    multiple error in magic mirror after update from 2.28.0 to 2.36.0
    71 Posts 2 Posters 8.4k Views 2 Watching
    • 1 Offline
      1a2a3a @sdetweil
      @sdetweil did not manage to open MM
      > magicmirror@2.36.0 start:wayland
      > WAYLAND_DISPLAY="${WAYLAND_DISPLAY:=wayland-1}" ./node_modules/.bin/electron js/electron.js --ozone-platform=wayland
      [2026-05-02 02:39:50.838] [LOG]   [app] Starting MagicMirror: v2.36.0
      [2026-05-02 02:39:50.845] [LOG]   [utils] Loading config ...
      [2026-05-02 02:39:51.547] [INFO]  [systeminformation]
      ####  System Information  ####
      - SYSTEM:   manufacturer: Raspberry Pi Foundation; model: Raspberry Pi 5 Model B Rev 1.0; virtual: false; MM: v2.36.0
      - OS:       platform: linux; distro: Debian GNU/Linux; release: 12; arch: arm64; kernel: 6.12.75+rpt-rpi-2712
      - VERSIONS: electron: 41.3.0; used node: 22.21.1; installed node: 22.21.1; npm: 10.9.4; pm2: 6.0.14
      - ENV:      XDG_SESSION_TYPE: tty; MM_CONFIG_FILE: undefined
                  WAYLAND_DISPLAY:  wayland-0; DISPLAY: undefined; ELECTRON_ENABLE_GPU: undefined
      - RAM:      total: 8059.06 MB; free: 6932.14 MB; used: 1126.92 MB
      - OTHERS:   uptime: 65 minutes; timeZone: Asia/Singapore
      [2026-05-02 02:40:04.644] [INFO]  [utils] Checking config file /home/hsa/MagicMirror/config/config.js ...
      [2026-05-02 02:40:04.720] [INFO]  [utils] Your configuration file doesn't contain syntax errors :)
      [2026-05-02 02:40:04.721] [INFO]  [utils] Checking modules structure configuration ...
      [2026-05-02 02:40:04.787] [INFO]  [utils] Your modules structure configuration doesn't contain errors :)
      [2026-05-02 02:40:04.788] [LOG]   [app] Loading module helpers ...
      [2026-05-02 02:40:04.788] [LOG]   [app] No helper found for module: alert.
      [2026-05-02 02:40:04.790] [LOG]   [node_helper] Initializing new module helper ...
      [2026-05-02 02:40:04.791] [LOG]   [node_helper] Module helper loaded: updatenotification
      [2026-05-02 02:40:04.791] [LOG]   [app] No helper found for module: clock.
      [2026-05-02 02:40:04.891] [LOG]   [node_helper] Initializing new module helper ...
      [2026-05-02 02:40:04.891] [LOG]   [node_helper] Module helper loaded: MMM-Jast
      [2026-05-02 02:40:05.554] [LOG]   [node_helper] Initializing new module helper ...
      [2026-05-02 02:40:05.555] [LOG]   [node_helper] Module helper loaded: MMM-GoogleDocs-Notes
      [2026-05-02 02:40:05.580] [LOG]   [node_helper] Initializing new module helper ...
      [2026-05-02 02:40:05.580] [LOG]   [node_helper] Module helper loaded: newsfeed
      [2026-05-02 02:40:05.586] [LOG]   [node_helper] Initializing new module helper ...
      [2026-05-02 02:40:05.586] [LOG]   [app] Check MagicMirror² version for node helper 'MMM-NewsAPI' - Minimum version: 2.21.0 - Current version: 2.36.0
      [2026-05-02 02:40:05.587] [LOG]   [app] Version is ok!
      [2026-05-02 02:40:05.587] [LOG]   [node_helper] Module helper loaded: MMM-NewsAPI
      [2026-05-02 02:40:05.588] [LOG]   [node_helper] Initializing new module helper ...
      [2026-05-02 02:40:05.588] [LOG]   [node_helper] Module helper loaded: MMM-MyScoreboard
      [2026-05-02 02:40:05.595] [LOG]   [node_helper] Initializing new module helper ...
      [2026-05-02 02:40:05.595] [LOG]   [app] Check MagicMirror² version for node helper 'MMM-SoccerLiveScore' - Minimum version: 2.1.0 - Current version: 2.36.0
      [2026-05-02 02:40:05.595] [LOG]   [app] Version is ok!
      [2026-05-02 02:40:05.595] [LOG]   [node_helper] Module helper loaded: MMM-SoccerLiveScore
      [2026-05-02 02:40:05.688] [LOG]   [node_helper] Initializing new module helper ...
      [2026-05-02 02:40:05.688] [LOG]   [node_helper] Module helper loaded: MMM-OneDrive
      [2026-05-02 02:40:05.689] [LOG]   [node_helper] Initializing new module helper ...
