    MMM-horoscope - daily horoscope
    25 Posts 11 Posters 26.0k Views 9 Watching
    • morozgrafixM
      morozgrafix Moderator @Maxzovirax
      @Maxzovirax Good point. It will not work with 2 modules running simultaneously because they both will pick up same broadcast message from node_helper.js. I wonder if modification of the module to allow display of multiple horoscope predictions in the same module would be sufficient. It will take a bit of time to do that modification and I’m going on a small vacation tomorrow. I will think on how it can be addressed. Thanks for bringing it up.
      M 1 Reply Last reply
        Maxzovirax @morozgrafix
        @morozgrafix Thank you for you quick reply… Verry nice of you to have a look at it, will look forward to a solution… have a nice holiday (going skiing?)
        brobergB 1 Reply Last reply
        • brobergB
          broberg Project Sponsor @Maxzovirax
          @Maxzovirax A quick fix might be to
          Copy the MMM-horoscope folder and rename it to MMM-horoscope2
          Open the MMM-horoscope.js file and change the lineModule.register("MMM-horoscope",{
          to Module.register("MMM-horoscope2",{
          Save it, and then rename MMM-horoscope.js to MMM-horoscope2.js
          Then in your config change one of the module names from MMM-horoscope to MMM-horoscope2
          Now reboot the MM2
          If it doesn’t work, delete the copied folder, change your config back and wait for morozgrafix
          M 3 Replies Last reply
            Maxzovirax @broberg
            @broberg Good idea, should have thought of that myself :-) , will give it a go and tell
              Maxzovirax @broberg
              @broberg That does it … but would still be nicer in a single module… Thanks :-) my girls will be happy
                Maxzovirax @broberg
                @broberg also you need to change the css file to the same module name ref. otherwize the format of the second horoscope will not look nice !
                • I
                  Iseknutz @morozgrafix
                  @morozgrafix I found this thread while I’m searching for some possibilities to show a German horoscope. I tried to reuse the newsfeed module, but javascript is not my friend ;) I found a source to a German rss feed at t-online. Now I cant post the link, the forum marks it as spam. Are you interested, can I send you the link via PM?
                  Mykle1M morozgrafixM 2 Replies Last reply
                  • Mykle1M
                    Mykle1 Project Sponsor Module Developer @Iseknutz
                    @Iseknutz said in MMM-horoscope - daily horoscope:
                    Did you try adding it to the config entry of the newsfeed module? If the link is to an .ics file then there is a strong possibility that it will work, assuming the ics link is valid.
                    Try adding this to your config entry for calendar, above or below the default
                    symbol: "calendar-check-o ",
                    url: "webcal://www.YOUR-LINK.com/blahblah/ical/The-ICS-FILE-NAME.ics"
                    I 1 Reply Last reply
                    • morozgrafixM
                      morozgrafix Moderator @Iseknutz
                      @Iseknutz I haven’t touched that code in about 9 months. I can certainly look at the URL and see if that can be implemented.
                      • I
                        Iseknutz @Mykle1
                        @Mykle1 Yes, I added it - the Problem is that all horoscopes (zodiacs) are shown. I want only see one of them. It`s a rss-feed (xml).
                        • I
                          @morozgrafix I have sent you a PM with the URL. (can’t post it here - the forum marks it as spam)
                          • WasupDudeW
                            WasupDude Banned
                            wow, that’s interesting
                            • serge cherpyS
                              serge cherpy
                              Bonjour j’ ai découver un lien identique a Yahoo Style Horoscopes, pour alimenter votre horoscope en français pourrait on l’ utiliser pour le MMM-horoscope en option ‘’ https://signes.horoscope999.com/zygos.php ‘’ se serait super sympa en Français …
                              Merci Serge
