    MM clock reverted to UTC
    9 Posts 4 Posters 479 Views 4 Watching
      smegbadger
      Hi
      After a recent reboot (to update MMM-CalendarExt3Agenda and add some more dates to MMM-MyGarbage) I’ve noticed that the clock and agenda modules have reverted to UTC (should be BST right now).
      A quick look shows the docker container is now running with UTC (although the RPi is correctly on BST):
      magicm@magicmirror:~ $ date
      Sun  3 May 09:02:24 BST 2026
      magicm@magicmirror:~ $ docker exec -it mm bash
      node@magicmirror:/opt/magic_mirror$ date
      Sun May  3 08:02:36 AM UTC 2026
      I’ve not set the timezone (or date format) explicitly for the Docker before. Has a new release of Docker changed that and, if so, how do I pass that setting through?
      Many thanks
      Steve
        sdetweil @smegbadger
        @smegbadger you would have to load the develop branch of MagicMirror, as we don’t distribute less than the full package…
        see this link
        https://forum.magicmirror.builders/topic/14327/testing-new-fixes-or-solving-current-problems-with-next-release-code
        • karsten13K Offline
          karsten13 @smegbadger
          @smegbadger
          The external url for getting the TZ doesn’t work anymore, I had to switch to another one. Meanwhile this did not work but I pushed new images some minutes ago which should fix this. So please pull the new image and let me know if it works.
            smegbadger @karsten13
            @karsten13
            I did a docker compose pull in the opt/mm/run directory and that was successful
            magicm@magicmirror:/opt/mm/run $ docker compose pull
            [+] Pulling 17/17
             ✔ labwc Pulled        0.9s
             ✔ magicmirror Pulled        81.9s
               ✔ 76b7b92b680d Already exists        0.0s
               ✔ 5ee1ed488d07 Already exists        0.0s
               ✔ 3154f7f9972b Already exists        0.0s
               ✔ 73114b557eb0 Already exists        0.0s
               ✔ 563f46f75d49 Already exists        0.0s
               ✔ ad0a7f3409e8 Already exists        0.0s
               ✔ 5a172ff577b3 Already exists        0.0s
               ✔ 39715dbbbd4f Already exists        0.0s
               ✔ 189de6907d33 Already exists        0.0s
               ✔ e8dbedaf8b5d Pull complete        0.4s
               ✔ 3c77d19aac28 Pull complete        0.5s
               ✔ 8d20b36a9778 Pull complete        0.5s
               ✔ 1d705635a0a9 Pull complete        51.6s
               ✔ 5c309722c0df Pull complete        80.1s
               ✔ 4f4fb700ef54 Pull complete        80.2s
            but the clock and agenda are still on UTC. The Docker logs state this early on
            [INFO] ***WARNING*** could not set timezone, please set TZ variable in compose.yaml, see https://khassel.gitlab.io/magicmirror/configuration/#timezone
            UPDATE
            Before I could send this another day passed and now they are correct! Docker is still on UTC but the Clock and Agenda are correctly showing times on BST!
            Tue  5 May 12:15:21 BST 2026
            Tue May  5 11:15:28 AM UTC 2026
            mumblebajM karsten13K 2 Replies Last reply Reply Quote 0
              smegbadger
              There is a git error in the Docker logs for MMM-CalendarExt3Agenda, though
              [2026-05-05 12:14:05.460] [ERROR] [updatenotification] Failed to get git revisions for MMM-CalendarExt3Agenda: Error: Command failed: git rev-list --ancestry-path --count 72816f2..ed664f3  main
              fatal: ambiguous argument '72816f2..ed664f3  main': unknown revision or path not in the working tree.
              Use '--' to separate paths from revisions, like this:
              'git <command> [<revision>...] -- [<file>...]'
              S S 2 Replies Last reply Reply Quote 0
                @smegbadger yes, we have a fix for that. It’s from the updatenotification module.
                • mumblebajM Offline
                  mumblebaj Module Developer @smegbadger
                  @smegbadger Not sure if this would work for you but you can set this in you docker-compose.yml under volumes:
                  - /etc/timezone:/etc/timezone:ro this should take the timezone from the host.
                    Thanks for the feedback. This is expected behavior. If you really need the timezone for other stuff in the container you can set it by adding this in the compose.yaml:
                        environment:
                          - TZ=Europe/Berlin
                      smegbadger @smegbadger
                      @sdetweil What’s the procedure to update that module?
                        see this link
                        • S smegbadger has marked this topic as solved on
