    Default Weather Module Stuck on loading.
    28 Posts 3 Posters 4.3k Views 4 Watching
    • F
      fnmuffinman @sdetweil
      @sdetweil No worries, I figured you were probably busy! Here is what comes up
        sdetweil @fnmuffinman
        @fnmuffinman ok, a little more debug
        grep nunj package.json
        should return
        		"nunjucks": "^3.2.4",
        then
        cd node_modules
        ls nunjucks -laF
        should return (I am on mac at the moment, with MagicMirror just installed, so dates will be different
        drwxr-xr-x   10 sam  staff    320 Feb  3 08:20 ./
        drwxr-xr-x  685 sam  staff  21920 Feb  3 08:21 ../
        drwxr-xr-x    4 sam  staff    128 Feb  3 08:20 bin/
        drwxr-xr-x   10 sam  staff    320 Feb  3 08:20 browser/
        -rw-r--r--    1 sam  staff   2309 Feb  3 08:20 index.js
        -rw-r--r--    1 sam  staff   1311 Feb  3 08:20 LICENSE
        drwxr-xr-x    3 sam  staff     96 Feb  3 08:20 node_modules/
        -rw-r--r--    1 sam  staff   3138 Feb  3 08:20 package.json
        -rw-r--r--    1 sam  staff   2127 Feb  3 08:20 README.md
        drwxr-xr-x   23 sam  staff    736 Feb  3 08:20 src/
        then I want to redo the MagicMirror npm install
        rm -rf node_modules
        npm install
        then restart MagicMirror however you do it…
        F 1 Reply Last reply
        • F
          @sdetweil alright so i ran those commands. when I got to
          ls nunjucks -laF
          It returned that directory did not exist, which i would imagine is part of my issue. I then continued with the rest of the commands, then I got this error.
          For context, recently I saw notifications on my mirror stating some modules needed to be updated. I ran through the docs for updating those but it’s possible I messed that up and caused myself a bigger problem here.
            @fnmuffinman ah…
            Node 23 is bad , so we won’t install there
            So try either of these commands
            n —version
            nvm —version
            Do either exist?
            • F
              @sdetweil it appears neither do
                @fnmuffinman good, thx
                Do this
                sudo npm install -g n
                sudo n 22.21.1
                hash -r
                node -v
                Should show v 22.21.1
                If not stop and advise
                If ok
                Then do
                npm install
                Then start MagicMirror
                • F
                  @sdetweil IT WORKS!! I cannot thank you enough for your time and patience with the help on this. I have learned alot from walking through this troubleshooting with you. Are you able to tell me what I may or may not have done wrong to cause it to stop working?
                    @fnmuffinman great news!! Thanks for the feedback
                    As for what happened
                    You upgraded nodejs at some point
                    And didn’t catch the npm install error message
                    So you had the new code (git pull) but not the runtime libs it needed
                    I recommend using my upgrade script in the future
                    • F
                      @sdetweil gotcha! I would love to use a script instead of breaking things again lol where can i find your upgrade script and what does it all entail? does it upgrade Magic mirror and the modules or just MM itself?
                        @fnmuffinman the links are in the MagicMirror documentation
                        It does only MagicMirror
                        • F
                          @sdetweil fantastic. Thanks again for all the help!!
