    showing start and end time instead of in x hours
    calendar
    6 Posts 2 Posters 2.1k Views 2 Watching
      com1cedric
      hello, is it possible in mmm calendar to show the start time (e.g 16:00), like it is already the case for the following days, and maybe the end time instead of “in 2 hours”?
      Thanks for your opinion and help if you can.
      Greatings.
        sdetweil @com1cedric
        @com1cedric I think this is relative/setrelative. See the doc on this settings
        C 1 Reply Last reply
          com1cedric @sdetweil
          @sdetweil : thank you very much, very appreciated!
            com1cedric @com1cedric
            hello @sdetweil
            I tested what you proposed, and was not effective.
            I found this other interesting option
            but it was not better.
            The question you could maybe help me to understand would be : why do the calendar suddenly changes the display of “today at hh.mm” to “in xx hours / minutes”?
            I searched in the code how to erase this change but did not find it. Should I place a pull request on the repository of the calendar on Gibhub?
            Thanks in advance and have a great sunny day.
            Cédric
              @com1cedric the setting is getRelative
              Should be becomeRelative or goRelative
              This is useful when an event gets close, you mostly don’t want it saying ‘today’
                com1cedric
                wow, you’re definitively better than ChatGpt @sdetweil !
