    Default Weather Module Stuck on loading.
    28 Posts 3 Posters 4.3k Views 4 Watching
      sdetweil @fnmuffinman
      @fnmuffinman I did, sorry been traveling.
      Can you Open the developers window
      ctrl-shift-I
      Select the console tab
      Add weath to the filter field
      F 1 Reply Last reply
      • F
        fnmuffinman @sdetweil
        @sdetweil No worries, I figured you were probably busy! Here is what comes up
          @fnmuffinman ok, a little more debug
          grep nunj package.json
          should return
          		"nunjucks": "^3.2.4",
          then
          cd node_modules
          ls nunjucks -laF
          should return (I am on mac at the moment, with MagicMirror just installed, so dates will be different
          drwxr-xr-x   10 sam  staff    320 Feb  3 08:20 ./
          drwxr-xr-x  685 sam  staff  21920 Feb  3 08:21 ../
          drwxr-xr-x    4 sam  staff    128 Feb  3 08:20 bin/
          drwxr-xr-x   10 sam  staff    320 Feb  3 08:20 browser/
          -rw-r--r--    1 sam  staff   2309 Feb  3 08:20 index.js
          -rw-r--r--    1 sam  staff   1311 Feb  3 08:20 LICENSE
          drwxr-xr-x    3 sam  staff     96 Feb  3 08:20 node_modules/
          -rw-r--r--    1 sam  staff   3138 Feb  3 08:20 package.json
          -rw-r--r--    1 sam  staff   2127 Feb  3 08:20 README.md
          drwxr-xr-x   23 sam  staff    736 Feb  3 08:20 src/
          then I want to redo the MagicMirror npm install
          rm -rf node_modules
          npm install
          then restart MagicMirror however you do it…
          • F
            @sdetweil alright so i ran those commands. when I got to
            ls nunjucks -laF
            It returned that directory did not exist, which i would imagine is part of my issue. I then continued with the rest of the commands, then I got this error.
            For context, recently I saw notifications on my mirror stating some modules needed to be updated. I ran through the docs for updating those but it’s possible I messed that up and caused myself a bigger problem here.
              @fnmuffinman ah…
              Node 23 is bad , so we won’t install there
              So try either of these commands
              n —version
              nvm —version
              Do either exist?
              • F
                @sdetweil it appears neither do
                  @fnmuffinman good, thx
                  Do this
                  sudo npm install -g n
                  sudo n 22.21.1
                  hash -r
                  node -v
                  Should show v 22.21.1
                  If not stop and advise
                  If ok
                  Then do
                  npm install
                  Then start MagicMirror
                  • F
                    @sdetweil IT WORKS!! I cannot thank you enough for your time and patience with the help on this. I have learned alot from walking through this troubleshooting with you. Are you able to tell me what I may or may not have done wrong to cause it to stop working?
                      @fnmuffinman great news!! Thanks for the feedback
                      As for what happened
                      You upgraded nodejs at some point
                      And didn’t catch the npm install error message
                      So you had the new code (git pull) but not the runtime libs it needed
                      I recommend using my upgrade script in the future
                      • F
                        @sdetweil gotcha! I would love to use a script instead of breaking things again lol where can i find your upgrade script and what does it all entail? does it upgrade Magic mirror and the modules or just MM itself?
                          @fnmuffinman the links are in the MagicMirror documentation
                          It does only MagicMirror
                          • F
                            @sdetweil fantastic. Thanks again for all the help!!
