    Creating a module to display daily horoscopes
    Scheduled Pinned Locked Moved Solved Development
    26 Posts 7 Posters 23.5k Views 6 Watching
      pflnpi0305
      i add this and get black screen only when i add the horoscope. maybe i dont know hot to install it lol. am i doing something wrong? any help is appreciated.
      /* Magic Mirror Config Sample
       * MIT Licensed.
      var config = {
      	port: 8080,
      	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", ],
      	language: 'en',
      	timeFormat: 12,
      	units: 'imperial',
      			module: 'alert',
      			module: "updatenotification",
      			position: "top_bar"
      			module: 'clock',
      			position: 'top_left'
      			module: 'calendar',
      			header: 'MY CALENDAR',
      			position: 'top_left',
      			fetchInterval: 1 * 60 * 1000,
      						symbol: 'calendar-check-o ',
                                                      url: 'https://calendar.google.com/calendar/ical/5ddp1drsb3mib0a6piof8h0f8s%40group.calendar.google.com/private-xxxxxxxxxxxxxxx'
      			module: 'compliments',
      			position: 'lower_third'
      			module: 'MMM-horoscope',
          			position: 'bottom_right',
            				sign: 'aries', // Zodiac sign
      		        module: 'currentweather',
      			position: 'top_right',
      				units: 'imperial',
      				locationID: '',  //ID from http://www.openweathermap.org
      				appid: 'xxxxxxxxxxxxxxxx'
      			module: 'MMM-Remote-Control'
      			module: 'MMM-WunderGround',
             				 apikey: 'xxxxxxxxxxxxxxxx', // private; don't share!
              			 pws: 'CA/FONTANA',
              			 hourly: '1',
             			         fctext: '1',
              			 fcdaycount: "5",
              			 fcdaystart: "0",
              			 hourlyinterval: "3",
              			 hourlycount: "2",
              			 alerttime: 10000,
              			 alerttruncatestring: "english:",
          			         roundTmpDecs: 1,
          				 UseCardinals: 0,
          				 layout: "horizontal",
          				sysstat: 0
      			module: 'newsfeed',
      			position: 'bottom_bar',
      				feeds: [
      						title: "Google News",
      						url: "https://news.google.com/news?cf=all&hl=en&pz=1&ned=us&output=rss"
      						title: "New York Times",
      	                    			url:       "http://www.nytimes.com/services
                                                   /xml/rss/nyt/HomePage.xml"
              				        title: "BBC Sci-Tech",
      						url: "http://feeds.bbci.co.uk/news/video_and_audio/technology/rss.xml?edition=uk"
      				showSourceTitle: true,
      				showPublishDate: true,
      				maxNewsItems: 0,
      				updateInterval: 10 * 1000,
      				reloadInterval:  2 * 60 * 1000
      morozgrafixM 1 Reply Last reply
      • cowboysdudeC
        @pflnpi0305
        Run that through this: http://javascriptbeautifier.com/
        to clean that up… lots of spaces in there… may not be the problem but it could become a problem at some point and it’s easier to read through it when it’s formatted ;)
        But I do believe your problem is right here:
        url: “http://www.nytimes.com/services
        /xml/rss/nyt/HomePage.xml”
        That’s not valid… needs to be:
        url: “http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml”
        Reply Quote 2
        • morozgrafixM
          morozgrafix Moderator @pflnpi0305
          @pflnpi0305 I believe that @cowboysdude is correct about that line spilling over. It needs to be on one line. When in doubt you can always paste your config.js at http://jshint.com/ and see if there are any errors (one warning about undefined variable module is ok)
          • cowboysdudeC
            cowboysdude Module Developer @morozgrafix
            @morozgrafix said in Creating a module to display daily horoscopes:
            Home away from home LOL AND off topic but Thanks and congrats on being a mod :)
              pflnpi0305
              so i fixed it and added it the the java beautifier link and thenadded it back to my config.js folder and rebootbut still black screen.
              cant use npm start
              is it because im using pm2 to autostart my mirror?
