    multiple error in magic mirror after update from 2.28.0 to 2.36.0
    71 Posts 2 Posters 9.2k Views 2 Watching
      1a2a3a @sdetweil
      @sdetweil edited to your mm.sh but same result
      hsa@HSA:~/MagicMirror/installers $ cat mm.sh
      #!/bin/bash
      if [ $(ps -ef | grep -v grep | grep -i -e xway -e labwc | wc -l) -ne 0 ]; then
         # if WAYLAND_DISPLAYis set, use it, else set to -0
         export WAYLAND_DISPLAY=${WAYLAND_DISPLAY:=wayland-0}
         npm run start:wayland
      else
         DISPLAY=:0 npm run start:x11
      fi
        sdetweil @1a2a3a
        @1a2a3a are you sure this is the script listed in pm2 info output?
        1 1 Reply Last reply
          1a2a3a @sdetweil
          status │ errored │
          │ name │ MagicMirror │
          │ namespace │ default │
          │ version │ 2.36.0 │
          │ restarts │ 45 │
          │ uptime │ 0 │
          │ script path │ /home/hsa/MagicMirror/installers/mm.sh │
          │ script args │ N/A │
          │ error log path │ /home/hsa/.pm2/logs/MagicMirror-error.log │
          │ out log path │ /home/hsa/.pm2/logs/MagicMirror-out.log │
          │ pid path │ /home/hsa/.pm2/pids/MagicMirror-0.pid │
          │ interpreter │ bash │
          │ interpreter args │ N/A │
          │ script id │ 0 │
          │ exec cwd │ /home/hsa/MagicMirror │
          │ exec mode │ fork_mode │
          │ node.js version │ N/A │
          │ node env │ N/A │
          │ watch & reload │ ✘ │
          │ unstable restarts │ 0 │
          │ created at │ N/A
            sdetweil @1a2a3a
            weird… do this
            cd ~/MagicMirror/installers
            curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/refs/heads/master/mm.sh >mm.sh
            then do the
            pm2 stop all
            pm2 start MagicMirror
              1a2a3a @sdetweil
              done, but mirror no response or whatsoever
              hsa@HSA:~ $ cd ~/MagicMirror/installers
              hsa@HSA:~/MagicMirror/installers $ curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/refs/heads/master/mm.sh >mm.sh
              hsa@HSA:~/MagicMirror/installers $ pm2 stop all
              (node:10682) [DEP0044] DeprecationWarning: The `util.isArray` API is deprecated. Please use `Array.isArray()` instead.
              (Use `node --trace-deprecation ...` to show where the warning was created)
              [PM2] Applying action stopProcessId on app [all](ids: [ 0 ])
              [PM2] [all](0) ✓
              │ id │ name               │ mode     │ ↺    │ status    │ cpu      │ memory   │
              │ 0  │ MagicMirror        │ fork     │ 45   │ stopped   │ 0%       │ 0b       │
              hsa@HSA:~/MagicMirror/installers $ pm2 start MagicMirror
              (node:10691) [DEP0044] DeprecationWarning: The `util.isArray` API is deprecated. Please use `Array.isArray()` instead.
              [PM2] Applying action restartProcessId on app [MagicMirror](ids: [ 0 ])
              [PM2] [MagicMirror](0) ✓
              [PM2] Process successfully started
              │ 0  │ MagicMirror        │ fork     │ 45   │ online    │ 0%       │ 2.7mb    │
                sdetweil @1a2a3a
                @1a2a3a and MM is up or not?
                pm2 status
                has the cycle count changed?
                  1a2a3a @sdetweil
                  @sdetweil mm is not up
                  hsa@HSA:~ $ pm2 status
                  │ id │ name           │ namespace   │ version │ mode    │ pid      │ uptime │ ↺    │ status    │ cpu      │ mem      │ user     │ watching │
                  │ 0  │ MagicMirror    │ default     │ 2.36.0  │ fork    │ 12206    │ 15s    │ 49   │ online    │ 0%       │ 2.6mb    │ hsa      │ disabled │
                  hsa@HSA:~ $
                    sdetweil @1a2a3a
                    @1a2a3a
                    pm2 stop all
                    installers/mm.sh
                      1a2a3a @sdetweil
                      @sdetweil did not manage to open MM
                      > magicmirror@2.36.0 start:wayland
                      > WAYLAND_DISPLAY="${WAYLAND_DISPLAY:=wayland-1}" ./node_modules/.bin/electron js/electron.js --ozone-platform=wayland
                      [2026-05-02 02:39:50.838] [LOG]   [app] Starting MagicMirror: v2.36.0
                      [2026-05-02 02:39:50.845] [LOG]   [utils] Loading config ...
