Probleme mit wiederkehrenden Terminen
you have got a mail
@stylemaster received. Just arrived destination for today. Will review a little later
hallo, ich habe jetzt mir die .ics datei nochmal genau angeschaut.
wenn ich vom Synology Kalender mir eine .ics runter lade finde ich die “RRULE” bei der ics. Habe jetzt herrausgefunden wenn ich in der MMM-CalDAV config
“expand: false”hinzugüge ist die RRULE da,
jetzt habe ich aber ein nächstes Problem
“0|MagicMirror | [2026-01-31 08:28:32.793] [ERROR] [calendar] Moment Timezone has no data for W. Europe Standard Time. See http://momentjs.com/timezone/docs/#/data-loading/.”
warum das jetzt
Mit freundlichen GrüßenModerator edit: English
Hello, I’ve now taken another close look at the .ics file. When I download an .ics file from the Synology calendar, I find the “RRULE” in the .ics file.
I’ve now discovered that if I add “expand: false” to the MMM-CalDAV configuration, the RRULE is present.However, I now have another problem:
“0|MagicMirror | [2026-01-31 08:28:32.793] [ERROR] [calendar] Moment Timezone has no data for W. Europe Standard Time. See http://momentjs.com/timezone/docs/#/data-loading/.” -
@stylemaster I see.
@kristjanesperanto do you have any guidance here.
I see that tz string in the windows lookup table in node-ical
He is running MagicMirror 2.34.0 -
@stylemaster is the calendar displaying? Others have reported similar but calendar display is ok
It’s a known limitation. MMM-Calendar can’t parse some Synology recurring RRULEs, so they don’t show even though they’re in the .ics file.
@eddiebrok what is mmm-Calendar? You mean the built in calendar module?
I built the lookup table 5 yrs ago for this problem in node-ical
There have been some recent significant updates to solve other problems , but not by me.
as I recall, There were test cases to detect this problem if it occurred again
Hy,
meine wiederholende einträge sind jetzt im calendermodul enthalten und auch die RRULE in der ics sind da was ich jetzt überhaupt nicht verstehe ist
die norm. Kalendereinträge passen (mit urzeit und so weiter) bei den wiederkehrenden passt die zeit um eine std nicht.
Auf der Synology ist die Zeitzone richtig eingestellt. Bei den wiederkehrenden Termine auch und auf dem MM ist auch die richtige zeit vorhanden.
Hast du noch eine Idee wie wir das fixen können
lg
stylemaster
@stylemaster Sie führen MagicMirror in einem Docker-Container aus. Können Sie überprüfen, ob die korrekte Zeitzone in der Docker-Compose-Datei eingestellt ist?
Kalender wir auf der synology bereitgestellt, MM auf einen Raspberry Zeitzone auf den Pi passt (sonst wären die andere kalendereibträge ja auch falsch )
