    Creating a module to display daily horoscopes
    Scheduled Pinned Locked Moved Solved Development
    26 Posts 7 Posters 23.0k Views 6 Watching
    • morozgrafixM Offline
      morozgrafix Moderator
      I’ve pushed my initial work for the module to GitHub. This is my very first MM module and I probably missed something obvious. Please get in touch with me if you have a suggestion or feature request (filing GH Issue is a great way to do it). Once I feel comfortable and possibly have some beta testers I will add a separate thread for this module. Thanks.
      Repo is here: https://github.com/morozgrafix/MMM-horoscope
        This topic can probably be marked as “solved” - module thread is here https://forum.magicmirror.builders/topic/1370/mmm-horoscope
          djbosman @morozgrafix
          @morozgrafix
          Hi!
          I am a rank NOOB who has just managed to get the Magic Mirror going.
          I then tried to add the Horoscope Module , but it only displays: “Aligning Stars …”.
          I have placed all the extracted files from Github , in the: /home/pi/MagicMirror/modules/MMM-horoscope/ folder.
          Then I edited the config.js to include:
          module: ‘MMM-horoscope’,
          position: ‘top_right’, // This can be any of the regions.
          // See ‘Configuration options’ for additional options and more information.
          sign: ‘aries’, // Zodiac sign
          What else should I be doing?
          I’ll be grateful for any help!
          Danie Bosman
          morozgrafixM 1 Reply Last reply Reply Quote 0
            morozgrafix Moderator @djbosman
            @djbosman Hi Danie,
            In the code snippet that you’ve posted (it’s a good idea to use markdown for code snippets) it looks like you are possibly using “fancy quotes”. Make sure that your config.js file has these ' or " and not these ‘ or “ (it’s possible that they were only converted in your post on the forum and your config is ok). Additionally make sure you have a comma after last } bracket as shown below:
            			module: 'MMM-horoscope',
            			position: 'top_right', // This can be any of the regions.
            				sign: 'aries', // Zodiac sign
            Also since this module is using node helper you may need to restart electron app for MM to pickup module helper for horoscopes.
            You should see these lines in the console log when you do npm start:
            Connecting socket for: MMM-horoscope
            Starting NodeHelper for MMM-horoscopemodule.
            Hope this helps and thanks for trying out my module.
            P.S. I just added instructions about restarting MM in the README
              pflnpi0305
              i add this and get black screen only when i add the horoscope. maybe i dont know hot to install it lol. am i doing something wrong? any help is appreciated.
              /* Magic Mirror Config Sample
               * MIT Licensed.
              var config = {
              	port: 8080,
              	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", ],
              	language: 'en',
              	timeFormat: 12,
              	units: 'imperial',
              			module: 'alert',
              			module: "updatenotification",
              			position: "top_bar"
              			module: 'clock',
              			position: 'top_left'
              			module: 'calendar',
              			header: 'MY CALENDAR',
              			position: 'top_left',
              			fetchInterval: 1 * 60 * 1000,
              						symbol: 'calendar-check-o ',
                                                              url: 'https://calendar.google.com/calendar/ical/5ddp1drsb3mib0a6piof8h0f8s%40group.calendar.google.com/private-xxxxxxxxxxxxxxx'
              			module: 'compliments',
              			position: 'lower_third'
                  			position: 'bottom_right',
              		        module: 'currentweather',
              				units: 'imperial',
              				locationID: '',  //ID from http://www.openweathermap.org
              				appid: 'xxxxxxxxxxxxxxxx'
              			module: 'MMM-Remote-Control'
              			module: 'MMM-WunderGround',
                     				 apikey: 'xxxxxxxxxxxxxxxx', // private; don't share!
                      			 pws: 'CA/FONTANA',
                      			 hourly: '1',
                     			         fctext: '1',
                      			 fcdaycount: "5",
                      			 fcdaystart: "0",
                      			 hourlyinterval: "3",
                      			 hourlycount: "2",
                      			 alerttime: 10000,
                      			 alerttruncatestring: "english:",
                  			         roundTmpDecs: 1,
                  				 UseCardinals: 0,
                  				 layout: "horizontal",
                  				sysstat: 0
              			module: 'newsfeed',
              			position: 'bottom_bar',
              				feeds: [
              						title: "Google News",
              						url: "https://news.google.com/news?cf=all&hl=en&pz=1&ned=us&output=rss"
              						title: "New York Times",
              	                    			url:       "http://www.nytimes.com/services
                                                           /xml/rss/nyt/HomePage.xml"
                      				        title: "BBC Sci-Tech",
              						url: "http://feeds.bbci.co.uk/news/video_and_audio/technology/rss.xml?edition=uk"
              				showSourceTitle: true,
              				showPublishDate: true,
              				maxNewsItems: 0,
              				updateInterval: 10 * 1000,
              				reloadInterval:  2 * 60 * 1000
              • cowboysdudeC Offline
                @pflnpi0305
                Run that through this: http://javascriptbeautifier.com/
                to clean that up… lots of spaces in there… may not be the problem but it could become a problem at some point and it’s easier to read through it when it’s formatted ;)
                But I do believe your problem is right here:
                url: “http://www.nytimes.com/services
                /xml/rss/nyt/HomePage.xml”
                That’s not valid… needs to be:
                url: “http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml”
                  morozgrafix Moderator @pflnpi0305
                  @pflnpi0305 I believe that @cowboysdude is correct about that line spilling over. It needs to be on one line. When in doubt you can always paste your config.js at http://jshint.com/ and see if there are any errors (one warning about undefined variable module is ok)
                    cowboysdude Module Developer @morozgrafix
                    @morozgrafix said in Creating a module to display daily horoscopes:
                    Home away from home LOL AND off topic but Thanks and congrats on being a mod :)
                      pflnpi0305
                      so i fixed it and added it the the java beautifier link and thenadded it back to my config.js folder and rebootbut still black screen.