                      [2026-05-02 02:39:51.547] [INFO]  [systeminformation]
                      ####  System Information  ####
                      - SYSTEM:   manufacturer: Raspberry Pi Foundation; model: Raspberry Pi 5 Model B Rev 1.0; virtual: false; MM: v2.36.0
                      - OS:       platform: linux; distro: Debian GNU/Linux; release: 12; arch: arm64; kernel: 6.12.75+rpt-rpi-2712
                      - VERSIONS: electron: 41.3.0; used node: 22.21.1; installed node: 22.21.1; npm: 10.9.4; pm2: 6.0.14
                      - ENV:      XDG_SESSION_TYPE: tty; MM_CONFIG_FILE: undefined
                                  WAYLAND_DISPLAY:  wayland-0; DISPLAY: undefined; ELECTRON_ENABLE_GPU: undefined
                      - RAM:      total: 8059.06 MB; free: 6932.14 MB; used: 1126.92 MB
                      - OTHERS:   uptime: 65 minutes; timeZone: Asia/Singapore
                      [2026-05-02 02:40:04.644] [INFO]  [utils] Checking config file /home/hsa/MagicMirror/config/config.js ...
                      [2026-05-02 02:40:04.720] [INFO]  [utils] Your configuration file doesn't contain syntax errors :)
                      [2026-05-02 02:40:04.721] [INFO]  [utils] Checking modules structure configuration ...
                      [2026-05-02 02:40:04.787] [INFO]  [utils] Your modules structure configuration doesn't contain errors :)
                      [2026-05-02 02:40:04.788] [LOG]   [app] Loading module helpers ...
                      [2026-05-02 02:40:04.788] [LOG]   [app] No helper found for module: alert.
                      [2026-05-02 02:40:04.790] [LOG]   [node_helper] Initializing new module helper ...
                      [2026-05-02 02:40:04.791] [LOG]   [node_helper] Module helper loaded: updatenotification
                      [2026-05-02 02:40:04.791] [LOG]   [app] No helper found for module: clock.
                      [2026-05-02 02:40:04.891] [LOG]   [node_helper] Initializing new module helper ...
                      [2026-05-02 02:40:04.891] [LOG]   [node_helper] Module helper loaded: MMM-Jast
                      [2026-05-02 02:40:05.554] [LOG]   [node_helper] Initializing new module helper ...
                      [2026-05-02 02:40:05.555] [LOG]   [node_helper] Module helper loaded: MMM-GoogleDocs-Notes
                      [2026-05-02 02:40:05.580] [LOG]   [node_helper] Initializing new module helper ...
                      [2026-05-02 02:40:05.580] [LOG]   [node_helper] Module helper loaded: newsfeed
                      [2026-05-02 02:40:05.586] [LOG]   [node_helper] Initializing new module helper ...
                      [2026-05-02 02:40:05.586] [LOG]   [app] Check MagicMirror² version for node helper 'MMM-NewsAPI' - Minimum version: 2.21.0 - Current version: 2.36.0
                      [2026-05-02 02:40:05.587] [LOG]   [app] Version is ok!
                      [2026-05-02 02:40:05.587] [LOG]   [node_helper] Module helper loaded: MMM-NewsAPI
                      [2026-05-02 02:40:05.588] [LOG]   [node_helper] Initializing new module helper ...
                      [2026-05-02 02:40:05.588] [LOG]   [node_helper] Module helper loaded: MMM-MyScoreboard
                      [2026-05-02 02:40:05.595] [LOG]   [node_helper] Initializing new module helper ...
                      [2026-05-02 02:40:05.595] [LOG]   [app] Check MagicMirror² version for node helper 'MMM-SoccerLiveScore' - Minimum version: 2.1.0 - Current version: 2.36.0
                      [2026-05-02 02:40:05.595] [LOG]   [app] Version is ok!
                      [2026-05-02 02:40:05.595] [LOG]   [node_helper] Module helper loaded: MMM-SoccerLiveScore
                      [2026-05-02 02:40:05.688] [LOG]   [node_helper] Initializing new module helper ...
                      [2026-05-02 02:40:05.688] [LOG]   [node_helper] Module helper loaded: MMM-OneDrive
                      [2026-05-02 02:40:05.689] [LOG]   [node_helper] Initializing new module helper ...
                      [2026-05-02 02:40:05.689] [LOG]   [node_helper] Module helper loaded: MMM-CalendarExt3Agenda
                      [2026-05-02 02:40:05.746] [LOG]   [node_helper] Initializing new module helper ...
