    MMM-horoscope - daily horoscope
    25 Posts 11 Posters 25.5k Views 9 Watching
      pflnpi0305
      cant get mine to work, after i add this i get black screen. any help is appreciated
      morozgrafixM 1 Reply Last reply Reply Quote 0
      • morozgrafixM Offline
        morozgrafix Moderator @pflnpi0305
        @pflnpi0305 are you getting any errors? Looks like you’ve posted your config in another thread, will help you there.
        • I Offline
          istepgueu @morozgrafix
          Hi @morozgrafix
          Can you integrate this RSS (it’s French daily horoscope) in your module ?
          https://www.horoscope.fr/rss/horoscope/jour
          Thanks à lot !
          Stephane.
            morozgrafix Moderator @istepgueu
            @istepgueu I will look into it. may need some help with translations.
            Just quickly glanced at it and it seems that RSS feed doesn’t have complete text of the horoscopes only partial information. I’m not sure how useful it would be when displayed on the MM
            For example here is the text from RSS feed
            Amour : 31 01 2017 Vous aimeriez bien vous changer les idées auprès de votre...<br>Travail : 31 01 2017 Une bonne stratégie vous évitera de perdre du temps dans des...<br>Vitalité : 31 01 2017 Avec Mars dans votre secteur d'ombre, vous ne serez pas à l'abri d'un...<br>Humeur : 31 01 2017 Vous ferez de votre mieux pour ne pas prendre les choses qui n'en valent...<br /><a href="https://www.horoscope.fr/horoscopes/horoscope_taureau.html" title="Horoscope du taureau">Horoscope du taureau</a> ou visitez ce site : <a href="http://www.voyanceprivee.org" title="voyanceprivee.org" rel="nofollow">voyanceprivee.org</a>
            It would look like this (after some formatting):
            • I Offline
              istepgueu
              Hummm yes, the sentences are truncated.
              I will try to find another stream more clear and comprehensive.
              Thank you very much for the quick response
                @istepgueu no problem. Let me know if you find something that can be used.
                  Maxzovirax
                  Hello, I am trying to have 2 horoscopes run on the mirror, one foe my wife and one for my daughter, unfortunately if I repeat the module twice in the config.jf file it will only display the text of the first loaded horoscope. That is twice the Leo sign. Is there a way to have two. My plan is to use the the scheduler ot the profile switcher on a later date. I hope it is possible. that would be the last touch to my mirror.
                    morozgrafix Moderator @Maxzovirax
                    @Maxzovirax Good point. It will not work with 2 modules running simultaneously because they both will pick up same broadcast message from node_helper.js. I wonder if modification of the module to allow display of multiple horoscope predictions in the same module would be sufficient. It will take a bit of time to do that modification and I’m going on a small vacation tomorrow. I will think on how it can be addressed. Thanks for bringing it up.
                      Maxzovirax @morozgrafix
                      @morozgrafix Thank you for you quick reply… Verry nice of you to have a look at it, will look forward to a solution… have a nice holiday (going skiing?)
                        broberg Project Sponsor @Maxzovirax
                        @Maxzovirax A quick fix might be to
                        Copy the MMM-horoscope folder and rename it to MMM-horoscope2
                        Open the MMM-horoscope.js file and change the lineModule.register("MMM-horoscope",{
                        to Module.register("MMM-horoscope2",{
                        Save it, and then rename MMM-horoscope.js to MMM-horoscope2.js
                        Then in your config change one of the module names from MMM-horoscope to MMM-horoscope2
                        Now reboot the MM2
                        If it doesn’t work, delete the copied folder, change your config back and wait for morozgrafix
                        M 3 Replies Last reply Reply Quote 0
                          Maxzovirax @broberg
                          @broberg Good idea, should have thought of that myself :-) , will give it a go and tell
                            Maxzovirax @broberg
                            @broberg That does it … but would still be nicer in a single module… Thanks :-) my girls will be happy
                              Maxzovirax @broberg
                              @broberg also you need to change the css file to the same module name ref. otherwize the format of the second horoscope will not look nice !
                              • I Offline
                                Iseknutz @morozgrafix
                                @morozgrafix I found this thread while I’m searching for some possibilities to show a German horoscope. I tried to reuse the newsfeed module, but javascript is not my friend ;) I found a source to a German rss feed at t-online. Now I cant post the link, the forum marks it as spam. Are you interested, can I send you the link via PM?
                                Mykle1M morozgrafixM 2 Replies Last reply Reply Quote 0
                                  Mykle1 Project Sponsor Module Developer @Iseknutz
                                  @Iseknutz said in MMM-horoscope - daily horoscope:
                                  Did you try adding it to the config entry of the newsfeed module? If the link is to an .ics file then there is a strong possibility that it will work, assuming the ics link is valid.
                                  Try adding this to your config entry for calendar, above or below the default
                                  symbol: "calendar-check-o ",
                                  url: "webcal://www.YOUR-LINK.com/blahblah/ical/The-ICS-FILE-NAME.ics"
                                  I 1 Reply Last reply Reply Quote 1
                                    morozgrafix Moderator @Iseknutz
                                    @Iseknutz I haven’t touched that code in about 9 months. I can certainly look at the URL and see if that can be implemented.
                                    • I Offline
                                      Iseknutz @Mykle1
                                      @Mykle1 Yes, I added it - the Problem is that all horoscopes (zodiacs) are shown. I want only see one of them. It`s a rss-feed (xml).
                                      • I Offline
                                        @morozgrafix I have sent you a PM with the URL. (can’t post it here - the forum marks it as spam)
                                        • WasupDudeW Offline
                                          WasupDude Banned
                                          wow, that’s interesting
                                          • serge cherpyS Offline
                                            serge cherpy
                                            Bonjour j’ ai découver un lien identique a Yahoo Style Horoscopes, pour alimenter votre horoscope en français pourrait on l’ utiliser pour le MMM-horoscope en option ‘’ https://signes.horoscope999.com/zygos.php ‘’ se serait super sympa en Français …
                                            Merci Serge
