    Reverting to previous MM Release
    20 Posts 4 Posters 2.9k Views 5 Watching
      sdetweil @BKeyport
      @BKeyport it’s just a name. I picked something, could be anything except master and develop as those are already used
      • BKeyportB
        @sdetweil gotcha.
        I’ll likely re-work my entire system(s) after tax season is over, but this will hold until then. Once I have time, I’m mulling a few changes that’ll break everything anyway.
        mumblebajM 1 Reply Last reply Reply Quote 1
        • mumblebajM
          mumblebaj Module Developer @BKeyport
          I have just reverted to the old version as well. Too many issues with electron. Breaking issues for me as well. And I am running Pi5 Trixie. Something about Pi5 Trixie and Electron 41 not playing well together. v2.34.0 ran just fine on Trixie and using Wayland. Now it is breaking.
            sdetweil @mumblebaj
            @mumblebaj can you articulate the issues?
            • mumblebajM
              @sdetweil Hi Sam. I upgraded using your upgrade script. Then I saw the following error, /home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGTRAP. MM shows that it has started but browser does not launch, Electron failing. Tried a bunch of things but nothing seems to help. Switched back to X11 and still getting the dreaded error.
              I have downgraded to 2.34.0 and still same issue now.
              I am flashing a new SD card now and will try a fresh install and see how that goes
              S jca2112J 2 Replies Last reply Reply Quote 0
                sdetweil @mumblebaj
                @mumblebaj
                After downgrading, did you run
                npm install again
                • mumblebajM
                  @sdetweil Yes sir. Just got in now. Will work on the new SD card now and advise in a bit.
                    sdetweil @mumblebaj
                    @mumblebaj ok, thx
                    • mumblebajM
                      @sdetweil Flashed the new card and installed trixie, Did a clean install. Ran your restore script and everything is running just fine.
                        sdetweil @mumblebaj
                        @mumblebaj woohoo… at least thats something good!!
                        • mumblebajM
                          @sdetweil For sure. I am suspecting the card may have been flaking. Now to fix my Docker image. 😮‍💨
                          • jca2112J
                            jca2112 @mumblebaj
                            @sdetweil I ran your upgrade script as well and I also see electron errors in the pm2 logs. The system just loads to a blank/black screen (with cursor), but fails to load beyond that.
                            0|mm  | /home/dietpi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGSEGV
                              sdetweil @jca2112
                              @jca2112 when did you run it? today?
                              can you look at ~/MagicMirror/installers/mm.sh
                              and see if
                              npm run start:x11
                              is present on line 9
                              also, can you do
                              pm2 stop all
                              and try either
                              npm start
                              or
                              npm run start:x11
                              is this really a dietpi? what OS version is running
                              lsb_release -a
                              also, can you send me ~/MagicMirror/installers/upgrade.log
                              same userid at gmail
                              jca2112J 1 Reply Last reply Reply Quote 0
                              • jca2112J
                                jca2112 @sdetweil
                                I ran the script yesterday (04/05/2026).
                                and see if
                                npm run start:x11
                                Here is the mm.sh:
                                #!/bin/bash
                                cd /home/dietpi/MagicMirror
                                if [ $(ps -ef | grep -v grep | grep -i -e xway -e labwc | wc -l) -ne 0 ]; then
                                   # if WAYLAND_DISPLAYis set, use it, else set to -0
                                   export WAYLAND_DISPLAY=${WAYLAND_DISPLAY:=wayland-0}
                                   npm run start:wayland
                                else
                                   DISPLAY=:0 npm start
                                fi
                                #DISPLAY=:0 npm start
                                also, can you do
                                pm2 stop all
                                and try either
                                npm start
                                npm output:
                                > magicmirror@2.35.0 start
                                > node --run start:wayland
                                [2026-04-06 09:08:03.511] [LOG]   [app] Starting MagicMirror: v2.35.0
                                [2026-04-06 09:08:03.549] [LOG]   [utils] Loading config ...
                                [2026-04-06 09:08:03.567] [INFO]  [utils] Checking config file /home/dietpi/MagicMirror/config/config.js ...
                                [2026-04-06 09:08:03.945] [INFO]  [utils] Your configuration file doesn't contain syntax errors :)
                                [2026-04-06 09:08:03.949] [INFO]  [utils] Checking modules structure configuration ...
                                [2026-04-06 09:08:04.360] [INFO]  [utils] Your modules structure configuration doesn't contain errors :)
                                [2026-04-06 09:08:04.369] [LOG]   [app] Loading module helpers ...
                                [2026-04-06 09:08:04.377] [LOG]   [app] No helper found for module: alert.
                                [2026-04-06 09:08:04.408] [LOG]   [node_helper] Initializing new module helper ...
                                [2026-04-06 09:08:04.413] [LOG]   [node_helper] Module helper loaded: updatenotification
                                [2026-04-06 09:08:04.417] [LOG]   [app] No helper found for module: clock.
