    MMM-horoscope - daily horoscope
    25 Posts 11 Posters 25.5k Views 9 Watching
      broberg Project Sponsor @Maxzovirax
      @Maxzovirax A quick fix might be to
      Copy the MMM-horoscope folder and rename it to MMM-horoscope2
      Open the MMM-horoscope.js file and change the lineModule.register("MMM-horoscope",{
      to Module.register("MMM-horoscope2",{
      Save it, and then rename MMM-horoscope.js to MMM-horoscope2.js
      Then in your config change one of the module names from MMM-horoscope to MMM-horoscope2
      Now reboot the MM2
      If it doesn’t work, delete the copied folder, change your config back and wait for morozgrafix
      M 3 Replies Last reply Reply Quote 0
        Maxzovirax @broberg
        @broberg Good idea, should have thought of that myself :-) , will give it a go and tell
          Maxzovirax @broberg
          @broberg That does it … but would still be nicer in a single module… Thanks :-) my girls will be happy
            Maxzovirax @broberg
            @broberg also you need to change the css file to the same module name ref. otherwize the format of the second horoscope will not look nice !
            • I Offline
              Iseknutz @morozgrafix
              @morozgrafix I found this thread while I’m searching for some possibilities to show a German horoscope. I tried to reuse the newsfeed module, but javascript is not my friend ;) I found a source to a German rss feed at t-online. Now I cant post the link, the forum marks it as spam. Are you interested, can I send you the link via PM?
              Mykle1M morozgrafixM 2 Replies Last reply Reply Quote 0
                Mykle1 Project Sponsor Module Developer @Iseknutz
                @Iseknutz said in MMM-horoscope - daily horoscope:
                Did you try adding it to the config entry of the newsfeed module? If the link is to an .ics file then there is a strong possibility that it will work, assuming the ics link is valid.
                Try adding this to your config entry for calendar, above or below the default
                symbol: "calendar-check-o ",
                url: "webcal://www.YOUR-LINK.com/blahblah/ical/The-ICS-FILE-NAME.ics"
                I 1 Reply Last reply Reply Quote 1
                • morozgrafixM Offline
                  morozgrafix Moderator @Iseknutz
                  @Iseknutz I haven’t touched that code in about 9 months. I can certainly look at the URL and see if that can be implemented.
                  • I Offline
                    Iseknutz @Mykle1
                    @Mykle1 Yes, I added it - the Problem is that all horoscopes (zodiacs) are shown. I want only see one of them. It`s a rss-feed (xml).
                    • I Offline
                      @morozgrafix I have sent you a PM with the URL. (can’t post it here - the forum marks it as spam)
                      • WasupDudeW Offline
                        WasupDude Banned
                        wow, that’s interesting
                        • serge cherpyS Offline
                          serge cherpy
                          Bonjour j’ ai découver un lien identique a Yahoo Style Horoscopes, pour alimenter votre horoscope en français pourrait on l’ utiliser pour le MMM-horoscope en option ‘’ https://signes.horoscope999.com/zygos.php ‘’ se serait super sympa en Français …
                          Merci Serge