              • morozgrafixM
                @pflnpi0305 if you are using pm2 then you can restart mm with pm2 restart mm, to stop it you would run pm2 stop mm, to list processes managed by pm2 you would do pm2 list and to start you would run pm2 start mm
                If you are still have issues, post your latest version of config.js here again. Are you getting any errors?
                  pflnpi0305
                  so i also dropped my config in jshint.comand and javascriptbeautifier.com and all is well…i dont know what im missing. if i remove the horoscope everything works well but if i have it then it wont work.
                                var config = {
                  port: 8080,
                  ipWhitelist: [ "127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.1.1/24" ],
                  language: "en",
                  timeFormat: 12,
                  units: "imperial",
                  modules: [ {
                      module: "MMM-Admin-Interface"
                      module: "alert"
                      position: "top_bar"
                      module: "clock",
                      position: "top_left"
                      header: "MY CALENDAR",
                          calendars: [ {
                              symbol: "calendar-check-o ",
                              url:"https://calendar.google.com/calendar/ical/5ddp1drsb3mib0a6piof8h0f8s%40group.calendar.google.com/private-xxxxxxxxxxxxxxx/basic.ics"
                      module: "compliments",
                      position: "lower_third"
                      module: "currentweather",
                          units: "imperial",
                          locationID: "",
                          appid: "xxxxxxxxxxxxxx"
                      module: "MMM-Remote-Control"
                      module: "MMM-WunderGround",
                          apikey: "xxxxxxx",
                          pws: "CA/FONTANA",
                          hourly: "1",
                          fctext: "1",
                          fcdaycount: "5",
                          fcdaystart: "0",
                          hourlycount: "2",
                          alerttime: 10000,
                          roundTmpDecs: 1,
                          UseCardinals: 0,
                          sysstat: 0
                      module: "MMM-Globe",
                      position: "center",
                          style: "geoColor",
                          imageSize: 300,
                          ownImagePath: "",
                          updateInterval: 10 * 60 * 1000
                      module: "MMM-horoscope",
                      position: "bottom_right",
                          sign: "aries"
                      module: "newsfeed",
                      position: "bottom_bar",
                          feeds: [ {
                          maxNewsItems: 0,
                  if ("undefined" !== typeof module) module.exports = config;
                  • morozgrafixM
                    @pflnpi0305 Do you see any errors in the console log when you run it start the mirror with npm start dev command? Also are you running off the master branch or dev?
                    We can try to start eliminating things out to narrow down what is causing the black screen for you.
                    Can you try this config with only horoscope module:
                     * MIT Licensed.
                    var config = {
                    	port: 8080,
                    	language: 'en',
                    	timeFormat: 24,
                    	units: 'metric',
                    			position: 'bottom_right', // This can be any of the regions.
                    				// See ‘Configuration options’ for additional options and more information.
                    Also can you please double check that MMM-horoscope and contents exist under ~/MagicMirror/modules directory? (I know I’m asking for obvious things, just trying to get some more info about your installation).
                      pflnpi0305
                      thats the issue it doesnt exsist in there… how do i clone the git via ssh
                      Y 1 Reply Last reply
                      • morozgrafixM
                        @pflnpi0305 It will not work if you don’t have a copy of the module installed locally, black screen is there because MM is attempting to load JS files for the module from the directory that doesn’t exist. You need to run this in terminal while connected to your RasPi (directly or via SSH).
                        cd ~/MagicMirror/modules
                        git clone https://github.com/morozgrafix/MMM-horoscope.git
                        After that you would need to restart MM node process in order it to pickup new node_helper for horoscope module.
                        • Y
                          yawns Moderator @pflnpi0305
                          @pflnpi0305 said in Creating a module to display daily horoscopes:
                          Mh, you are right. The readme on github doesn’t state how to do this. Maybe @morozgrafix could add this, even though the process is always the same.
                          If you go to github, you see this:
                          1. click on “clone or download”
                          2. copy the url or click on the icon next to it
                          cd MMM-horoscope
                          npm install
                          After that you update your config.js file, restart your magic mirror and should be fine
                          edit: oh, morozgrafix was faster
                          • morozgrafixM
                            morozgrafix Moderator @yawns
                            @yawns Thanks! I just added a small bit related to installation steps to the README.
                              pflnpi0305
                              lol thank you guys i should have thought of it but idk why it just slipped my mind i followed and i thought hmmm i need to close i think ahah…thanks i love this forum and all the help here.
