    multiple error in magic mirror after update from 2.28.0 to 2.36.0
    71 Posts 2 Posters 9.2k Views 2 Watching
      sdetweil @1a2a3a
      @1a2a3a
      pm2 stop all
      installers/mm.sh
      1 1 Reply Last reply
        1a2a3a @sdetweil
        @sdetweil did not manage to open MM
        > magicmirror@2.36.0 start:wayland
        > WAYLAND_DISPLAY="${WAYLAND_DISPLAY:=wayland-1}" ./node_modules/.bin/electron js/electron.js --ozone-platform=wayland
        [2026-05-02 02:39:50.838] [LOG]   [app] Starting MagicMirror: v2.36.0
        [2026-05-02 02:39:50.845] [LOG]   [utils] Loading config ...
        [2026-05-02 02:39:51.547] [INFO]  [systeminformation]
        ####  System Information  ####
        - SYSTEM:   manufacturer: Raspberry Pi Foundation; model: Raspberry Pi 5 Model B Rev 1.0; virtual: false; MM: v2.36.0
        - OS:       platform: linux; distro: Debian GNU/Linux; release: 12; arch: arm64; kernel: 6.12.75+rpt-rpi-2712
        - VERSIONS: electron: 41.3.0; used node: 22.21.1; installed node: 22.21.1; npm: 10.9.4; pm2: 6.0.14
        - ENV:      XDG_SESSION_TYPE: tty; MM_CONFIG_FILE: undefined
                    WAYLAND_DISPLAY:  wayland-0; DISPLAY: undefined; ELECTRON_ENABLE_GPU: undefined
        - RAM:      total: 8059.06 MB; free: 6932.14 MB; used: 1126.92 MB
        - OTHERS:   uptime: 65 minutes; timeZone: Asia/Singapore
        [2026-05-02 02:40:04.644] [INFO]  [utils] Checking config file /home/hsa/MagicMirror/config/config.js ...
        [2026-05-02 02:40:04.720] [INFO]  [utils] Your configuration file doesn't contain syntax errors :)
        [2026-05-02 02:40:04.721] [INFO]  [utils] Checking modules structure configuration ...
        [2026-05-02 02:40:04.787] [INFO]  [utils] Your modules structure configuration doesn't contain errors :)
        [2026-05-02 02:40:04.788] [LOG]   [app] Loading module helpers ...
        [2026-05-02 02:40:04.788] [LOG]   [app] No helper found for module: alert.
        [2026-05-02 02:40:04.790] [LOG]   [node_helper] Initializing new module helper ...
        [2026-05-02 02:40:04.791] [LOG]   [node_helper] Module helper loaded: updatenotification
        [2026-05-02 02:40:04.791] [LOG]   [app] No helper found for module: clock.
        [2026-05-02 02:40:04.891] [LOG]   [node_helper] Initializing new module helper ...
        [2026-05-02 02:40:04.891] [LOG]   [node_helper] Module helper loaded: MMM-Jast
        [2026-05-02 02:40:05.554] [LOG]   [node_helper] Initializing new module helper ...
        [2026-05-02 02:40:05.555] [LOG]   [node_helper] Module helper loaded: MMM-GoogleDocs-Notes
        [2026-05-02 02:40:05.580] [LOG]   [node_helper] Initializing new module helper ...
        [2026-05-02 02:40:05.580] [LOG]   [node_helper] Module helper loaded: newsfeed
        [2026-05-02 02:40:05.586] [LOG]   [node_helper] Initializing new module helper ...
        [2026-05-02 02:40:05.586] [LOG]   [app] Check MagicMirror² version for node helper 'MMM-NewsAPI' - Minimum version: 2.21.0 - Current version: 2.36.0
        [2026-05-02 02:40:05.587] [LOG]   [app] Version is ok!
        [2026-05-02 02:40:05.587] [LOG]   [node_helper] Module helper loaded: MMM-NewsAPI
        [2026-05-02 02:40:05.588] [LOG]   [node_helper] Initializing new module helper ...
        [2026-05-02 02:40:05.588] [LOG]   [node_helper] Module helper loaded: MMM-MyScoreboard
        [2026-05-02 02:40:05.595] [LOG]   [node_helper] Initializing new module helper ...
        [2026-05-02 02:40:05.595] [LOG]   [app] Check MagicMirror² version for node helper 'MMM-SoccerLiveScore' - Minimum version: 2.1.0 - Current version: 2.36.0
        [2026-05-02 02:40:05.595] [LOG]   [app] Version is ok!
        [2026-05-02 02:40:05.595] [LOG]   [node_helper] Module helper loaded: MMM-SoccerLiveScore
        [2026-05-02 02:40:05.688] [LOG]   [node_helper] Initializing new module helper ...
        [2026-05-02 02:40:05.688] [LOG]   [node_helper] Module helper loaded: MMM-OneDrive
        [2026-05-02 02:40:05.689] [LOG]   [node_helper] Initializing new module helper ...