      [2026-05-02 02:40:05.689] [LOG]   [node_helper] Module helper loaded: MMM-CalendarExt3Agenda
      [2026-05-02 02:40:05.746] [LOG]   [node_helper] Initializing new module helper ...
      [2026-05-02 02:40:05.746] [LOG]   [node_helper] Module helper loaded: calendar
      [2026-05-02 02:40:05.747] [LOG]   [node_helper] Initializing new module helper ...
      [2026-05-02 02:40:05.747] [LOG]   [node_helper] Module helper loaded: MMM-CalendarExt3
      [2026-05-02 02:40:05.747] [LOG]   [app] All module helpers loaded.
      [2026-05-02 02:40:05.751] [LOG]   [server] Starting server on port 8080 ...
      [2026-05-02 02:40:05.760] [ERROR] [unknown] (node:13239) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
      (Use `electron --trace-deprecation ...` to show where the warning was created)
      [13239:0502/024005.762036:ERROR:ui/ozone/platform/wayland/host/wayland_connection.cc:202] Failed to connect to Wayland display: No such file or directory (2)
      [13239:0502/024005.762106:ERROR:ui/ozone/platform/wayland/ozone_platform_wayland.cc:281] Failed to initialize Wayland platform
      [13239:0502/024005.762122:ERROR:ui/aura/env.cc:246] The platform failed to initialize.  Exiting.
      /home/hsa/MagicMirror/node_modules/electron/dist/electron exited with signal SIGSEGV
      hsa@HSA:~/MagicMirror $
        sdetweil @1a2a3a
        @1a2a3a ok, it still thinks wayland is active.
        nano  installers/mm.sh
        change line
          if [ $(ps -ef | grep -v grep | grep -i -e xway -e labwc | wc -l) -ne 0 ]; then
        to
          if [ $(ps -ef | grep -v grep | grep -i -e xway -e labwc | wc -l) -ne 1 ]; then
        ctrl-o,
        enter
        ctrl-x
        then
        installers/mm.sh
        1 1 Reply Last reply Reply Quote 0
        • 1 Offline
          1a2a3a @sdetweil
          @sdetweil ok it runs now. what do i do next?
          edit sorry obviously stupid. just pm2 start and we are GOLD :D
          thanks again!
            sdetweil @1a2a3a
            @1a2a3a yeh, weird tho
            can you show me output of
            lsb_release -a
            uname -a
            weird it thinks wayland, but won’t run that way
            • 1 Offline
              1a2a3a @sdetweil
              hsa@HSA:~/MagicMirror $ lsb_release -a
              No LSB modules are available.
              Distributor ID: Debian
              Description:    Debian GNU/Linux 12 (bookworm)
              Release:        12
              Codename:       bookworm
              hsa@HSA:~/MagicMirror $ uname -a
              Linux HSA 6.12.75+rpt-rpi-2712 #1 SMP PREEMPT Debian 1:6.12.75-1+rpt1~bookworm (2026-03-11) aarch64 GNU/Linux
              S 1 2 Replies Last reply Reply Quote 0
                sdetweil @1a2a3a
                @1a2a3a thanks…
                • 1 Offline
                  1a2a3a @1a2a3a
                  @sdetweil dont know man, gets even weirder.
                  i cant turn on mm using the terminal on the pi directly.
                  i tried npm run start:x11 and it will just close off with a /home/hsa/MagicMirror/node_modules/electron/dist/electron exited with signal SIGSEGV
                  i can now only turn on my mm using pm2 on my ssh terminal…
                  btw i have a cron job, not sure if this is causing the issue
                  crontab -e
                  38 00 * * * /home/HSA/display_on.sh
                  37 00 * * * /home/HSA/display_off.sh
                  display_off.sh
                  #!/bin/bash
                  export WAYLAND_DISPLAY=wayland-1
                  export XDG_RUNTIME_DIR=/run/user/1000
                  /usr/bin/wlr-randr --output HDMI-A-2 --off
                  display_on.sh
                  #!/bin/bash
                  /usr/bin/wlr-randr --output HDMI-A-2 --on --transform 90
                    sdetweil @1a2a3a
                    @1a2a3a yeh… weird indeed… those scripts are wayland based…
                    ok, open a new terminal window
                    and do
                    env
                    to dump out the environment variables…
                    check to make sure none expose any info you don’t want shown here and paste the cleaned list
                    • 1 Offline
                      1a2a3a @sdetweil
                      @sdetweil uhm which are the info that are sensitive?
                      so im actually wayland instead of x11?
                        sdetweil @1a2a3a
                        @1a2a3a sensitive
                        name, address, zipcode, apikeys, passwords…
                        • 1 Offline
                          1a2a3a @sdetweil
                          @sdetweil this safe?
