    PIR / MQTT - Presence sensor(s) revived
    43 Posts 7 Posters 11.1k Views 9 Watching
      rkorell Module Developer @htilburgs
      Dear @htilburgs,
      Thanks for the detailed logs and config — very helpful!
      Issue 1 — resolved as you found: wlr-randr instead of xrandr on Wayland. ✓
      Issue 3 (confusing [MMM-Pir] prefix) — fixed in the latest commit. Log messages now show
      [PresenceScreenControl] [PIR]. A git pull will get you this fix.
      Issue 2 (screen stays on at startup): The counter showing 00:00 when nobody is in front of the
      sensor is actually correct — no presence means the counter is expired.
      The real question is: does your screen actually turn off? Your log shows the off-command executing successfully:
      [updateScreen] SUCCESS: executed “DISPLAY=:0 wlr-randr --output HDMI-A-1 --off”
      If the screen turns off but comes back on after ~10 seconds (as you describe in your second post),
      that’s not our module turning it back on — the debug log shows no PIR_DETECTED event at that
      moment. Please check if your Wayland compositor (Wayfire?) has its own idle/screen management:
      look for an [idle] section in ~/.config/wayfire.ini. A dpms_timeout or similar setting would
      re-enable the screen and override our wlr-randr --off.
      Warmest regards,
      Ralf
      R htilburgsH 2 Replies Last reply Reply Quote 0
        rkorell Module Developer @rkorell
        MMM-PresenceScreenControl: gpiomon replaces native dependencies (PR #2)
        I’m happy to share that @KristjanESPERANTO contributed a significant improvement to
        MMM-PresenceScreenControl via https://github.com/rkorell/MMM-PresenceScreenControl/pull/2:
        What changed:
        The PIR sensor handling has been completely reworked. Instead of relying on node-libgpiod (a
        native C addon requiring @electron/rebuild) with a Python/gpiozero fallback, the module now uses
        gpiomon — a standard CLI tool that comes pre-installed with libgpiod on every Raspberry Pi.
        What this means for you:
        • No more native compilation during npm install
        • No more @electron/rebuild or Python dependencies for PIR
        • Works on both Bookworm and Trixie out of the box
        • Automatic detection of libgpiod version (1.x / 2.x) and GPIO chip (Pi 4: gpiochip0, Pi 5:
          gpiochip4)
        Additional fixes in the same update:
        • Log spam eliminated: runtime log messages now respect the debug setting (“off” / “simple” /
          “complex”). With debug: “off” (default), pm2 logs stay clean. Thanks to @htilburgs for spotting
          this!
        • Confusing [MMM-Pir] log prefix renamed to [PresenceScreenControl]
        To update:
        cd ~/MagicMirror/modules/MMM-PresenceScreenControl
        rm -rf node_modules package-lock.json
        git pull
        npm install
        BIG ! thanks to @KristjanESPERANTO for the clean refactoring and pointing out the log issues!
        Warm regards,
        Ralf
        htilburgsH 1 Reply Last reply Reply Quote 1
        • htilburgsH
          htilburgs @rkorell
          @rkorell
          Hi Ralf, I don’t agree with your argument about Issue 2.
          When my MagicMirror starts and it does not detect any movement, the screen will stay on and on until movement is detected. Let’s say I’m not around for 2 hours, the screen is on for 2 hours.
          My other PIR modules I tested, do this as aspected (both MMM-Pir and MMM-Universal-Pir). So maybe you can consider to change this.
          The other issue still exists after the update.
          I don’t have a wayfire.ini file in my ~/.config.
          My previous module MMM-Pir puts the screen off and at movement on. It stays off after it goes off.
          With MMM-PresenceScreenControl my screen turns off and than after about 6-7 seconds, the screen comes back on again. I don’t make conclusions, but I think it has nothing to do with my system of Wayland settings. Something is triggering that the screen goes on again.
          (still trying to learn JS, but not afraid to ask and AI is my best friend) ☺
          • htilburgsH
            htilburgs @rkorell
            To update:
            git pull
            npm install
            The better way is first rm -rf node_modules package-lock.json, otherwise git pull gives an error that it cannot update because of package-lock.json
            error: Your local changes to the following files would be overwritten by merge: package-lock.json
            Please commit your changes or stash them before you merge.
