeFormat: 12, units: 'imperial', modules: [ { module: 'alert', }, { module: "updatenotification", position: "top_bar" }, { module: 'clock', position: 'top_left' }, { module: 'calendar', header: 'MY CALENDAR', position: 'top_left', config: { fetchInterval: 1 * 60 * 1000, calendars: [ { symbol: 'calendar-check-o ', url: 'webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics' }, { url: 'https://calendar.google.com/calendar/ical/5ddp1drsb3mib0a6piof8h0f8s%40group.calendar.google.com/private-xxxxxxxxxxxxxxx' } ] } }, { module: 'compliments', position: 'lower_third' }, { module: 'MMM-horoscope', position: 'bottom_right', config: { sign: 'aries', // Zodiac sign } }, { module: 'currentweather', position: 'top_right', config: { units: 'imperial', location: '', locationID: '', //ID from http://www.openweathermap.org appid: 'xxxxxxxxxxxxxxxx' } }, { module: 'MMM-Remote-Control' }, { module: 'MMM-WunderGround', position: 'top_right', config: { apikey: 'xxxxxxxxxxxxxxxx', // private; don't share! pws: 'CA/FONTANA', hourly: '1', fctext: '1', fcdaycount: "5", fcdaystart: "0", hourlyinterval: "3", hourlycount: "2", alerttime: 10000, alerttruncatestring: "english:", roundTmpDecs: 1, UseCardinals: 0, layout: "horizontal", sysstat: 0 } }, { module: 'newsfeed', position: 'bottom_bar', config: { feeds: [ { title: "Google News", url: "https://news.google.com/news?cf=all&hl=en&pz=1&ned=us&output=rss" }, { title: "New York Times", url: "http://www.nytimes.com/services /xml/rss/nyt/HomePage.xml" }, { title: "BBC Sci-Tech", url: "http://feeds.bbci.co.uk/news/video_and_audio/technology/rss.xml?edition=uk" } ], showSourceTitle: true, showPublishDate: true, maxNewsItems: 0, updateInterval: 10 * 1000, reloadInterval: 2 * 60 * 1000 } }, ] }; /*************** DO NOT EDIT THE LINE BELOW ***************/ if (typeof module !== 'undefined') {module.exports = config;}
Run that through this: http://javascriptbeautifier.com/
to clean that up… lots of spaces in there… may not be the problem but it could become a problem at some point and it’s easier to read through it when it’s formatted ;)
But I do believe your problem is right here:
url: “http://www.nytimes.com/services
/xml/rss/nyt/HomePage.xml”That’s not valid… needs to be:
url: “http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml”
@pflnpi0305 I believe that @cowboysdude is correct about that line spilling over. It needs to be on one line. When in doubt you can always paste your
config.js
at http://jshint.com/ and see if there are any errors (one warning about undefined variablemodule
is ok) -
@morozgrafix said in Creating a module to display daily horoscopes:
config.js
is ok)Home away from home LOL AND off topic but Thanks and congrats on being a mod :)
so i fixed it and added it the the java beautifier link and thenadded it back to my config.js folder and rebootbut still black screen.
cant use npm start
is it because im using pm2 to autostart my mirror? -
@pflnpi0305 if you are using pm2 then you can restart mm with
pm2 restart mm
, to stop it you would runpm2 stop mm
, to list processes managed by pm2 you would dopm2 list
and to start you would runpm2 start mm
If you are still have issues, post your latest version of
config.js
here again. Are you getting any errors? -
so i also dropped my config in jshint.comand and javascriptbeautifier.com and all is well…i dont know what im missing. if i remove the horoscope everything works well but if i have it then it wont work.
var config = { port: 8080, ipWhitelist: [ "127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.1.1/24" ], language: "en", timeFormat: 12, units: "imperial", modules: [ { module: "MMM-Admin-Interface" }, { module: "alert" }, { module: "updatenotification", position: "top_bar" }, { module: "clock", position: "top_left" }, { module: "calendar", header: "MY CALENDAR", position: "top_left", config: { fetchInterval: 1 * 60 * 1000, calendars: [ { symbol: "calendar-check-o ", url: "webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics" }, { url:"https://calendar.google.com/calendar/ical/5ddp1drsb3mib0a6piof8h0f8s%40group.calendar.google.com/private-xxxxxxxxxxxxxxx/basic.ics" } ] } }, { module: "compliments", position: "lower_third" }, { module: "currentweather", position: "top_right", config: { units: "imperial", location: "FONTANA/CA", locationID: "", appid: "xxxxxxxxxxxxxx" } }, { module: "MMM-Remote-Control" }, { module: "MMM-WunderGround", position: "top_right", config: { apikey: "xxxxxxx", pws: "CA/FONTANA", hourly: "1", fctext: "1", fcdaycount: "5", fcdaystart: "0", hourlyinterval: "3", hourlycount: "2", alerttime: 10000, alerttruncatestring: "english:", roundTmpDecs: 1, UseCardinals: 0, layout: "horizontal", sysstat: 0 } }, { module: "MMM-Globe", position: "center", config: { style: "geoColor", imageSize: 300, ownImagePath: "", updateInterval: 10 * 60 * 1000 } }, { module: "MMM-horoscope", position: "bottom_right", config: { sign: "aries" } }, { module: "newsfeed", position: "bottom_bar", config: { feeds: [ { title: "Google News", url: "https://news.google.com/news?cf=all&hl=en&pz=1&ned=us&output=rss" }, { title: "New York Times", url: "http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml" }, { title: "BBC Sci-Tech", url: "http://feeds.bbci.co.uk/news/video_and_audio/technology/rss.xml?edition=uk" } ], showSourceTitle: true, showPublishDate: true, maxNewsItems: 0, updateInterval: 10 * 1000, reloadInterval: 2 * 60 * 1000 } } ] }; if ("undefined" !== typeof module) module.exports = config;
@pflnpi0305 Do you see any errors in the console log when you run it start the mirror with
npm start dev
command? Also are you running off the master branch or dev?
We can try to start eliminating things out to narrow down what is causing the black screen for you.Can you try this config with only horoscope module:
/* Magic Mirror Config Sample * * By Michael Teeuw http://michaelteeuw.nl * MIT Licensed. */ var config = { port: 8080, ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], language: 'en', timeFormat: 24, units: 'metric', modules: [ { module: 'MMM-horoscope', position: 'bottom_right', // This can be any of the regions. config: { // See ‘Configuration options’ for additional options and more information. sign: 'aries', // Zodiac sign } }, ] }; /*************** DO NOT EDIT THE LINE BELOW ***************/ if (typeof module !== 'undefined') {module.exports = config;}
Also can you please double check that
MMM-horoscope
and contents exist under~/MagicMirror/modules
directory? (I know I’m asking for obvious things, just trying to get some more info about your installation).
