Reverting to previous MM Release
I need to back down to the previous release. I believe the 4/1 release of MM is a step too far in compatibility breaks.
Is there a guide on how to do this?
cd ~/MagicMirror # double dash in front of tags git fetch —tags git checkout -b test_branch v2.34.0 rm -rf node_modules rm package-lock.json npm run install-mm -
@sdetweil interesting that the old release is in test branch.
@BKeyport it’s just a name. I picked something, could be anything except master and develop as those are already used
@sdetweil gotcha.
I’ll likely re-work my entire system(s) after tax season is over, but this will hold until then. Once I have time, I’m mulling a few changes that’ll break everything anyway.
I have just reverted to the old version as well. Too many issues with electron. Breaking issues for me as well. And I am running Pi5 Trixie. Something about Pi5 Trixie and Electron 41 not playing well together. v2.34.0 ran just fine on Trixie and using Wayland. Now it is breaking.
@mumblebaj can you articulate the issues?
S sdetweil has marked this topic as solved on
@sdetweil Hi Sam. I upgraded using your upgrade script. Then I saw the following error,
/home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGTRAP. MM shows that it has started but browser does not launch, Electron failing. Tried a bunch of things but nothing seems to help. Switched back to X11 and still getting the dreaded error.I have downgraded to 2.34.0 and still same issue now.
I am flashing a new SD card now and will try a fresh install and see how that goes
@mumblebaj
After downgrading, did you run
npm install again -
@sdetweil Yes sir. Just got in now. Will work on the new SD card now and advise in a bit.
@mumblebaj ok, thx
@sdetweil Flashed the new card and installed trixie, Did a clean install. Ran your restore script and everything is running just fine.
@mumblebaj woohoo… at least thats something good!!
@sdetweil For sure. I am suspecting the card may have been flaking. Now to fix my Docker image. 😮💨
@sdetweil I ran your upgrade script as well and I also see electron errors in the pm2 logs. The system just loads to a blank/black screen (with cursor), but fails to load beyond that.
0|mm | /home/dietpi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGSEGV -
@jca2112 when did you run it? today?
can you look at ~/MagicMirror/installers/mm.sh
and see if
npm run start:x11is present on line 9
also, can you do
pm2 stop all cd ~/MagicMirrorand try either
npm startor
npm run start:x11is this really a dietpi? what OS version is running
lsb_release -a
also, can you send me ~/MagicMirror/installers/upgrade.log
same userid at gmail -
I ran the script yesterday (04/05/2026).
and see if
Here is the mm.sh:
#!/bin/bash cd /home/dietpi/MagicMirror if [ $(ps -ef | grep -v grep | grep -i -e xway -e labwc | wc -l) -ne 0 ]; then # if WAYLAND_DISPLAYis set, use it, else set to -0 export WAYLAND_DISPLAY=${WAYLAND_DISPLAY:=wayland-0} npm run start:wayland else DISPLAY=:0 npm start fi #DISPLAY=:0 npm startalso, can you do
npm startnpm output:
> magicmirror@2.35.0 start > node --run start:wayland [2026-04-06 09:08:03.511] [LOG] [app] Starting MagicMirror: v2.35.0 [2026-04-06 09:08:03.549] [LOG] [utils] Loading config ... [2026-04-06 09:08:03.567] [INFO] [utils] Checking config file /home/dietpi/MagicMirror/config/config.js ... [2026-04-06 09:08:03.945] [INFO] [utils] Your configuration file doesn't contain syntax errors :) [2026-04-06 09:08:03.949] [INFO] [utils] Checking modules structure configuration ... [2026-04-06 09:08:04.360] [INFO] [utils] Your modules structure configuration doesn't contain errors :) [2026-04-06 09:08:04.369] [LOG] [app] Loading module helpers ... [2026-04-06 09:08:04.377] [LOG] [app] No helper found for module: alert. [2026-04-06 09:08:04.408] [LOG] [node_helper] Initializing new module helper ... [2026-04-06 09:08:04.413] [LOG] [node_helper] Module helper