                      [2026-05-02 02:40:05.746] [LOG]   [node_helper] Module helper loaded: calendar
                      [2026-05-02 02:40:05.747] [LOG]   [node_helper] Initializing new module helper ...
                      [2026-05-02 02:40:05.747] [LOG]   [node_helper] Module helper loaded: MMM-CalendarExt3
                      [2026-05-02 02:40:05.747] [LOG]   [app] All module helpers loaded.
                      [2026-05-02 02:40:05.751] [LOG]   [server] Starting server on port 8080 ...
                      [2026-05-02 02:40:05.760] [ERROR] [unknown] (node:13239) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
                      (Use `electron --trace-deprecation ...` to show where the warning was created)
                      [13239:0502/024005.762036:ERROR:ui/ozone/platform/wayland/host/wayland_connection.cc:202] Failed to connect to Wayland display: No such file or directory (2)
                      [13239:0502/024005.762106:ERROR:ui/ozone/platform/wayland/ozone_platform_wayland.cc:281] Failed to initialize Wayland platform
                      [13239:0502/024005.762122:ERROR:ui/aura/env.cc:246] The platform failed to initialize.  Exiting.
                      /home/hsa/MagicMirror/node_modules/electron/dist/electron exited with signal SIGSEGV
                      hsa@HSA:~/MagicMirror $
                        sdetweil @1a2a3a
                        @1a2a3a ok, it still thinks wayland is active.
                        nano  installers/mm.sh
                        change line
                        to
                          if [ $(ps -ef | grep -v grep | grep -i -e xway -e labwc | wc -l) -ne 1 ]; then
                        ctrl-o,
                        enter
                        ctrl-x
                        then
                        installers/mm.sh
                          1a2a3a @sdetweil
                          @sdetweil ok it runs now. what do i do next?
                          edit sorry obviously stupid. just pm2 start and we are GOLD :D
                          thanks again!
                            sdetweil @1a2a3a
                            @1a2a3a yeh, weird tho
                            can you show me output of
                            lsb_release -a
                            uname -a
                            weird it thinks wayland, but won’t run that way
                              1a2a3a @sdetweil
                              hsa@HSA:~/MagicMirror $ lsb_release -a
                              No LSB modules are available.
                              Distributor ID: Debian
                              Description:    Debian GNU/Linux 12 (bookworm)
                              Release:        12
                              Codename:       bookworm
                              hsa@HSA:~/MagicMirror $ uname -a
                              Linux HSA 6.12.75+rpt-rpi-2712 #1 SMP PREEMPT Debian 1:6.12.75-1+rpt1~bookworm (2026-03-11) aarch64 GNU/Linux
                              S 1 2 Replies Last reply
                                sdetweil @1a2a3a
                                @1a2a3a thanks…
                                  1a2a3a @1a2a3a
                                  @sdetweil dont know man, gets even weirder.
                                  i cant turn on mm using the terminal on the pi directly.
                                  i tried npm run start:x11 and it will just close off with a /home/hsa/MagicMirror/node_modules/electron/dist/electron exited with signal SIGSEGV
                                  i can now only turn on my mm using pm2 on my ssh terminal…
                                  btw i have a cron job, not sure if this is causing the issue
                                  crontab -e
                                  38 00 * * * /home/HSA/display_on.sh
                                  37 00 * * * /home/HSA/display_off.sh
                                  display_off.sh
                                  #!/bin/bash
                                  export WAYLAND_DISPLAY=wayland-1
                                  export XDG_RUNTIME_DIR=/run/user/1000
                                  /usr/bin/wlr-randr --output HDMI-A-2 --off
                                  display_on.sh
                                  #!/bin/bash
                                  /usr/bin/wlr-randr --output HDMI-A-2 --on --transform 90
                                    sdetweil @1a2a3a
                                    @1a2a3a yeh… weird indeed… those scripts are wayland based…
                                    ok, open a new terminal window
                                    and do
                                    env
                                    to dump out the environment variables…
                                    check to make sure none expose any info you don’t want shown here and paste the cleaned list
                                      1a2a3a @sdetweil
                                      @sdetweil uhm which are the info that are sensitive?
                                      so im actually wayland instead of x11?
                                        sdetweil @1a2a3a
                                        @1a2a3a sensitive
                                        name, address, zipcode, apikeys, passwords…
                                          1a2a3a @sdetweil
                                          @sdetweil this safe?
