    MMM-horoscope - daily horoscope
    25 Posts 11 Posters 22.8k Views 9 Watching
    • foxF Offline
      fox
      Thank you! Some german would be nice:-)
      Issues With MMM-WatchDog known?
      https://forum.magicmirror.builders/post/29827
      Useful for PIR-Sensor: https://forum.magicmirror.builders/post/21299
      morozgrafixM 1 Reply Last reply Reply Quote 0
      • morozgrafixM Offline
        morozgrafix Moderator @fox
        @fox If you know of a source for daily horoscope in German (preferably in API form, but RSS feed may also work) I’m happy to look into adding it to the module.
          pflnpi0305
          cant get mine to work, after i add this i get black screen. any help is appreciated
            morozgrafix Moderator @pflnpi0305
            @pflnpi0305 are you getting any errors? Looks like you’ve posted your config in another thread, will help you there.
            istepgueuI 1 Reply Last reply Reply Quote 0
            • istepgueuI Offline
              istepgueu @morozgrafix
              Hi @morozgrafix
              Can you integrate this RSS (it’s French daily horoscope) in your module ?
              https://www.horoscope.fr/rss/horoscope/jour
              Thanks à lot !
              Stephane.
                morozgrafix Moderator @istepgueu
                @istepgueu I will look into it. may need some help with translations.
                Just quickly glanced at it and it seems that RSS feed doesn’t have complete text of the horoscopes only partial information. I’m not sure how useful it would be when displayed on the MM
                For example here is the text from RSS feed
                Amour : 31 01 2017 Vous aimeriez bien vous changer les idées auprès de votre...<br>Travail : 31 01 2017 Une bonne stratégie vous évitera de perdre du temps dans des...<br>Vitalité : 31 01 2017 Avec Mars dans votre secteur d'ombre, vous ne serez pas à l'abri d'un...<br>Humeur : 31 01 2017 Vous ferez de votre mieux pour ne pas prendre les choses qui n'en valent...<br /><a href="https://www.horoscope.fr/horoscopes/horoscope_taureau.html" title="Horoscope du taureau">Horoscope du taureau</a> ou visitez ce site : <a href="http://www.voyanceprivee.org" title="voyanceprivee.org" rel="nofollow">voyanceprivee.org</a>
                It would look like this (after some formatting):
                  istepgueu
                  Hummm yes, the sentences are truncated.
                  I will try to find another stream more clear and comprehensive.
                  Thank you very much for the quick response
                    @istepgueu no problem. Let me know if you find something that can be used.
                      Maxzovirax
                      Hello, I am trying to have 2 horoscopes run on the mirror, one foe my wife and one for my daughter, unfortunately if I repeat the module twice in the config.jf file it will only display the text of the first loaded horoscope. That is twice the Leo sign. Is there a way to have two. My plan is to use the the scheduler ot the profile switcher on a later date. I hope it is possible. that would be the last touch to my mirror.
                        morozgrafix Moderator @Maxzovirax
                        @Maxzovirax Good point. It will not work with 2 modules running simultaneously because they both will pick up same broadcast message from node_helper.js. I wonder if modification of the module to allow display of multiple horoscope predictions in the same module would be sufficient. It will take a bit of time to do that modification and I’m going on a small vacation tomorrow. I will think on how it can be addressed. Thanks for bringing it up.
