    Creating a module to display daily horoscopes
    Scheduled Pinned Locked Moved Solved Development
    26 Posts 7 Posters 21.3k Views 6 Watching
    • morozgrafixM Offline
      morozgrafix Moderator
      I believe that OP already attempted to use newsfeed, but since it only displays title of the each newsfeed item and not the description he was getting something along the lines of Dec 20 Aquarius displayed on the screen.
      I’ve looked around and found a way to get Daily and Weekly feeds in JSON form and started to create a small prototype for the module. Will be happy to share it here once it is a bit more solidified and ready to be tested. (I never wrote a module from scratch, so it’s a good learning experience for me).
        Here is an initial draft of the styling (I’m testing in Chrome on my Mac at the moment, haven’t had time to throw it on RasPi yet). Feedback is welcome:
        cowboysdudeC 1 Reply Last reply Reply Quote 4
        • cowboysdudeC Offline
          cowboysdude Module Developer @morozgrafix
          @morozgrafix said in Creating a module to display daily horoscopes:
          Love it! LOL I was in process of building just about the same thing… it may be a tad different but mine is about done too :)
          Nice to see members who can answering the call for those who can’t!! LOVE THIS PLACE!
            Colors are wrong right now and needs a bit more styling but this was the one I’ve been working on…
            morozgrafixM 1 Reply Last reply Reply Quote 0
              morozgrafix Moderator @cowboysdude
              @cowboysdude Very nice! What feed are you using for data? I found not very official way to consume API from https://www.yahoo.com/style/horoscope Don’t know if that source is any good, since I’m very clueless about horoscopes.
                I’ve pushed my initial work for the module to GitHub. This is my very first MM module and I probably missed something obvious. Please get in touch with me if you have a suggestion or feature request (filing GH Issue is a great way to do it). Once I feel comfortable and possibly have some beta testers I will add a separate thread for this module. Thanks.
                Repo is here: https://github.com/morozgrafix/MMM-horoscope
                  This topic can probably be marked as “solved” - module thread is here https://forum.magicmirror.builders/topic/1370/mmm-horoscope
                    djbosman @morozgrafix
                    @morozgrafix
                    Hi!
                    I am a rank NOOB who has just managed to get the Magic Mirror going.
                    I then tried to add the Horoscope Module , but it only displays: “Aligning Stars …”.
                    I have placed all the extracted files from Github , in the: /home/pi/MagicMirror/modules/MMM-horoscope/ folder.
                    Then I edited the config.js to include:
                    module: ‘MMM-horoscope’,
                    position: ‘top_right’, // This can be any of the regions.
                    // See ‘Configuration options’ for additional options and more information.
                    sign: ‘aries’, // Zodiac sign
                    What else should I be doing?
                    I’ll be grateful for any help!
                    Danie Bosman
                      morozgrafix Moderator @djbosman
                      @djbosman Hi Danie,
                      In the code snippet that you’ve posted (it’s a good idea to use markdown for code snippets) it looks like you are possibly using “fancy quotes”. Make sure that your config.js file has these ' or " and not these ‘ or “ (it’s possible that they were only converted in your post on the forum and your config is ok). Additionally make sure you have a comma after last } bracket as shown below:
                      			module: 'MMM-horoscope',
                      			position: 'top_right', // This can be any of the regions.
                      				sign: 'aries', // Zodiac sign
                      Also since this module is using node helper you may need to restart electron app for MM to pickup module helper for horoscopes.
                      You should see these lines in the console log when you do npm start:
                      Connecting socket for: MMM-horoscope
                      Starting NodeHelper for MMM-horoscopemodule.
                      Hope this helps and thanks for trying out my module.
                      P.S. I just added instructions about restarting MM in the README
                        pflnpi0305
                        i add this and get black screen only when i add the horoscope. maybe i dont know hot to install it lol. am i doing something wrong? any help is appreciated.
                        /* Magic Mirror Config Sample
                         * MIT Licensed.
                        var config = {
                        	port: 8080,
                        	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", ],
                        	language: 'en',
                        	timeFormat: 12,
                        	units: 'imperial',
                        			module: 'alert',
                        			module: "updatenotification",
                        			position: "top_bar"
                        			module: 'clock',
                        			position: 'top_left'
                        			module: 'calendar',
                        			header: 'MY CALENDAR',
                        			position: 'top_left',
                        			fetchInterval: 1 * 60 * 1000,
                        						symbol: 'calendar-check-o ',
        url: 'https://calendar.google.com/calendar/ical/5ddp1drsb3mib0a6piof8h0f8s%40group.calendar.google.com/private-xxxxxxxxxxxxxxx'
                        			module: 'compliments',
                        			position: 'lower_third'
                            			position: 'bottom_right',
                        		        module: 'currentweather',
                        				units: 'imperial',
                        				locationID: '',  //ID from http://www.openweathermap.org
                        				appid: 'xxxxxxxxxxxxxxxx'
                        			module: 'MMM-Remote-Control'
                        			module: 'MMM-WunderGround',
                               				 apikey: 'xxxxxxxxxxxxxxxx', // private; don't share!
                                			 pws: 'CA/FONTANA',
                                			 hourly: '1',
                               			         fctext: '1',
                                			 fcdaycount: "5",
                                			 fcdaystart: "0",
                                			 hourlyinterval: "3",
                                			 hourlycount: "2",
                                			 alerttime: 10000,
                                			 alerttruncatestring: "english:",
                            			         roundTmpDecs: 1,
                            				 UseCardinals: 0,
                            				 layout: "horizontal",
                            				sysstat: 0
                        			module: 'newsfeed',
                        			position: 'bottom_bar',
                        				feeds: [
                        						title: "Google News",
                        						url: "https://news.google.com/news?cf=all&hl=en&pz=1&ned=us&output=rss"
                        						title: "New York Times",
                        	                    			url:       "http://www.nytimes.com/services
        /xml/rss/nyt/HomePage.xml"
                                				        title: "BBC Sci-Tech",
                        						url: "http://feeds.bbci.co.uk/news/video_and_audio/technology/rss.xml?edition=uk"
                        				showSourceTitle: true,
                        				showPublishDate: true,
                        				maxNewsItems: 0,
                        				updateInterval: 10 * 1000,
                        				reloadInterval:  2 * 60 * 1000