              @htilburgs sure. you’re right. Sorry.
              I’ve removed package-lock.json from git-tracking and corrected the README.md installation instruction according your advise.
              Instructions in postings above corrected as well.
              Regards,
              Ralf
                Dear @htilburgs
                You were right about the startup behavior — I’ve fixed it. The screen now turns off after ~1
                second if no presence is detected at startup. No more waiting for the first sensor event.
                Please update:
                git pull
                npm install
                Regarding the remaining issue (screen comes back on after 6-7 seconds): The debug log you shared
                earlier shows the off command executing successfully, with no PIR event triggering the screen back
                on. The module isn’t causing it — but I need to understand what is. Could you please set debug:
                “complex” and share the complete log output from the moment the screen turns off until it comes
                back on? That will show every internal state change.
                Thanks for your testing and feedback — it’s making the module better for everyone.
                Warm regards,
                Ralf
                htilburgsH S 2 Replies Last reply Reply Quote 0
                • htilburgsH
                  htilburgs @rkorell
                  @rkorell
                  First of all, thank you for your time!
                  Ok, nice. But why ~1 second?
                  Why not the time from counterTimeout?
                  Just my thoughts ;-)
                  back on?
                  I will do this, but it will be tommorow.
                  I have to get up early and it’s already late.
                  htilburgsH 1 Reply Last reply Reply Quote 0
                    sdetweil @rkorell
                    @rkorell you could set a preinstall script in
                    package.json to erase the lock file
                    • htilburgsH
                      htilburgs @htilburgs
                      @rkorell
                      I did a git pull so I’m sure I’ve the latest version:
                      • Screen stays on until I trigger the sensor, so that is not changed.
                      • Screen goes off after 30 sec (my setting for testing) and after 6 seconds it comes on again, saying 00:00
                      I had set debug:“complex” and this is what it gave
                      [2026-03-09 06:53:11.320] [LOG]   [MMM-PresenceScreenControl] [PresenceScreenControl] [PIR] gpiomon output: 30488.576057914     rising  gpiochip0 17 "GPIO17"
                      [2026-03-09 06:53:12.466] [LOG]   [MMM-PresenceScreenControl] [PresenceScreenControl] [PIR] gpiomon output: 30489.724051868     falling gpiochip0 17 "GPIO17"
                      [2026-03-09 06:53:14.974] [LOG]   [MMM-PresenceScreenControl] [PresenceScreenControl] [PIR] gpiomon output: 30492.232041526     rising  gpiochip0 17 "GPIO17"
                      [2026-03-09 06:53:16.122] [LOG]   [MMM-PresenceScreenControl] [PresenceScreenControl] [PIR] gpiomon output: 30493.380045941     falling gpiochip0 17 "GPIO17"
                      [2026-03-09 06:55:15.350] [LOG]   [MMM-PresenceScreenControl] [PresenceScreenControl] [PIR] gpiomon output: 30612.608045172     rising  gpiochip0 17 "GPIO17"
                      [2026-03-09 06:55:16.498] [LOG]   [MMM-PresenceScreenControl] [PresenceScreenControl] [PIR] gpiomon output: 30613.756051231     falling gpiochip0 17 "GPIO17"
                      I only have a message when I trigger the PIR, but further no messages. For being complete, my config:
                                              module: "MMM-PresenceScreenControl",
                                              position: "bottom_right",
                                              disabled: false,
                                                      mode: "PIR",
                                                      pirGPIO: 17,
                                                      onCommand: "DISPLAY=:0 wlr-randr --output HDMI-A-1 --on --mode 1920x1080 --transform 270",
                                                      offCommand: "DISPLAY=:0 wlr-randr --output HDMI-A-1 --off",
                                                      counterTimeout: 30,
                                                      autoDimmer: false,
                                                      autoDimmerTimeout: 60,
                                                      style: 2,
                                                      colorFrom: "red",
                                                      colorTo: "lime",
                                                      colorCronActivation: "cornflowerblue",
                                                      showPresenceStatus: false,
                                                      debug: "complex",
                                                      resetCountdownWidth: false
                        @sdetweil Thanks.
