    MMM-CalendarExt3 Resize module
    12 Posts 4 Posters 5.7k Views 4 Watching
      MMRIZE @Xsoldier2000
      @Xsoldier2000
      This module usually (and for your convenience), uses the whole width of the region that this module lays on. So, if you want to use 3/4 width of the entire screen, it will be easier to limit the width and location of the region itself. So, if you want to lay this module into top_center, guess how to expand and locate top_center region to 3/4 width from the right edge. (There could be many solution and condition, so I cannot point a silver bullet.)
        megagprime
        hey guys, i cant seem to figure out how to resize this module, i have tried the css, custom cssa and even modifying the module bottom.left css max size. how can i double the width?!2c853f08-d988-4582-a4de-4037442666bd-image.jpeg thank you
          sdetweil @megagprime
          @megagprime if you put the module in bottom bar it will resize.
          It fits in the area you place it
          M 3 Replies Last reply Reply Quote 0
            megagprime @sdetweil
            @sdetweil how can i make it twice as wide as it is?
              @sdetweil i have something in the bottom right
                @sdetweil i have something on the bottom right, i just want to double the width of bottom left module
                  @megagprime you will have to use position absolute and width
                  You can use the developers window elements tab to try it out.
                  See the second link in my sig below for an example on how to use the elements tab
                    @sdetweil i have done that, and even tried the module position module with custom css and it still will not work
                      @megagprime if you just put it in another position , it will be in that positions size, without custom.css
                      I am away from my system til late us central time tonight
                        @megagprime try this
                        module
                        position:"bottom_left",
                        no custom.css setting
                        custom.css
                        .MMM-CalendarExt3 .module-content {
                            width:175%;
                        adjust % as you need
