    MMM-CalendarExt3Agenda - Event Transforming not working - Mirror 2.35.0
    9 Posts 3 Posters 3.6k Views 3 Watching
    • BKeyportB Offline
      BKeyport Module Developer
      I’m having a problem with event transforming not working anymore in Mirror 2.35.0
      the client title (Client’s name) is shown instead of the ev.title I want (Client)
      Nothing is in the logs - help!
      Here’s the code:
      	  		module: "MMM-CalendarExt3Agenda",
        			position: "bottom_center",
        			classes: "page1",
        				eventTransformer: (ev) => {
      					if (ev.title.search("🏠 Personal Commitment") > -1) {
      						ev.title = ev.title.replace("🏠 Personal Commitment","Personal Commitment")
      					if(ev.description && ev.description.search("YCBM") > -1) {
             					 	ev.title = "Client"
      					return ev
      				showMiniMonthCalendar: false,
      				//onlyEventDays: 1,
      				waitFetch: 5000,
      				refreshInterval: 10000,
      				animationSpeed: 0,
      				calendarSet: ["Main", "Lemay", "Holidays"],
      • KristjanESPERANTOK Offline
        KristjanESPERANTO Module Developer @BKeyport
        @BKeyport It should be fixed with v1.5.0. Please update and check :-)
          sdetweil @BKeyport
          @BKeyport can you use console.log to log the description. See it in the dev window console
            There is a big rewrite of calendar this release . To fix the dates, dst/std, and timezone conversions. @kristjanesperanto did a great job. Also fixing node-iCal
            Both also get rid of moment
            I didn’t see any issues in testing, but I didn’t have any transforms
            BKeyportB 1 Reply Last reply Reply Quote 1
            • BKeyportB Offline
              @sdetweil As I said, I cannot find any errors in any logs I know how to access. (Other than the usual updating DOM without display, etc).
              As for the re-writes, I don’t know enough about it, and in the middle of tax season, so I don’t have time to learn.
              S KristjanESPERANTOK 2 Replies Last reply Reply Quote 0
                sdetweil @BKeyport
                @BKeyport NO… I was asking you to add a
                console.log(“ev description-.”+ev.description+“<-”)
                to your tranformer
                then you can see the contents of the description field…
                as this runs in the browser, you would have to open the developers window, console tab, and put ext3, in the filter field to see the messages
                then you would know exactly what is there. and it may give indication of the problem
                you could also dump the fields
                console.log(“ev fields=”,ev)
                note the comma here, it will haveJS to do the unpacking of the fields in ev
                  • BKeyportB Offline
                    BKeyport Module Developer @KristjanESPERANTO
                    @KristjanESPERANTO I’m downgraded to previous MM until after the end of tax season at least.
                      @BKeyport Okay, no rush 🙂
                      • BKeyportB Offline
                        @KristjanESPERANTO Finally got time to fix things up and move forward (Complete reinstall, honestly)
                        Everything is working as I desire now.
