    multiple error in magic mirror after update from 2.28.0 to 2.36.0
    71 Posts 2 Posters 9.2k Views 2 Watching
      which means it THINKS you are running wayland…
      crtl-c in that window just to make sure its stopped
      if you do
      npm run start:x11
      does MM come up?
      if so, change the
      npm run start:wayland
      to
      npm run start:x11
      and then pm2 start MagicMirror
      1 1 Reply Last reply
        1a2a3a @sdetweil
        @sdetweil i have change mm.sh to
        if [ $(ps -ef | grep -v grep | grep -i -e xway -e labwc | wc -l) -ne 0 ]; then
           # if WAYLAND_DISPLAYis set, use it, else set to -0
           export WAYLAND_DISPLAY=${WAYLAND_DISPLAY:=wayland-0}
           npm run start:x11
        else
           DISPLAY=:0 npm run start:x11
        fi
        pm2 start Magicmirror does not start still
          sdetweil @1a2a3a
          @1a2a3a ok, lets reboot once
            1a2a3a @sdetweil
            @sdetweil ok done. same. black screen with mouse > wall paper > continue looping
            the funny thing is that when i do the bash, it works. just pm2 start doesnt.
              sdetweil @1a2a3a
              @1a2a3a ok, can you show the output of
              pm2 logs --lines=100
              1 2 Replies Last reply
                1a2a3a @sdetweil
                /home/hsa/.pm2/pm2.log last 100 lines:
                PM2        | 2026-05-02T01:40:40: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                PM2        | 2026-05-02T01:40:40: PM2 log: App [MagicMirror:0] starting in -fork mode-
                PM2        | 2026-05-02T01:40:40: PM2 log: App [MagicMirror:0] online
                PM2        | 2026-05-02T01:40:40: PM2 log: Script /home/hsa/MagicMirror/installers/mm.sh had too many unstable restarts (16). Stopped. "errored"
                PM2        | 2026-05-02T01:41:05: PM2 log: App [MagicMirror:0] starting in -fork mode-
                PM2        | 2026-05-02T01:41:05: PM2 log: App [MagicMirror:0] online
                PM2        | 2026-05-02T01:41:05: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                PM2        | 2026-05-02T01:41:05: PM2 log: Script /home/hsa/MagicMirror/installers/mm.sh had too many unstable restarts (16). Stopped. "errored"
                PM2        | 2026-05-02T01:44:14: PM2 log: App [MagicMirror:0] starting in -fork mode-
                PM2        | 2026-05-02T01:44:14: PM2 log: App [MagicMirror:0] online
                PM2        | 2026-05-02T01:44:37: PM2 log: Stopping app:MagicMirror id:0
                PM2        | 2026-05-02T01:44:52: PM2 error: Error: EIO: i/o error, write
                PM2        | 2026-05-02T01:44:52: PM2 log: pid=4701 msg=failed to kill - retrying in 100ms
                PM2        | 2026-05-02T01:44:53: PM2 log: pid=4701 msg=failed to kill - retrying in 100ms
                PM2        | 2026-05-02T01:44:53: PM2 log: Process with pid 4701 still alive after 1600ms, sending it SIGKILL now...
