    MMM-MySystem
    6 Posts 3 Posters 544 Views 3 Watching
    • htilburgsH Offline
      htilburgs
      MMM-MySystem
      This is a Magic Mirror² module for the system information.
      I now there are more 😉, but I built a version with a modern look and feel, suited for my needs.
      SCR-20260310-qsds
      Installation
      Clone this repository in your modules folder, and install dependencies:
      cd ~/MagicMirror/modules
      git clone https://github.com/htilburgs/MMM-MySystem.git
      cd MMM-MySystem
      npm install
      Update
      When you need to update this module:
      cd ~/MagicMirror/modules/MMM-MySystem
      git pull
      npm install
      Configuration
      Go to the MagicMirror/config directory and edit the config.js file.
      Add the module to your modules array in your config.js.
        module: "MMM-MySystem",
        header: "System Information",
        disabled: false,
          showHeader: true,
          showCpuUsage: true,
          showCpuTemp: true,
          showMemory: true,
          showDisk: true,
          showUptime: true,
          showIPeth: true,
          showIPwifi: true,
          tempUnit: "C"
          updateInterval: 10000
      Configuration Options
      Option Description
      showHeader Show the header with Hostname, Model and OS Version
      Options: true/false - Default: true
      showCPUusage Show the CPU Usage (%)
      showCPUtemp Show the CPU Temperature
      showMemory Show the Free Memory (%)
      showDisk Show the Free Diskpace
      showIPeth Show the IP Address for the Ethernet
      showIPwifi | Show the IP Address for the Wifi<br/>Options: true/false - Default: <b>true`
      tempUnit Show the temperature in ˚C or ˚F
      Options: C/F - Default: C
      updateInterval Update interval module in ms
      Default: 10000 (10 seconds)
      Versions
      v1.0.0 (10-03-2026): Initial version)
      (still trying to learn JS, but not afraid to ask and AI is my best friend) ☺
      O 1 Reply Last reply Reply Quote 3
      • O Offline
        OberfragGER @htilburgs
        @htilburgs Thanks a lot. It looks pretty nice. Something is strange - i haver other icons…!?!
        Is that related to a old MM-Version?
        Also “Freier Speicher” / free memory looks doesent have any icon or why is the text more left than the other text?
        htilburgsH 1 Reply Last reply Reply Quote 0
          htilburgs @OberfragGER
          @OberfragGER
          I had somebody with a simular problem on MMM-MyTado. He installed the fonts-noto-color-emoji font
          sudo apt update
          sudo apt install fonts-noto-color-emoji
          fc-cache -fv
          Restart your mirror and see what happens.
            Megawaldi
            Its possible to get black/white icons?
              htilburgs @Megawaldi
              @Megawaldi
              Currently it is not possible. The icons are ‘hard-coded’ into the module.
              • O Offline
                @htilburgs Thanks for the update.
                Im running a buster version… so this is not working for me.
                Maybe im getting back to it when i have more time for that.
