    MMM-horoscope - daily horoscope
    25 Posts 11 Posters 25.8k Views 9 Watching
      Maxzovirax @broberg
      @broberg Good idea, should have thought of that myself :-) , will give it a go and tell
        Maxzovirax @broberg
        @broberg That does it … but would still be nicer in a single module… Thanks :-) my girls will be happy
          Maxzovirax @broberg
          @broberg also you need to change the css file to the same module name ref. otherwize the format of the second horoscope will not look nice !
          • I
            Iseknutz @morozgrafix
            @morozgrafix I found this thread while I’m searching for some possibilities to show a German horoscope. I tried to reuse the newsfeed module, but javascript is not my friend ;) I found a source to a German rss feed at t-online. Now I cant post the link, the forum marks it as spam. Are you interested, can I send you the link via PM?
            Mykle1M morozgrafixM 2 Replies Last reply
            • Mykle1M
              Mykle1 Project Sponsor Module Developer @Iseknutz
              @Iseknutz said in MMM-horoscope - daily horoscope:
              Did you try adding it to the config entry of the newsfeed module? If the link is to an .ics file then there is a strong possibility that it will work, assuming the ics link is valid.
              Try adding this to your config entry for calendar, above or below the default
              symbol: "calendar-check-o ",
              url: "webcal://www.YOUR-LINK.com/blahblah/ical/The-ICS-FILE-NAME.ics"
              I 1 Reply Last reply
              • morozgrafixM
                morozgrafix Moderator @Iseknutz
                @Iseknutz I haven’t touched that code in about 9 months. I can certainly look at the URL and see if that can be implemented.
                • I
                  Iseknutz @Mykle1
                  @Mykle1 Yes, I added it - the Problem is that all horoscopes (zodiacs) are shown. I want only see one of them. It`s a rss-feed (xml).
                  • I
                    @morozgrafix I have sent you a PM with the URL. (can’t post it here - the forum marks it as spam)
                    • WasupDudeW
                      WasupDude Banned
                      wow, that’s interesting
                      • serge cherpyS
                        serge cherpy
                        Bonjour j’ ai découver un lien identique a Yahoo Style Horoscopes, pour alimenter votre horoscope en français pourrait on l’ utiliser pour le MMM-horoscope en option ‘’ https://signes.horoscope999.com/zygos.php ‘’ se serait super sympa en Français …
                        Merci Serge