                          SHELL=/bin/bash
                          LANGUAGE=en_US.UTF-8
                          NO_AT_BRIDGE=1
                          XDG_SESSION_TYPE=tty
                          MOTD_SHOWN=pam
                          LANG=en_US.UTF-8
                          LS_COLORS=rs=0:di=01;34:ln=01;36:mh=00:pi=40;33:so=01;35:do=01;35:bd=40;33;01:cd=40;33;01:or=40;31;01:mi=00:su=37;41:sg=30;43:ca=00:tw=30;42:ow=34;42:st=37;44:ex=01;32:*.tar=01;31:*.tgz=01;31:*.arc=01;31:*.arj=01;31:*.taz=01;31:*.lha=01;31:*.lz4=01;31:*.lzh=01;31:*.lzma=01;31:*.tlz=01;31:*.txz=01;31:*.tzo=01;31:*.t7z=01;31:*.zip=01;31:*.z=01;31:*.dz=01;31:*.gz=01;31:*.lrz=01;31:*.lz=01;31:*.lzo=01;31:*.xz=01;31:*.zst=01;31:*.tzst=01;31:*.bz2=01;31:*.bz=01;31:*.tbz=01;31:*.tbz2=01;31:*.tz=01;31:*.deb=01;31:*.rpm=01;31:*.jar=01;31:*.war=01;31:*.ear=01;31:*.sar=01;31:*.rar=01;31:*.alz=01;31:*.ace=01;31:*.zoo=01;31:*.cpio=01;31:*.7z=01;31:*.rz=01;31:*.cab=01;31:*.wim=01;31:*.swm=01;31:*.dwm=01;31:*.esd=01;31:*.avif=01;35:*.jpg=01;35:*.jpeg=01;35:*.mjpg=01;35:*.mjpeg=01;35:*.gif=01;35:*.bmp=01;35:*.pbm=01;35:*.pgm=01;35:*.ppm=01;35:*.tga=01;35:*.xbm=01;35:*.xpm=01;35:*.tif=01;35:*.tiff=01;35:*.png=01;35:*.svg=01;35:*.svgz=01;35:*.mng=01;35:*.pcx=01;35:*.mov=01;35:*.mpg=01;35:*.mpeg=01;35:*.m2v=01;35:*.mkv=01;35:*.webm=01;35:*.webp=01;35:*.ogm=01;35:*.mp4=01;35:*.m4v=01;35:*.mp4v=01;35:*.vob=01;35:*.qt=01;35:*.nuv=01;35:*.wmv=01;35:*.asf=01;35:*.rm=01;35:*.rmvb=01;35:*.flc=01;35:*.avi=01;35:*.fli=01;35:*.flv=01;35:*.gl=01;35:*.dl=01;35:*.xcf=01;35:*.xwd=01;35:*.yuv=01;35:*.cgm=01;35:*.emf=01;35:*.ogv=01;35:*.ogx=01;35:*.aac=00;36:*.au=00;36:*.flac=00;36:*.m4a=00;36:*.mid=00;36:*.midi=00;36:*.mka=00;36:*.mp3=00;36:*.mpc=00;36:*.ogg=00;36:*.ra=00;36:*.wav=00;36:*.oga=00;36:*.opus=00;36:*.spx=00;36:*.xspf=00;36:*~=00;90:*#=00;90:*.bak=00;90:*.old=00;90:*.orig=00;90:*.part=00;90:*.rej=00;90:*.swp=00;90:*.tmp=00;90:*.dpkg-dist=00;90:*.dpkg-old=00;90:*.ucf-dist=00;90:*.ucf-new=00;90:*.ucf-old=00;90:*.rpmnew=00;90:*.rpmorig=00;90:*.rpmsave=00;90:
                          XDG_SESSION_CLASS=user
                          TERM=xterm
                          SHLVL=1
                          XDG_SESSION_ID=6
                          LC_ALL=en_US.UTF-8
                          DBUS_SESSION_BUS_ADDRESS=unix:path=/run/user/1000/bus
                          SSH_TTY=/dev/pts/0
                          _=/usr/bin/env
                            sdetweil @1a2a3a
                            @1a2a3a yeh, fine, but no wayland info there
                            I see a diff on my mm.sh
                            if wayland_display is not set, then I set it to
                            WAYLAND_DISPLAY=wayland-0
                            but your scripts use wayland-1
                            SO, lets try this
                            edit mm.sh again
                            change this line
                            back to
                            and change this line
                            export WAYLAND_DISPLAY=${WAYLAND_DISPLAY:=wayland-0}
                            to
                            export WAYLAND_DISPLAY=${WAYLAND_DISPLAY:=wayland-1}
                            and save mm.sh
                            then
                            pm2 stop all
                            pm2 start MagicMirror
                            • 1 Offline
                              1a2a3a @sdetweil
                              @sdetweil it worked! is that your expectation?
                                sdetweil @1a2a3a
                                @1a2a3a yes…
                                all should be good now
                                • 1 Offline
                                  1a2a3a @sdetweil
                                  @sdetweil many thanks for your help once again sam!
                                  • 4 / 4