                                [2026-04-06 09:08:05.284] [LOG]   [node_helper] Initializing new module helper ...
                                [2026-04-06 09:08:05.286] [LOG]   [node_helper] Module helper loaded: calendar
                                [2026-04-06 09:08:05.297] [LOG]   [node_helper] Initializing new module helper ...
                                [2026-04-06 09:08:05.300] [LOG]   [node_helper] Module helper loaded: weather
                                [2026-04-06 09:08:05.615] [LOG]   [node_helper] Initializing new module helper ...
                                [2026-04-06 09:08:05.619] [LOG]   [node_helper] Module helper loaded: newsfeed
                                [2026-04-06 09:08:06.334] [INFO]  [systeminformation]
                                ####  System Information  ####
                                - SYSTEM:   manufacturer: Raspberry Pi Foundation; model: Raspberry Pi 3 Model B Plus Rev 1.3; virtual: false; MM: v2.35.0
                                - OS:       platform: linux; distro: Debian GNU/Linux; release: 13; arch: arm64; kernel: 6.12.75+rpt-rpi-v8
                                - VERSIONS: electron: 41.1.0; used node: 25.2.1; installed node: 25.2.1; npm: 11.6.2; pm2: 6.0.14
                                - ENV:      XDG_SESSION_TYPE: undefined; MM_CONFIG_FILE: undefined
                                            WAYLAND_DISPLAY:  wayland-1; DISPLAY: undefined; ELECTRON_ENABLE_GPU: undefined
                                - RAM:      total: 905.98 MB; free: 524.54 MB; used: 381.45 MB
                                - OTHERS:   uptime: 1192 minutes; timeZone: America/New_York
                                [2026-04-06 09:08:06.353] [LOG]   [node_helper] Initializing new module helper ...
                                [2026-04-06 09:08:06.355] [LOG]   [node_helper] Module helper loaded: MMM-Sonos
                                [2026-04-06 09:08:06.356] [LOG]   [app] All module helpers loaded.
                                [2026-04-06 09:08:06.385] [LOG]   [server] Starting server on port 8080 ...
                                [2026-04-06 09:08:06.415] [ERROR] [unknown] (node:605210) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
                                (Use `electron --trace-deprecation ...` to show where the warning was created)
                                [2026-04-06 09:08:06.477] [LOG]   [app] Server started ...
                                [2026-04-06 09:08:06.480] [LOG]   [node_helper] Connecting socket for: updatenotification
                                [2026-04-06 09:08:06.481] [LOG]   [node_helper] Starting module helper: updatenotification
                                [2026-04-06 09:08:06.483] [LOG]   [node_helper] Connecting socket for: calendar
                                [2026-04-06 09:08:06.485] [LOG]   [calendar] Starting node helper for: calendar
                                [2026-04-06 09:08:06.486] [LOG]   [node_helper] Connecting socket for: weather
                                [2026-04-06 09:08:06.488] [LOG]   [weather] Starting node helper for: weather
                                [2026-04-06 09:08:06.490] [LOG]   [node_helper] Connecting socket for: newsfeed
                                [2026-04-06 09:08:06.491] [LOG]   [newsfeed] Starting node helper for: newsfeed
                                [2026-04-06 09:08:06.493] [LOG]   [node_helper] Connecting socket for: MMM-Sonos
                                [2026-04-06 09:08:06.495] [LOG]   [MMM-Sonos] Sonos helper started ...
                                [2026-04-06 09:08:06.496] [LOG]   [app] Sockets connected & modules started ...
                                error: XDG_RUNTIME_DIR is invalid or not set in the environment.
                                [605210:0406/090806.501637:ERROR:ui/ozone/platform/wayland/host/wayland_connection.cc:202] Failed to connect to Wayland display: No such file or directory (2)
                                [605210:0406/090806.502006:ERROR:ui/ozone/platform/wayland/ozone_platform_wayland.cc:281] Failed to initialize Wayland platform
                                [605210:0406/090806.502155:ERROR:ui/aura/env.cc:246] The platform failed to initialize.  Exiting.
                                DietPi v10.2.3 (I believe that is the latest version)
                                Email sent.
                                Thanks for all your help!
                                  sdetweil @jca2112
                                  @jca2112 ok edit the mm.sh
                                  and change
                                  npm start
                                  to
                                  npm run start:x11
                                  I know why… I fixed the script on saturday, but didn’t catch that on my mac I was on a different branch, so the master branch didn’t get updated til about 9pm central last night.
                                  I drove all day yesterday, and fixed it again on master…
                                    sdetweil @jca2112
                                    @jca2112 from the log,
                                    saved translations/en.json
                                    make sure you check on this change, as it was stashed but not re-applied…
                                    • jca2112J
                                      jca2112 @sdetweil
                                      @sdetweil Yup, it’s working now. Awesome, thank you so much.
                                      (The translations/en.json is just a single word change, so easy to fix manually without being stashed.)