loaded: updatenotification [2026-04-06 09:08:04.417] [LOG] [app] No helper found for module: clock. [2026-04-06 09:08:05.284] [LOG] [node_helper] Initializing new module helper ... [2026-04-06 09:08:05.286] [LOG] [node_helper] Module helper loaded: calendar [2026-04-06 09:08:05.297] [LOG] [node_helper] Initializing new module helper ... [2026-04-06 09:08:05.300] [LOG] [node_helper] Module helper loaded: weather [2026-04-06 09:08:05.615] [LOG] [node_helper] Initializing new module helper ... [2026-04-06 09:08:05.619] [LOG] [node_helper] Module helper loaded: newsfeed [2026-04-06 09:08:06.334] [INFO] [systeminformation] #### System Information #### - SYSTEM: manufacturer: Raspberry Pi Foundation; model: Raspberry Pi 3 Model B Plus Rev 1.3; virtual: false; MM: v2.35.0 - OS: platform: linux; distro: Debian GNU/Linux; release: 13; arch: arm64; kernel: 6.12.75+rpt-rpi-v8 - VERSIONS: electron: 41.1.0; used node: 25.2.1; installed node: 25.2.1; npm: 11.6.2; pm2: 6.0.14 - ENV: XDG_SESSION_TYPE: undefined; MM_CONFIG_FILE: undefined WAYLAND_DISPLAY: wayland-1; DISPLAY: undefined; ELECTRON_ENABLE_GPU: undefined - RAM: total: 905.98 MB; free: 524.54 MB; used: 381.45 MB - OTHERS: uptime: 1192 minutes; timeZone: America/New_York [2026-04-06 09:08:06.353] [LOG] [node_helper] Initializing new module helper ... [2026-04-06 09:08:06.355] [LOG] [node_helper] Module helper loaded: MMM-Sonos [2026-04-06 09:08:06.356] [LOG] [app] All module helpers loaded. [2026-04-06 09:08:06.385] [LOG] [server] Starting server on port 8080 ... [2026-04-06 09:08:06.415] [ERROR] [unknown] (node:605210) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead. (Use `electron --trace-deprecation ...` to show where the warning was created) [2026-04-06 09:08:06.477] [LOG] [app] Server started ... [2026-04-06 09:08:06.480] [LOG] [node_helper] Connecting socket for: updatenotification [2026-04-06 09:08:06.481] [LOG] [node_helper] Starting module helper: updatenotification [2026-04-06 09:08:06.483] [LOG] [node_helper] Connecting socket for: calendar [2026-04-06 09:08:06.485] [LOG] [calendar] Starting node helper for: calendar [2026-04-06 09:08:06.486] [LOG] [node_helper] Connecting socket for: weather [2026-04-06 09:08:06.488] [LOG] [weather] Starting node helper for: weather [2026-04-06 09:08:06.490] [LOG] [node_helper] Connecting socket for: newsfeed [2026-04-06 09:08:06.491] [LOG] [newsfeed] Starting node helper for: newsfeed [2026-04-06 09:08:06.493] [LOG] [node_helper] Connecting socket for: MMM-Sonos [2026-04-06 09:08:06.495] [LOG] [MMM-Sonos] Sonos helper started ... [2026-04-06 09:08:06.496] [LOG] [app] Sockets connected & modules started ... error: XDG_RUNTIME_DIR is invalid or not set in the environment. [605210:0406/090806.501637:ERROR:ui/ozone/platform/wayland/host/wayland_connection.cc:202] Failed to connect to Wayland display: No such file or directory (2) [605210:0406/090806.502006:ERROR:ui/ozone/platform/wayland/ozone_platform_wayland.cc:281] Failed to initialize Wayland platform [605210:0406/090806.502155:ERROR:ui/aura/env.cc:246] The platform failed to initialize. Exiting. /home/dietpi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGSEGVis this really a dietpi? what OS version is running
DietPi v10.2.3 (I believe that is the latest version)
same userid at gmailEmail sent.
Thanks for all your help!
@jca2112 ok edit the mm.sh
and changenpm startto
npm run start:x11I know why… I fixed the script on saturday, but didn’t catch that on my mac I was on a different branch, so the master branch didn’t get updated til about 9pm central last night.
I drove all day yesterday, and fixed it again on master… -
@jca2112 from the log,
saved translations/en.json
make sure you check on this change, as it was stashed but not re-applied…
@sdetweil Yup, it’s working now. Awesome, thank you so much.
(The translations/en.json is just a single word change, so easy to fix manually without being stashed.)
