    Default Weather Module Stuck on loading.
    28 Posts 3 Posters 3.9k Views 4 Watching
    • F Offline
      fnmuffinman @sdetweil
      @sdetweil so after messing around and trying out a new module (might change my problem here) but seems it still won’t load. I am still pretty green at troubleshooting modules so excuse my lack of knowledge here. I have a screenshot of the spot you asked but for the new module:
        sdetweil @fnmuffinman
        @fnmuffinman which module are you using
        git remote -v
        In the module folder
        Tom’s is v3 api only
        The original is v2.5 only
        From Toms version readme
          @fnmuffinman these modules use a helper so debug info is where you npm start , IF the author presents logging
          • F Offline
            @sdetweil alrighty so I got a bit further after a bit more testing and digging into the pm2 logs so here is where I am at.
            I am using this module: https://github.com/Tom-Hirschberger/MMM-OpenWeatherForecast
            Here is a screenshot of the current error I am seeing in the dev tools
            I was seeing a 401 Unauthorized error for a bit but figured out the 3.0 API call thing. I did test the URL from the website with my lat and long with the API key it works. I no longer see those errors in my pm2 logs on the mirror. Here is a screenshot of my current config in the config.js as well
            Sorry didn’t want to dox or give my api key :) also as further troubleshooting, here is a screenshot of the api.openweathermap.org URL to show it does work
            appreciate the help! my first time truly digging into why a module isn’t working. I have alot more respect for coders lol
              @fnmuffinman did you do the npm install in the module folder?
              • F Offline
                @sdetweil I was pretty sure I did but I ran it again and rebooted the mirror to the same results. Still the same error as the above screenshot in the dev tools console. Not sure if it matters, but I do have the mirror booting headless. I don’t remember exactly but it’s part of the startup script so when I reboot the pi, it automatically runs MM and loads it onscreen
                  @fnmuffinman what do you mean headless?
                  If no display here, you need to do
                  npm run server
                  And access from somewhere else
                  Make sure to enable config.js to allow other machine access
                  • F Offline
                    @sdetweil sorry wrong terminology. It is running on a pi connected to a display. I meant headless in I don’t have peripherals on it, just ssh into it from my pc
                      @fnmuffinman how did you install MagicMirror
                      What version are you running
                      grep version package.json
                      • F Offline
                        Sorry for the delay!
                        • F Offline
                          fnmuffinman @fnmuffinman
                          @sdetweil Hi, just checking in to see if you saw my last reply above! If not, I was going to create a new thread with all the troubleshooting you have graciously help me out with to start from there
                            @fnmuffinman I did, sorry been traveling.
                            Can you Open the developers window
                            ctrl-shift-I
                            Select the console tab
                            Add weath to the filter field
                            • F Offline
                              @sdetweil No worries, I figured you were probably busy! Here is what comes up
                                @fnmuffinman ok, a little more debug
                                grep nunj package.json
                                should return
                                		"nunjucks": "^3.2.4",
                                then
                                cd node_modules
                                ls nunjucks -laF
                                should return (I am on mac at the moment, with MagicMirror just installed, so dates will be different
                                drwxr-xr-x   10 sam  staff    320 Feb  3 08:20 ./
                                drwxr-xr-x  685 sam  staff  21920 Feb  3 08:21 ../
                                drwxr-xr-x    4 sam  staff    128 Feb  3 08:20 bin/
                                drwxr-xr-x   10 sam  staff    320 Feb  3 08:20 browser/
                                -rw-r--r--    1 sam  staff   2309 Feb  3 08:20 index.js
                                -rw-r--r--    1 sam  staff   1311 Feb  3 08:20 LICENSE
                                drwxr-xr-x    3 sam  staff     96 Feb  3 08:20 node_modules/
                                -rw-r--r--    1 sam  staff   3138 Feb  3 08:20 package.json
                                -rw-r--r--    1 sam  staff   2127 Feb  3 08:20 README.md
                                drwxr-xr-x   23 sam  staff    736 Feb  3 08:20 src/
                                then I want to redo the MagicMirror npm install
                                rm -rf node_modules
                                npm install
                                then restart MagicMirror however you do it…
                                • F Offline
                                  @sdetweil alright so i ran those commands. when I got to
                                  ls nunjucks -laF
                                  It returned that directory did not exist, which i would imagine is part of my issue. I then continued with the rest of the commands, then I got this error.
                                  For context, recently I saw notifications on my mirror stating some modules needed to be updated. I ran through the docs for updating those but it’s possible I messed that up and caused myself a bigger problem here.
                                    @fnmuffinman ah…
                                    Node 23 is bad , so we won’t install there
                                    So try either of these commands
                                    n —version
                                    nvm —version
                                    Do either exist?
                                    F 1 Reply Last reply Reply Quote 1
                                    • F Offline
                                      @sdetweil it appears neither do
                                        @fnmuffinman good, thx
                                        Do this
                                        sudo npm install -g n
                                        sudo n 22.21.1
                                        hash -r
                                        node -v
                                        Should show v 22.21.1
                                        If not stop and advise
                                        If ok
                                        Then do
                                        npm install
                                        Then start MagicMirror
                                        • F Offline
                                          @sdetweil IT WORKS!! I cannot thank you enough for your time and patience with the help on this. I have learned alot from walking through this troubleshooting with you. Are you able to tell me what I may or may not have done wrong to cause it to stop working?
                                            @fnmuffinman great news!! Thanks for the feedback
                                            As for what happened
                                            You upgraded nodejs at some point
                                            And didn’t catch the npm install error message
                                            So you had the new code (git pull) but not the runtime libs it needed
                                            I recommend using my upgrade script in the future