        [2026-05-02 02:40:05.689] [LOG]   [node_helper] Module helper loaded: MMM-CalendarExt3Agenda
        [2026-05-02 02:40:05.746] [LOG]   [node_helper] Initializing new module helper ...
        [2026-05-02 02:40:05.746] [LOG]   [node_helper] Module helper loaded: calendar
        [2026-05-02 02:40:05.747] [LOG]   [node_helper] Initializing new module helper ...
        [2026-05-02 02:40:05.747] [LOG]   [node_helper] Module helper loaded: MMM-CalendarExt3
        [2026-05-02 02:40:05.747] [LOG]   [app] All module helpers loaded.
        [2026-05-02 02:40:05.751] [LOG]   [server] Starting server on port 8080 ...
        [2026-05-02 02:40:05.760] [ERROR] [unknown] (node:13239) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
        (Use `electron --trace-deprecation ...` to show where the warning was created)
        [13239:0502/024005.762036:ERROR:ui/ozone/platform/wayland/host/wayland_connection.cc:202] Failed to connect to Wayland display: No such file or directory (2)
        [13239:0502/024005.762106:ERROR:ui/ozone/platform/wayland/ozone_platform_wayland.cc:281] Failed to initialize Wayland platform
        [13239:0502/024005.762122:ERROR:ui/aura/env.cc:246] The platform failed to initialize.  Exiting.
        /home/hsa/MagicMirror/node_modules/electron/dist/electron exited with signal SIGSEGV
        hsa@HSA:~/MagicMirror $
          sdetweil @1a2a3a
          @1a2a3a ok, it still thinks wayland is active.
          nano  installers/mm.sh
          change line
            if [ $(ps -ef | grep -v grep | grep -i -e xway -e labwc | wc -l) -ne 0 ]; then
          to
            if [ $(ps -ef | grep -v grep | grep -i -e xway -e labwc | wc -l) -ne 1 ]; then
          ctrl-o,
          enter
          ctrl-x
          then
          installers/mm.sh
            1a2a3a @sdetweil
            @sdetweil ok it runs now. what do i do next?
            edit sorry obviously stupid. just pm2 start and we are GOLD :D
            thanks again!
              sdetweil @1a2a3a
              @1a2a3a yeh, weird tho
              can you show me output of
              lsb_release -a
              uname -a
              weird it thinks wayland, but won’t run that way
                1a2a3a @sdetweil
                hsa@HSA:~/MagicMirror $ lsb_release -a
                No LSB modules are available.
                Distributor ID: Debian
                Description:    Debian GNU/Linux 12 (bookworm)
                Release:        12
                Codename:       bookworm
                hsa@HSA:~/MagicMirror $ uname -a
                Linux HSA 6.12.75+rpt-rpi-2712 #1 SMP PREEMPT Debian 1:6.12.75-1+rpt1~bookworm (2026-03-11) aarch64 GNU/Linux
                S 1 2 Replies Last reply
                  sdetweil @1a2a3a
                  @1a2a3a thanks…
                    1a2a3a @1a2a3a
                    @sdetweil dont know man, gets even weirder.
                    i cant turn on mm using the terminal on the pi directly.
                    i tried npm run start:x11 and it will just close off with a /home/hsa/MagicMirror/node_modules/electron/dist/electron exited with signal SIGSEGV
                    i can now only turn on my mm using pm2 on my ssh terminal…
                    btw i have a cron job, not sure if this is causing the issue
                    crontab -e
                    38 00 * * * /home/HSA/display_on.sh
                    37 00 * * * /home/HSA/display_off.sh
                    display_off.sh
                    #!/bin/bash
                    export WAYLAND_DISPLAY=wayland-1
                    export XDG_RUNTIME_DIR=/run/user/1000
                    /usr/bin/wlr-randr --output HDMI-A-2 --off
                    display_on.sh
                    #!/bin/bash
                    /usr/bin/wlr-randr --output HDMI-A-2 --on --transform 90
                      sdetweil @1a2a3a
                      @1a2a3a yeh… weird indeed… those scripts are wayland based…
                      ok, open a new terminal window
                      and do
                      env
                      to dump out the environment variables…
                      check to make sure none expose any info you don’t want shown here and paste the cleaned list
                        1a2a3a @sdetweil
                        @sdetweil uhm which are the info that are sensitive?
                        so im actually wayland instead of x11?
                          sdetweil @1a2a3a
                          @1a2a3a sensitive
                          name, address, zipcode, apikeys, passwords…
                            1a2a3a @sdetweil
                            @sdetweil this safe?