                PM2        | 2026-05-02T01:44:53: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGKILL]
                PM2        | 2026-05-02T01:44:54: PM2 log: pid=4701 msg=process killed
                /home/hsa/.pm2/logs/MagicMirror-error.log last 100 lines:
                0|MagicMir | /home/hsa/MagicMirror/node_modules/electron/dist/electron exited with signal SIGTRAP
                0|MagicMir | [2026-05-01 22:58:12.952] [ERROR] [unknown] (node:1972286) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
                0|MagicMir | (Use `electron --trace-deprecation ...` to show where the warning was created)
                0|MagicMir | [2026-05-01 22:59:26.457] [ERROR] [unknown] (node:1972654) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
                0|MagicMir | [2026-05-01 23:00:45.581] [ERROR] [unknown] (node:1972996) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
                0|MagicMir | [2026-05-01 23:00:51.435] [ERROR] [unknown] (node:1973259) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
                0|MagicMir | [2026-05-01 23:02:41.213] [ERROR] [unknown] (node:1973622) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
                0|MagicMir | [2026-05-01 23:02:47.007] [ERROR] [unknown] (node:1973926) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
                0|MagicMir | [2026-05-01 23:48:30.795] [ERROR] [unknown] (node:1978494) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
                0|MagicMir | [2026-05-01 23:56:37.164] [ERROR] [unknown] (node:1979751) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
                0|MagicMir | [2026-05-01 23:57:50.550] [ERROR] [unknown] (node:1980093) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
                0|MagicMir | [2026-05-02 00:35:18.202] [ERROR] [unknown] (node:1986797) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
                0|MagicMir | [2026-05-02 00:36:30.821] [ERROR] [unknown] (node:1987135) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
                0|MagicMir | [2026-05-02 00:37:43.066] [ERROR] [unknown] (node:1987721) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
                0|MagicMir | [2026-05-02 00:38:56.786] [ERROR] [unknown] (node:1988072) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
                0|MagicMir | [2026-05-02 00:40:10.172] [ERROR] [unknown] (node:1988442) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
                0|MagicMir | [2026-05-02 00:41:23.991] [ERROR] [unknown] (node:1988801) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
                0|MagicMir | [2026-05-02 00:42:37.723] [ERROR] [unknown] (node:1989164) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
                0|MagicMir | [2026-05-02 00:43:50.993] [ERROR] [unknown] (node:1989673) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
                0|MagicMir | [2026-05-02 01:01:40.022] [ERROR] [unknown] (node:1991891) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
                0|MagicMir | [2026-05-02 01:02:52.189] [ERROR] [unknown] (node:1992235) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
                0|MagicMir | [2026-05-02 01:04:42.831] [ERROR] [unknown] (node:1992608) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
                0|MagicMir | [2026-05-02 01:04:48.383] [ERROR] [unknown] (node:1992913) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
                0|MagicMir | [2026-05-02 01:06:00.472] [ERROR] [unknown] (node:1993256) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
                0|MagicMir | [2026-05-02 01:07:12.592] [ERROR] [unknown] (node:1993598) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
                0|MagicMir | [2026-05-02 01:08:25.975] [ERROR] [unknown] (node:1993969) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
                0|MagicMir | [2026-05-02 01:09:39.688] [ERROR] [unknown] (node:1994320) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
                0|MagicMir | [2026-05-02 01:10:53.313] [ERROR] [unknown] (node:1994688) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
                0|MagicMir | [2026-05-02 01:13:18.207] [ERROR] [unknown] (node:1995430) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
                0|MagicMir | [2026-05-02 01:14:30.831] [ERROR] [unknown] (node:1995781) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
                0|MagicMir | [2026-05-02 01:27:17.967] [ERROR] [unknown] (node:1998078) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
                0|MagicMir | [2026-05-02 01:31:48.948] [ERROR] [unknown] (node:1998975) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
                0|MagicMir | [2026-05-02 01:31:54.952] [ERROR] [unknown] (node:1999283) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
                0|MagicMir | [2026-05-02 01:36:40.810] [ERROR] [unknown] (node:2153) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
                0|MagicMir | [2026-05-02 01:36:53.372] [ERROR] [unknown] (node:3319) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
                0|MagicMir | [2026-05-02 01:38:13.968] [ERROR] [unknown] (node:3697) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
                0|MagicMir | [2026-05-02 01:39:57.114] [ERROR] [unknown] (node:4016) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
                0|MagicMir | /home/hsa/MagicMirror/installers/mm.sh: line 2: $'\r': command not found
                0|MagicMir | /home/hsa/MagicMirror/installers/mm.sh: line 3: cd: $'/home/hsa/MagicMirror\r': No such file or directory
                0|MagicMir | [2026-05-02 01:44:16.815] [ERROR] [unknown] (node:4725) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
                  1a2a3a @sdetweil
                  @sdetweil does this needs to be fix?
                  (node:5692) [DEP0044] DeprecationWarning: The `util.isArray` API is deprecated. Please use `Array.isArray()` instead.
                  (Use `node --trace-deprecation ...` to show where the warning was created)
                    sdetweil @1a2a3a
                    @1a2a3a said:
                    0|MagicMir | /home/hsa/MagicMirror/installers/mm.sh: line 2: $‘\r’: command not found
                    0|MagicMir | /home/hsa/MagicMirror/installers/mm.sh: line 3: cd: $‘/home/hsa/MagicMirror\r’: No such file or directory
                    are you on windows??
                    it added a carriage return to lines 2 and 3… please remove… the script failed, and pm2s JOB is to keep it running
                    pm2 status will show you the restart count
                    | id │ name                │ namespace   │ version │ mode    │ pid      │ uptime │ ↺    │ status    │ cpu      │ mem      │ user     │ watching │
                    │ 8  │ MagicMirror         │ default     │ 2.32.0… │ fork    │ N/A      │ 0      │ 245… │ stopped   │ 0%       │ 0b       │ sam      │ disabled │
                    the circle arrow next to uptime, is number of restarts
                      sdetweil @1a2a3a
                      @1a2a3a
                      API is deprecated. Please use Array.isArray() instead.
                      same as punycode
                      up to the module author
                        1a2a3a @sdetweil
                        @sdetweil im on rpi5, ssh from a windows. where do i remove the lines?
