    Default Weather Module Stuck on loading.
    28 Posts 3 Posters 3.6k Views 4 Watching
      sdetweil @fnmuffinman
      @fnmuffinman these modules use a helper so debug info is where you npm start , IF the author presents logging
      • F Offline
        fnmuffinman @sdetweil
        @sdetweil alrighty so I got a bit further after a bit more testing and digging into the pm2 logs so here is where I am at.
        I am using this module: https://github.com/Tom-Hirschberger/MMM-OpenWeatherForecast
        Here is a screenshot of the current error I am seeing in the dev tools
        I was seeing a 401 Unauthorized error for a bit but figured out the 3.0 API call thing. I did test the URL from the website with my lat and long with the API key it works. I no longer see those errors in my pm2 logs on the mirror. Here is a screenshot of my current config in the config.js as well
        Sorry didn’t want to dox or give my api key :) also as further troubleshooting, here is a screenshot of the api.openweathermap.org URL to show it does work
        appreciate the help! my first time truly digging into why a module isn’t working. I have alot more respect for coders lol
          @fnmuffinman did you do the npm install in the module folder?
          • F Offline
            @sdetweil I was pretty sure I did but I ran it again and rebooted the mirror to the same results. Still the same error as the above screenshot in the dev tools console. Not sure if it matters, but I do have the mirror booting headless. I don’t remember exactly but it’s part of the startup script so when I reboot the pi, it automatically runs MM and loads it onscreen
              @fnmuffinman what do you mean headless?
              If no display here, you need to do
              npm run server
              And access from somewhere else
              Make sure to enable config.js to allow other machine access
              • F Offline
                @sdetweil sorry wrong terminology. It is running on a pi connected to a display. I meant headless in I don’t have peripherals on it, just ssh into it from my pc
                  @fnmuffinman how did you install MagicMirror
                  What version are you running
                  grep version package.json
                  • F Offline
                    Sorry for the delay!
                    • F Offline
                      fnmuffinman @fnmuffinman
                      @sdetweil Hi, just checking in to see if you saw my last reply above! If not, I was going to create a new thread with all the troubleshooting you have graciously help me out with to start from there
                        @fnmuffinman I did, sorry been traveling.
                        Can you Open the developers window
                        ctrl-shift-I
                        Select the console tab
                        Add weath to the filter field
                        • F Offline
                          @sdetweil No worries, I figured you were probably busy! Here is what comes up
                            @fnmuffinman ok, a little more debug
                            grep nunj package.json
                            should return
                            		"nunjucks": "^3.2.4",
                            then
                            cd node_modules
                            ls nunjucks -laF
                            should return (I am on mac at the moment, with MagicMirror just installed, so dates will be different
                            drwxr-xr-x   10 sam  staff    320 Feb  3 08:20 ./
                            drwxr-xr-x  685 sam  staff  21920 Feb  3 08:21 ../
                            drwxr-xr-x    4 sam  staff    128 Feb  3 08:20 bin/
                            drwxr-xr-x   10 sam  staff    320 Feb  3 08:20 browser/
                            -rw-r--r--    1 sam  staff   2309 Feb  3 08:20 index.js
                            -rw-r--r--    1 sam  staff   1311 Feb  3 08:20 LICENSE
                            drwxr-xr-x    3 sam  staff     96 Feb  3 08:20 node_modules/
                            -rw-r--r--    1 sam  staff   3138 Feb  3 08:20 package.json
                            -rw-r--r--    1 sam  staff   2127 Feb  3 08:20 README.md
                            drwxr-xr-x   23 sam  staff    736 Feb  3 08:20 src/
                            then I want to redo the MagicMirror npm install
                            rm -rf node_modules
                            npm install
                            then restart MagicMirror however you do it…
                            • F Offline
                              @sdetweil alright so i ran those commands. when I got to
                              ls nunjucks -laF
                              It returned that directory did not exist, which i would imagine is part of my issue. I then continued with the rest of the commands, then I got this error.
                              For context, recently I saw notifications on my mirror stating some modules needed to be updated. I ran through the docs for updating those but it’s possible I messed that up and caused myself a bigger problem here.
                                @fnmuffinman ah…
                                Node 23 is bad , so we won’t install there
                                So try either of these commands
                                n —version
                                nvm —version
                                Do either exist?
                                F 1 Reply Last reply Reply Quote 1
                                • F Offline
                                  @sdetweil it appears neither do
                                    @fnmuffinman good, thx
                                    Do this
                                    sudo npm install -g n
                                    sudo n 22.21.1
                                    hash -r
                                    node -v
                                    Should show v 22.21.1
                                    If not stop and advise
                                    If ok
                                    Then do
                                    npm install
                                    Then start MagicMirror
                                    • F Offline
                                      @sdetweil IT WORKS!! I cannot thank you enough for your time and patience with the help on this. I have learned alot from walking through this troubleshooting with you. Are you able to tell me what I may or may not have done wrong to cause it to stop working?
                                        @fnmuffinman great news!! Thanks for the feedback
                                        As for what happened
                                        You upgraded nodejs at some point
                                        And didn’t catch the npm install error message
                                        So you had the new code (git pull) but not the runtime libs it needed
                                        I recommend using my upgrade script in the future
                                        • F Offline
                                          @sdetweil gotcha! I would love to use a script instead of breaking things again lol where can i find your upgrade script and what does it all entail? does it upgrade Magic mirror and the modules or just MM itself?
                                            @fnmuffinman the links are in the MagicMirror documentation
                                            It does only MagicMirror