                            SHELL=/bin/bash
                            LANGUAGE=en_US.UTF-8
                            NO_AT_BRIDGE=1
                            XDG_SESSION_TYPE=tty
                            MOTD_SHOWN=pam
                            LANG=en_US.UTF-8
                            LS_COLORS=rs=0:di=01;34:ln=01;36:mh=00:pi=40;33:so=01;35:do=01;35:bd=40;33;01:cd=40;33;01:or=40;31;01:mi=00:su=37;41:sg=30;43:ca=00:tw=30;42:ow=34;42:st=37;44:ex=01;32:*.tar=01;31:*.tgz=01;31:*.arc=01;31:*.arj=01;31:*.taz=01;31:*.lha=01;31:*.lz4=01;31:*.lzh=01;31:*.lzma=01;31:*.tlz=01;31:*.txz=01;31:*.tzo=01;31:*.t7z=01;31:*.zip=01;31:*.z=01;31:*.dz=01;31:*.gz=01;31:*.lrz=01;31:*.lz=01;31:*.lzo=01;31:*.xz=01;31:*.zst=01;31:*.tzst=01;31:*.bz2=01;31:*.bz=01;31:*.tbz=01;31:*.tbz2=01;31:*.tz=01;31:*.deb=01;31:*.rpm=01;31:*.jar=01;31:*.war=01;31:*.ear=01;31:*.sar=01;31:*.rar=01;31:*.alz=01;31:*.ace=01;31:*.zoo=01;31:*.cpio=01;31:*.7z=01;31:*.rz=01;31:*.cab=01;31:*.wim=01;31:*.swm=01;31:*.dwm=01;31:*.esd=01;31:*.avif=01;35:*.jpg=01;35:*.jpeg=01;35:*.mjpg=01;35:*.mjpeg=01;35:*.gif=01;35:*.bmp=01;35:*.pbm=01;35:*.pgm=01;35:*.ppm=01;35:*.tga=01;35:*.xbm=01;35:*.xpm=01;35:*.tif=01;35:*.tiff=01;35:*.png=01;35:*.svg=01;35:*.svgz=01;35:*.mng=01;35:*.pcx=01;35:*.mov=01;35:*.mpg=01;35:*.mpeg=01;35:*.m2v=01;35:*.mkv=01;35:*.webm=01;35:*.webp=01;35:*.ogm=01;35:*.mp4=01;35:*.m4v=01;35:*.mp4v=01;35:*.vob=01;35:*.qt=01;35:*.nuv=01;35:*.wmv=01;35:*.asf=01;35:*.rm=01;35:*.rmvb=01;35:*.flc=01;35:*.avi=01;35:*.fli=01;35:*.flv=01;35:*.gl=01;35:*.dl=01;35:*.xcf=01;35:*.xwd=01;35:*.yuv=01;35:*.cgm=01;35:*.emf=01;35:*.ogv=01;35:*.ogx=01;35:*.aac=00;36:*.au=00;36:*.flac=00;36:*.m4a=00;36:*.mid=00;36:*.midi=00;36:*.mka=00;36:*.mp3=00;36:*.mpc=00;36:*.ogg=00;36:*.ra=00;36:*.wav=00;36:*.oga=00;36:*.opus=00;36:*.spx=00;36:*.xspf=00;36:*~=00;90:*#=00;90:*.bak=00;90:*.old=00;90:*.orig=00;90:*.part=00;90:*.rej=00;90:*.swp=00;90:*.tmp=00;90:*.dpkg-dist=00;90:*.dpkg-old=00;90:*.ucf-dist=00;90:*.ucf-new=00;90:*.ucf-old=00;90:*.rpmnew=00;90:*.rpmorig=00;90:*.rpmsave=00;90:
                            XDG_SESSION_CLASS=user
                            TERM=xterm
                            SHLVL=1
                            XDG_SESSION_ID=6
                            LC_ALL=en_US.UTF-8
                            DBUS_SESSION_BUS_ADDRESS=unix:path=/run/user/1000/bus
                            SSH_TTY=/dev/pts/0
                            _=/usr/bin/env
                              sdetweil @1a2a3a
                              @1a2a3a yeh, fine, but no wayland info there
                              I see a diff on my mm.sh
                              if wayland_display is not set, then I set it to
                              WAYLAND_DISPLAY=wayland-0
                              but your scripts use wayland-1
                              SO, lets try this
                              edit mm.sh again
                              change this line
                              back to
                              and change this line
                              export WAYLAND_DISPLAY=${WAYLAND_DISPLAY:=wayland-0}
                              to
                              export WAYLAND_DISPLAY=${WAYLAND_DISPLAY:=wayland-1}
                              and save mm.sh
                              then
                              pm2 stop all
                              pm2 start MagicMirror
                                1a2a3a @sdetweil
                                @sdetweil it worked! is that your expectation?
                                  sdetweil @1a2a3a
                                  @1a2a3a yes…
                                  all should be good now
                                    1a2a3a @sdetweil
                                    @sdetweil many thanks for your help once again sam!
                                    • 4 / 4
