MMM-horoscope - daily horoscope
Description:
Horoscope Module for MagicMirror² v.0.1.0
This is a module for MagicMirror² that adds daily horoscope pulled from the Yahoo Style Horoscopes. API endpoint used for this module is not officially supported and may break at any time.
Initial request for it was by @YoungHomie and I thought that this would be a good opportunity to try creating my first module from scratch. (I’m pretty much clueless when it comes to horoscopes or anything related to astrology) Details are in the repo, feel free to file issues on github if you find bugs or have suggestions for features. It’s also easy get in touch with me through the forum.
Screenshots:
Download:
Version 0.1.0
- Initial Work committed
Hi, that’s only in English?
@lolobyte At this point it is only in English, as I was only able to find one reliable API to pull data from. If you know of other API or possible RSS feeds in other languages I’m happy to look into integrating it as well.
Thank you! Some german would be nice:-)
@fox If you know of a source for daily horoscope in German (preferably in API form, but RSS feed may also work) I’m happy to look into adding it to the module.
cant get mine to work, after i add this i get black screen. any help is appreciated
@pflnpi0305 are you getting any errors? Looks like you’ve posted your config in another thread, will help you there.
Hi @morozgrafix
Can you integrate this RSS (it’s French daily horoscope) in your module ?
https://www.horoscope.fr/rss/horoscope/jour
Thanks à lot !Stephane.
@istepgueu I will look into it. may need some help with translations.
Just quickly glanced at it and it seems that RSS feed doesn’t have complete text of the horoscopes only partial information. I’m not sure how useful it would be when displayed on the MM
For example here is the text from RSS feed
Amour : 31 01 2017 Vous aimeriez bien vous changer les idées auprès de votre...<br>Travail : 31 01 2017 Une bonne stratégie vous évitera de perdre du temps dans des...<br>Vitalité : 31 01 2017 Avec Mars dans votre secteur d'ombre, vous ne serez pas à l'abri d'un...<br>Humeur : 31 01 2017 Vous ferez de votre mieux pour ne pas prendre les choses qui n'en valent...<br /><a href="https://www.horoscope.fr/horoscopes/horoscope_taureau.html" title="Horoscope du taureau">Horoscope du taureau</a> ou visitez ce site : <a href="http://www.voyanceprivee.org" title="voyanceprivee.org" rel="nofollow">voyanceprivee.org</a>
It would look like this (after some formatting):
Amour : 31 01 2017 Vous aimeriez bien vous changer les idées auprès de votre... Travail : 31 01 2017 Une bonne stratégie vous évitera de perdre du temps dans des... Vitalité : 31 01 2017 Avec Mars dans votre secteur d'ombre, vous ne serez pas à l'abri d'un... Humeur : 31 01 2017 Vous ferez de votre mieux pour ne pas prendre les choses qui n'en valent...
Hummm yes, the sentences are truncated.
I will try to find another stream more clear and comprehensive.
Thank you very much for the quick response