                        I’ve excluded this file from git tracking so the pull should work.
                        Warm regards,
                        Ralf
                          Dear @htilburgs,
                          it seems, we are in the same time-zone :-) wouldn’t be surpised even same mother-tongue …
                          Nevertheless, thank you for your patience and the detailed logs — they were extremely helpful in tracking this down.
                          What we found
                          The module works perfectly on my system (Pi 5, Debian Trixie, Wayland/labwc, MagicMirror 2.34.0), so we did an intensive
                          deep-dive comparing your setup, your MMM-Pir configuration, and your MMM-PresenceScreenControl configuration to understand why
                          the screen comes back after ~6 seconds on your system.
                          The key clue came from your own working MMM-Pir config:
                          mode: 3
                          waylandDisplayName: "wayland-0"
                          MMM-Pir mode 3 uses wlr-randr — the same tool you configured for MMM-PresenceScreenControl. But there’s a critical difference:
                          MMM-Pir internally sets WAYLAND_DISPLAY=wayland-0 (from your waylandDisplayName parameter) before calling wlr-randr.
                          Your MMM-PresenceScreenControl config, on the other hand, uses:
                          wlr-randr is a Wayland tool — it communicates with the Wayland compositor via the WAYLAND_DISPLAY environment variable.
                          DISPLAY=:0 is an X11 variable and is meaningless to wlr-randr. Without the correct WAYLAND_DISPLAY, wlr-randr falls back to
                          guessing the socket, which results in the unstable behavior you’re seeing: the screen turns off but comes back after ~6
                          seconds.
                          This also explains why your system info shows WAYLAND_DISPLAY: undefined — MagicMirror/Electron doesn’t have it set, so any
                          screen command executed from the module needs to provide it explicitly.
                          The fix
                          Replace DISPLAY=:0 with WAYLAND_DISPLAY=wayland-0 in your config. You have two options:
                          Option A: wlr-randr (matching your working MMM-Pir setup)
                          onCommand: "WAYLAND_DISPLAY=wayland-0 wlr-randr --output HDMI-A-1 --on --mode 1920x1080 --transform 270",
                          offCommand: "WAYLAND_DISPLAY=wayland-0 wlr-randr --output HDMI-A-1 --off",
                          This is the minimal change — same tool, same parameters, just the correct environment variable.
                          Option B: wlopm (recommended, more robust)
                          wlopm is purpose-built for display power management on Wayland. Unlike wlr-randr --off (which removes the output from the
                          compositor layout), wlopm --off uses the Wayland power management protocol (DPMS-level) — it turns the display hardware off
                          without affecting window layout. This is what I use on my system.
                          First install it (it’s in the Trixie repos):
                          sudo apt install wlopm
                          Then configure:
                          onCommand: "wlopm --on HDMI-A-1",
                          offCommand: "wlopm --off HDMI-A-1",
                          Note: wlopm doesn’t need WAYLAND_DISPLAY explicitly — the default fallback to wayland-0 works reliably on Trixie. And since
                          wlopm controls hardware power state, it doesn’t need --mode or --transform on the on command — the display simply wakes up with
                          its previous settings intact.
                          For reference, the https://github.com/Jopyth/MMM-Remote-Control/blob/master/docs/guide/monitor-control.md documents wlr-randr
                          as the recommended Wayland screen control option, including the hint to set WAYLAND_DISPLAY if needed.
                          About the startup behavior (screen stays on)
                          You mentioned the screen stays on after MagicMirror starts until you trigger the PIR. The startup fix from commit 39d28d6 does
                          work — it turns the screen off ~1 second after startup. But since your offCommand wasn’t working correctly (the DISPLAY=:0
                          issue), the screen appeared to “stay on.” Once you fix the command, the screen should turn off shortly after startup if nobody
                          is in front of the PIR.