                          sdetweil @1a2a3a
                          @1a2a3a in some editor… you might see them in nano
                          cd ~/MagicMirror/installers
                          nano mm.sh
                          use arrow keys to move around, delete to remove, ins to be able to insert
                          when done
                          ctrl-o
                          to save
                          ctrl-x to exit
                          if you don’t want to save
                          ctrl-x and reply n
                            1a2a3a @sdetweil
                            @sdetweil i dont see the lines in mm.sh…
                              sdetweil @1a2a3a
                              @1a2a3a
                              cat mm.sh
                                1a2a3a @sdetweil
                                hsa@HSA:~/MagicMirror/installers $ cat mm.sh
                                #!/bin/bash
                                  sdetweil @1a2a3a
                                  @1a2a3a ok, thats not my mm.sh which you supposedly saved
                                  but
                                  nano mm.sh
                                  remove the blank line 2
                                  and go to the end of new line 2 and if the cursor is not after the last character, hit backspace,
                                  then ctrl-o to save
                                  and ctrl-x to exit nano
                                    1a2a3a @sdetweil
                                    @sdetweil edited to your mm.sh but same result
                                    #!/bin/bash
                                    else
                                    fi
                                      sdetweil @1a2a3a
                                      @1a2a3a are you sure this is the script listed in pm2 info output?
                                        1a2a3a @sdetweil
                                        status │ errored │
                                        │ name │ MagicMirror │
                                        │ namespace │ default │
                                        │ version │ 2.36.0 │
                                        │ restarts │ 45 │
                                        │ uptime │ 0 │
                                        │ script path │ /home/hsa/MagicMirror/installers/mm.sh │
                                        │ script args │ N/A │
                                        │ error log path │ /home/hsa/.pm2/logs/MagicMirror-error.log │
                                        │ out log path │ /home/hsa/.pm2/logs/MagicMirror-out.log │
                                        │ pid path │ /home/hsa/.pm2/pids/MagicMirror-0.pid │
                                        │ interpreter │ bash │
                                        │ interpreter args │ N/A │
                                        │ script id │ 0 │
                                        │ exec cwd │ /home/hsa/MagicMirror │
                                        │ exec mode │ fork_mode │
                                        │ node.js version │ N/A │
                                        │ node env │ N/A │
                                        │ watch & reload │ ✘ │
                                        │ unstable restarts │ 0 │
                                        │ created at │ N/A
                                          sdetweil @1a2a3a
                                          weird… do this
                                          curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/refs/heads/master/mm.sh >mm.sh
                                          then do the
                                          pm2 stop all
                                            1a2a3a @sdetweil
                                            done, but mirror no response or whatsoever
                                            hsa@HSA:~ $ cd ~/MagicMirror/installers
                                            hsa@HSA:~/MagicMirror/installers $ curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/refs/heads/master/mm.sh >mm.sh
                                            hsa@HSA:~/MagicMirror/installers $ pm2 stop all
                                            (node:10682) [DEP0044] DeprecationWarning: The `util.isArray` API is deprecated. Please use `Array.isArray()` instead.
                                            [PM2] Applying action stopProcessId on app [all](ids: [ 0 ])
                                            [PM2] [all](0) ✓
                                            │ id │ name               │ mode     │ ↺    │ status    │ cpu      │ memory   │
                                            │ 0  │ MagicMirror        │ fork     │ 45   │ stopped   │ 0%       │ 0b       │
                                            hsa@HSA:~/MagicMirror/installers $ pm2 start MagicMirror
                                            (node:10691) [DEP0044] DeprecationWarning: The `util.isArray` API is deprecated. Please use `Array.isArray()` instead.
                                            [PM2] Applying action restartProcessId on app [MagicMirror](ids: [ 0 ])
                                            [PM2] [MagicMirror](0) ✓
                                            [PM2] Process successfully started
                                            │ 0  │ MagicMirror        │ fork     │ 45   │ online    │ 0%       │ 2.7mb    │
                                            • 3 / 4