                      cant use npm start
                      is it because im using pm2 to autostart my mirror?
                        @pflnpi0305 if you are using pm2 then you can restart mm with pm2 restart mm, to stop it you would run pm2 stop mm, to list processes managed by pm2 you would do pm2 list and to start you would run pm2 start mm
                        If you are still have issues, post your latest version of config.js here again. Are you getting any errors?
                          pflnpi0305
                          so i also dropped my config in jshint.comand and javascriptbeautifier.com and all is well…i dont know what im missing. if i remove the horoscope everything works well but if i have it then it wont work.
                                        var config = {
                          port: 8080,
                          ipWhitelist: [ "127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.1.1/24" ],
                          language: "en",
                          timeFormat: 12,
                          units: "imperial",
                          modules: [ {
                              module: "MMM-Admin-Interface"
                              module: "alert"
                              position: "top_bar"
                              module: "clock",
                              position: "top_left"
                              header: "MY CALENDAR",
                                  calendars: [ {
                                      symbol: "calendar-check-o ",
                                      url:"https://calendar.google.com/calendar/ical/5ddp1drsb3mib0a6piof8h0f8s%40group.calendar.google.com/private-xxxxxxxxxxxxxxx/basic.ics"
                              module: "compliments",
                              position: "lower_third"
                              module: "currentweather",
                                  units: "imperial",
                                  locationID: "",
                                  appid: "xxxxxxxxxxxxxx"
                              module: "MMM-Remote-Control"
                              module: "MMM-WunderGround",
                                  apikey: "xxxxxxx",
                                  pws: "CA/FONTANA",
                                  hourly: "1",
                                  fctext: "1",
                                  fcdaycount: "5",
                                  fcdaystart: "0",
                                  hourlycount: "2",
                                  alerttime: 10000,
                                  roundTmpDecs: 1,
                                  UseCardinals: 0,
                                  sysstat: 0
                              module: "MMM-Globe",
                              position: "center",
                                  style: "geoColor",
                                  imageSize: 300,
                                  ownImagePath: "",
                                  updateInterval: 10 * 60 * 1000
                              module: "MMM-horoscope",
                              position: "bottom_right",
                                  sign: "aries"
                              module: "newsfeed",
                              position: "bottom_bar",
                                  feeds: [ {
                                  maxNewsItems: 0,
                          if ("undefined" !== typeof module) module.exports = config;
                            @pflnpi0305 Do you see any errors in the console log when you run it start the mirror with npm start dev command? Also are you running off the master branch or dev?
                            We can try to start eliminating things out to narrow down what is causing the black screen for you.
                            Can you try this config with only horoscope module:
                             * MIT Licensed.
                            var config = {
                            	port: 8080,
                            	language: 'en',
                            	timeFormat: 24,
                            	units: 'metric',
                            			position: 'bottom_right', // This can be any of the regions.
                            Also can you please double check that MMM-horoscope and contents exist under ~/MagicMirror/modules directory? (I know I’m asking for obvious things, just trying to get some more info about your installation).
                              pflnpi0305
                              thats the issue it doesnt exsist in there… how do i clone the git via ssh
                                @pflnpi0305 It will not work if you don’t have a copy of the module installed locally, black screen is there because MM is attempting to load JS files for the module from the directory that doesn’t exist. You need to run this in terminal while connected to your RasPi (directly or via SSH).
                                cd ~/MagicMirror/modules
                                git clone https://github.com/morozgrafix/MMM-horoscope.git
                                After that you would need to restart MM node process in order it to pickup new node_helper for horoscope module.
                                • Y Offline
                                  yawns Moderator @pflnpi0305
                                  @pflnpi0305 said in Creating a module to display daily horoscopes:
                                  Mh, you are right. The readme on github doesn’t state how to do this. Maybe @morozgrafix could add this, even though the process is always the same.
                                  If you go to github, you see this:
                                  1. click on “clone or download”
                                  2. copy the url or click on the icon next to it
                                  cd MMM-horoscope
                                  npm install
                                  After that you update your config.js file, restart your magic mirror and should be fine
                                  edit: oh, morozgrafix was faster
                                  morozgrafixM 1 Reply Last reply Reply Quote 1
                                    morozgrafix Moderator @yawns
                                    @yawns Thanks! I just added a small bit related to installation steps to the README.
                                      pflnpi0305
                                      lol thank you guys i should have thought of it but idk why it just slipped my mind i followed and i thought hmmm i need to close i think ahah…thanks i love this forum and all the help here.