                                          SHELL=/bin/bash
                                          LANGUAGE=en_US.UTF-8
                                          NO_AT_BRIDGE=1
                                          XDG_SESSION_TYPE=tty
                                          MOTD_SHOWN=pam
                                          LANG=en_US.UTF-8
                                          LS_COLORS=rs=0:di=01;34:ln=01;36:mh=00:pi=40;33:so=01;35:do=01;35:bd=40;33;01:cd=40;33;01:or=40;31;01:mi=00:su=37;41:sg=30;43:ca=00:tw=30;42:ow=34;42:st=37;44:ex=01;32:*.tar=01;31:*.tgz=01;31:*.arc=01;31:*.arj=01;31:*.taz=01;31:*.lha=01;31:*.lz4=01;31:*.lzh=01;31:*.lzma=01;31:*.tlz=01;31:*.txz=01;31:*.tzo=01;31:*.t7z=01;31:*.zip=01;31:*.z=01;31:*.dz=01;31:*.gz=01;31:*.lrz=01;31:*.lz=01;31:*.lzo=01;31:*.xz=01;31:*.zst=01;31:*.tzst=01;31:*.bz2=01;31:*.bz=01;31:*.tbz=01;31:*.tbz2=01;31:*.tz=01;31:*.deb=01;31:*.rpm=01;31:*.jar=01;31:*.war=01;31:*.ear=01;31:*.sar=01;31:*.rar=01;31:*.alz=01;31:*.ace=01;31:*.zoo=01;31:*.cpio=01;31:*.7z=01;31:*.rz=01;31:*.cab=01;31:*.wim=01;31:*.swm=01;31:*.dwm=01;31:*.esd=01;31:*.avif=01;35:*.jpg=01;35:*.jpeg=01;35:*.mjpg=01;35:*.mjpeg=01;35:*.gif=01;35:*.bmp=01;35:*.pbm=01;35:*.pgm=01;35:*.ppm=01;35:*.tga=01;35:*.xbm=01;35:*.xpm=01;35:*.tif=01;35:*.tiff=01;35:*.png=01;35:*.svg=01;35:*.svgz=01;35:*.mng=01;35:*.pcx=01;35:*.mov=01;35:*.mpg=01;35:*.mpeg=01;35:*.m2v=01;35:*.mkv=01;35:*.webm=01;35:*.webp=01;35:*.ogm=01;35:*.mp4=01;35:*.m4v=01;35:*.mp4v=01;35:*.vob=01;35:*.qt=01;35:*.nuv=01;35:*.wmv=01;35:*.asf=01;35:*.rm=01;35:*.rmvb=01;35:*.flc=01;35:*.avi=01;35:*.fli=01;35:*.flv=01;35:*.gl=01;35:*.dl=01;35:*.xcf=01;35:*.xwd=01;35:*.yuv=01;35:*.cgm=01;35:*.emf=01;35:*.ogv=01;35:*.ogx=01;35:*.aac=00;36:*.au=00;36:*.flac=00;36:*.m4a=00;36:*.mid=00;36:*.midi=00;36:*.mka=00;36:*.mp3=00;36:*.mpc=00;36:*.ogg=00;36:*.ra=00;36:*.wav=00;36:*.oga=00;36:*.opus=00;36:*.spx=00;36:*.xspf=00;36:*~=00;90:*#=00;90:*.bak=00;90:*.old=00;90:*.orig=00;90:*.part=00;90:*.rej=00;90:*.swp=00;90:*.tmp=00;90:*.dpkg-dist=00;90:*.dpkg-old=00;90:*.ucf-dist=00;90:*.ucf-new=00;90:*.ucf-old=00;90:*.rpmnew=00;90:*.rpmorig=00;90:*.rpmsave=00;90:
                                          XDG_SESSION_CLASS=user
                                          TERM=xterm
                                          SHLVL=1
                                          XDG_SESSION_ID=6
                                          LC_ALL=en_US.UTF-8
                                          DBUS_SESSION_BUS_ADDRESS=unix:path=/run/user/1000/bus
                                          SSH_TTY=/dev/pts/0
                                          _=/usr/bin/env
                                            sdetweil @1a2a3a
                                            @1a2a3a yeh, fine, but no wayland info there
                                            I see a diff on my mm.sh
                                            if wayland_display is not set, then I set it to
                                            WAYLAND_DISPLAY=wayland-0
                                            but your scripts use wayland-1
                                            SO, lets try this
                                            edit mm.sh again
                                            change this line
                                            back to
                                            and change this line
                                            to
                                            export WAYLAND_DISPLAY=${WAYLAND_DISPLAY:=wayland-1}
                                            and save mm.sh
                                            then
                                            pm2 stop all
                                            • 3 / 4
