Solved Creating a module to display daily horoscopes
so i fixed it and added it the the java beautifier link and thenadded it back to my config.js folder and rebootbut still black screen.
cant use npm start
is it because im using pm2 to autostart my mirror? -
@pflnpi0305 if you are using pm2 then you can restart mm with
pm2 restart mm
, to stop it you would runpm2 stop mm
, to list processes managed by pm2 you would dopm2 list
and to start you would runpm2 start mm
If you are still have issues, post your latest version of
config.js
here again. Are you getting any errors? -
so i also dropped my config in jshint.comand and javascriptbeautifier.com and all is well…i dont know what im missing. if i remove the horoscope everything works well but if i have it then it wont work.
var config = { port: 8080, ipWhitelist: [ "127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.1.1/24" ], language: "en", timeFormat: 12, units: "imperial", modules: [ { module: "MMM-Admin-Interface" }, { module: "alert" }, { module: "updatenotification", position: "top_bar" }, { module: "clock", position: "top_left" }, { module: "calendar", header: "MY CALENDAR", position: "top_left", config: { fetchInterval: 1 * 60 * 1000, calendars: [ { symbol: "calendar-check-o ", url: "webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics" }, { url:"https://calendar.google.com/calendar/ical/5ddp1drsb3mib0a6piof8h0f8s%40group.calendar.google.com/private-xxxxxxxxxxxxxxx/basic.ics" } ] } }, { module: "compliments", position: "lower_third" }, { module: "currentweather", position: "top_right", config: { units: "imperial", location: "FONTANA/CA", locationID: "", appid: "xxxxxxxxxxxxxx" } }, { module: "MMM-Remote-Control" }, { module: "MMM-WunderGround", position: "top_right", config: { apikey: "xxxxxxx", pws: "CA/FONTANA", hourly: "1", fctext: "1", fcdaycount: "5", fcdaystart: "0", hourlyinterval: "3", hourlycount: "2", alerttime: 10000, alerttruncatestring: "english:", roundTmpDecs: 1, UseCardinals: 0, layout: "horizontal", sysstat: 0 } }, { module: "MMM-Globe", position: "center", config: { style: "geoColor", imageSize: 300, ownImagePath: "", updateInterval: 10 * 60 * 1000 } }, { module: "MMM-horoscope", position: "bottom_right", config: { sign: "aries" } }, { module: "newsfeed", position: "bottom_bar", config: { feeds: [ { title: "Google News", url: "https://news.google.com/news?cf=all&hl=en&pz=1&ned=us&output=rss" }, { title: "New York Times", url: "http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml" }, { title: "BBC Sci-Tech", url: "http://feeds.bbci.co.uk/news/video_and_audio/technology/rss.xml?edition=uk" } ], showSourceTitle: true, showPublishDate: true, maxNewsItems: 0, updateInterval: 10 * 1000, reloadInterval: 2 * 60 * 1000 } } ] }; if ("undefined" !== typeof module) module.exports = config;
@pflnpi0305 Do you see any errors in the console log when you run it start the mirror with
npm start dev
command? Also are you running off the master branch or dev?
We can try to start eliminating things out to narrow down what is causing the black screen for you.Can you try this config with only horoscope module:
/* Magic Mirror Config Sample * * By Michael Teeuw http://michaelteeuw.nl * MIT Licensed. */ var config = { port: 8080, ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], language: 'en', timeFormat: 24, units: 'metric', modules: [ { module: 'MMM-horoscope', position: 'bottom_right', // This can be any of the regions. config: { // See ‘Configuration options’ for additional options and more information. sign: 'aries', // Zodiac sign } }, ] }; /*************** DO NOT EDIT THE LINE BELOW ***************/ if (typeof module !== 'undefined') {module.exports = config;}
Also can you please double check that
MMM-horoscope
and contents exist under~/MagicMirror/modules
directory? (I know I’m asking for obvious things, just trying to get some more info about your installation). -
thats the issue it doesnt exsist in there… how do i clone the git via ssh
@pflnpi0305 It will not work if you don’t have a copy of the module installed locally, black screen is there because MM is attempting to load JS files for the module from the directory that doesn’t exist. You need to run this in terminal while connected to your RasPi (directly or via SSH).
cd ~/MagicMirror/modules git clone https://github.com/morozgrafix/MMM-horoscope.git
After that you would need to restart MM node process in order it to pickup new
node_helper
for horoscope module.Thanks
@pflnpi0305 said in Creating a module to display daily horoscopes:
Mh, you are right. The readme on github doesn’t state how to do this. Maybe @morozgrafix could add this, even though the process is always the same.
If you go to github, you see this:
- click on “clone or download”
- copy the url or click on the icon next to it
cd ~/MagicMirror/modules git clone https://github.com/morozgrafix/MMM-horoscope.git cd MMM-horoscope npm install
After that you update your config.js file, restart your magic mirror and should be fine
edit: oh, morozgrafix was faster
@yawns Thanks! I just added a small bit related to installation steps to the README.
lol thank you guys i should have thought of it but idk why it just slipped my mind i followed and i thought hmmm i need to close i think ahah…thanks i love this forum and all the help here.