                          You also asked: “Why not the time from counterTimeout?” — That’s a fair point. On my system, counterTimeout is 600 (10
                          minutes), so turning off after 1 second is the desired behavior — I want to see that the restart worked, but not wait 10
                          minutes. For your setup with counterTimeout: 30, having 30 seconds of screen-on after startup would make more sense.
                          I’m planning a new config parameter startupGracePeriod that lets you define how long the screen stays on after module start
                          before the presence logic kicks in. This way each user can choose independently of their counterTimeout. I’ll include this in a
                          future release.
                          Upcoming improvement: cronMonitor efficiency
                          While investigating your issue, I discovered that the internal cron monitor (which checks for always-on/ignore time windows)
                          sends updates to the frontend every second, even when nothing has changed and the screen is off. This causes unnecessary DOM
                          rebuilds and is inefficient, though it’s not the cause of your screen-comes-back problem. I’ll fix this in the next release to
                          make the module quieter after screen-off.
                          About the debug logging
                          Now that we’ve identified the root cause, you can set debug: “off” in your config again. The debug output you saw (gpiomon
                          lines in pm2 logs) comes from the PIR library and goes to the console. The module’s own debug logging (updatePresence,
                          startCounter, updateScreen, etc.) intentionally writes to a separate log file (MMM-PresenceScreenControl_local.log in the
                          module directory) rather than to pm2 logs. This keeps the debug output focused and separated from the noise of all other
                          modules — much easier to analyze when troubleshooting a specific issue. If you ever need to debug the module again, check that
                          file instead of pm2 logs.
                          Summary
                          1. Screen comes back after 6 seconds: Replace DISPLAY=:0 with WAYLAND_DISPLAY=wayland-0 (Option A), or switch to wlopm (Option
                            B)
                          2. Screen stays on after startup: Should be fixed once Option A or B is applied. A startupGracePeriod parameter is planned for
                            a future release.
                          3. Log prefix [MMM-Pir]: Already fixed in your version ✓
                          Please let me know if Option A or B resolves the screen-comes-back issue!
                          Warm regards,
                          Ralf
                          • htilburgsH
                            htilburgs @rkorell
                            @rkorell
                            I live in the Netherlands.
                            I’m Currently at the office, but I Will test it this evening and give you the results.
                              @htilburgs :-) OK, nearby - Germany …
                              Thanks for testing/feedback!
                              Ralf
                              • htilburgsH
                                htilburgs @rkorell
                                @rkorell
                                Oke, done some testing:
                                With the ‘new’ strings, I get:
                                [ERROR] [MMM-PresenceScreenControl] [updateScreen] ERROR: Error: Command failed: WAYLAND_DISPLAY=wayland-0 wlr-randr --output HDMI-A-1 --on --mode 1920x1080 --transform 270
                                unknown output HDMI-A-1
                                Why this message, I don’t know.
                                After a reboot this message didn’t show again.
                                Then I stopped MagicMirror and did the same command from the commandline WAYLAND_DISPLAY=wayland-0 wlr-randr --output HDMI-A-1 --off
                                After 6 seconds my display comes on again.
                                So it isn’t coming from MagicMirror, but from my system.
                                I created a simple Python3 script to turn off and on my monitor. Same problem.
                                Next step:
                                I took a new SD Card and installed a fresh copy of Trixie.
                                Didn’t do anything else, no updates or something else and tried again with WAYLAND_DISPLAY=wayland-0 wlr-randr --output HDMI-A-1 --off from the command prompt.
                                Display goes off and after 6 seconds back on again.
                                So I excluded MagicMirror. What else can it be?
                                Next step:
                                I took an other RPI4b with the new SD Card from previous step. Repeated the test, but still same result. Monitor goes on after 6 seconds. So it is not MagicMirror, not the RPI. But why it works with MMM-PIR and not with MMM-PresenceScreenControl. It is still a riddle for me.
                                Next step:
                                Original RPI with original SD Card and installed MMM-Universal-Pir. Same result, after 6 seconds screen on.
                                So I excluded MagicMirror, SD Card, Trixie installation and RPI. It must have something to do with my monitor?!?
