    MMM-Growatt module (API login and view)
    3 Posts 2 Posters 505 Views 2 Watching
    • N Offline
      nowayto
      I have a question for @mumblebaj.
      Kindly, is there a way to login with API key instead username+password method?
      I read that now API key doesn’t have the classic method’s frequency update limitations.
      It could be more useful to have “nearly live data” energy production.
      Another question, less important, is there a way to hide the grid from the “table” view?
      It’s not so important, I just like compact and minimal styles, when informations are more important than design itself.
      Thanks a lot
      mumblebajM 2 Replies Last reply Reply Quote 0
      • mumblebajM Offline
        mumblebaj Module Developer @nowayto
        @nowayto Hi. I see that the Growatt library now allows for key. I will need some time to update accordingly. If you would please log a feature request on the modules GitHub page.
        As for the table view, yes, you can remove the grid lines.
        .growatt-table td {
            border: none;
          @nowayto I have made changes to the module to accommodate the API key, however, when I tested it, it did not work for me.
          The Growatt NPM module states the following:
          You can get the key by having an email sent to you on the Grwatt website for a third party to display the data. The key is the combination of numbers and letters in the link. It has 96 characters.
          The API key I am seeing is much shorter than the 96 character key mentioned above and as a result I was getting a 500 error when I was testing it.
          This is obviously the wrong key.
          As such, I am reluctant to push changes I am unable to test successfully.