                                Did something happen? Not that I know.
                                After doing a search on the big WWW, I found an interesting article that described exact the same issue I was having.
                                https://forums.raspberrypi.com/viewtopic.php?t=363966
                                So I searched for my RemoteControl and search for a setting
                                that automatically scan its input sources (not easy if your MagicMirror screen is rotated 270° ;-)
                                And I found this setting and indeed it was standing on auto scan. I put it on HDMI as only source and tried it again:
                                YES, IT IS WORKING!!!
                                And even better than before, now my monitor turns completly off after 15 min. of no signal. So instead of using 75W when on, 26W in standby, it now uses 0W after 15 minutes (it’s a setting on the monitor).
                                Activating the PIR, it turns back on!
                                So with this I hope that if somebody else has this problem, they can solve it to.
                                Ralf, thanks for all the help and trying to solve it with me.
                                I’m looking forward for the startupGracePeriod parameter and think this is going to make the module fully as I like it.
                                Thank you for your great work with this module and a grownup replacement for MMM-Pir!!!
                                  @htilburgs
                                  I’m SO happy.
                                  Great news - congratulations…
                                  So at least your stubborn issue leds to several code enhancements - during my investigation regarding your symptoms I had the chance to identify some optimization potential, so code is much cleaner now.
                                  Thanks for this gentle “push”.
                                  Warmest regards,
                                  Ralf
                                  • htilburgsH
                                    htilburgs @rkorell
                                    @rkorell your welcome…;-)
                                      Good news — your wish came true faster than expected! 😊
                                      v1.5.0 is released and includes the startupGracePeriod parameter you were looking forward to.
                                      How to update:
                                      rm -rf node_modules
                                      git pull
                                      npm install
                                      Then add to your config:
                                      startupGracePeriod: 30,  // seconds to keep screen on after startup
                                      Set it to however many seconds you want the screen to stay on after a restart — enough time to
                                      verify everything came up correctly. After the grace period, normal presence logic kicks in. If
                                      your PIR detects you during the grace period, it seamlessly switches to the regular countdown
                                      timer.
                                      Also included in v1.5.0:
                                      • logFileName parameter — debug output now goes to pm2 logs by default (no more hidden log file)
                                      • Several internal fixes found during a code quality review
                                      Full changelog in the README.
                                      Enjoy! 🎉
                                      Warm regards,
                                      Ralf
                                      • htilburgsH
                                        htilburgs @rkorell
                                        @rkorell
                                        Hi Ralf, I implemented the new version and parameter.
                                        It works great!
                                        I’m now playing with the CSS.
                                        Made the bar smaller (50%) rounded edges and alligned the counter at the left of my screen.
                                        For those who like this setup, just add following in ~/MagicMirror/css/custom.css
                                        /* MMM-PresenceScreenControl */
                                        .psc-linebar {
                                          width: 50%;
                                          height: 5px;
                                          background: #222;
                                          border-radius: 4px;
                                          margin: 6px 0 6px 0;
                                          overflow: hidden;
                                          margin-left: auto;
                                          margin-right: 0;
                                        .psc-bar {
                                          height: 100%;
                                          width: 100%;
                                          border-radius: 4px;
                                          transition: width 0.4s ease, background 0.4s ease;
                                          box-shadow: 0 0 6px currentColor;
                                        .psc-timer {
                                          font-size: 16px;
                                          margin-top: 4px;
                                          margin-bottom: 2px;
                                          letter-spacing: 1px;
                                          text-align: right !important;
                                          @htilburgs cool!
                                          happy, that you are satisfied!
                                          Warm regards,
                                          Ralf
                                          interesting that you are poistion this counterbar on thr right side of the screen.
                                          For me it feels/looks more natural on the left side.
                                          May this is the reason for my “acceptance” of the colorFrom / colorTo - “mismatch” you had reported …
                                          • htilburgsH
                                            htilburgs @rkorell
                                            @rkorell
                                            My current mirror
                                            This is why I have it on the right. For me this feels better.
                                            On the left side there comes the Spotify information, when I play music.
                                            • 2 / 3
