    MMM-Carousel breaks with multiple instances of module by using positional
    5 Posts 2 Posters 241 Views 2 Watching
    • G Offline
      gonzonia
      Re: MMM-Carousel - how to configure a module multiple times on the SAME page?
      I looked through that thread but it doesn’t quite help with my issue.
      I’m using scenes 2 on my calendars to rotate between the various family calendars.
      In the top_left in trying to display weather info that rotates separately and aren’t part of the scenes . I’m trying to do that with carousel. It works great with 3 modules all different. The moment I had another instance of weather into the mix the last module no longer shows. I just get a blank area when it should show that module .
      Any pointers on where to look?
        sdetweil @gonzonia
        @gonzonia see this post
        https://forum.magicmirror.builders/topic/18218/mmm-carousel-two-of-the-same-module
        I like MMM-Pages for this
        • G Offline
          gonzonia @sdetweil
          Thanks. I tried Pages, but it seems like it’s an all or nothing situation. Each page has to be set up and it would change all the elements between pages. What I like about Scenes2 is if I don’t have a class from a scene assigned to an element, that element remains unaffected. This is why with a combination of Scenes2 and Carousel I can have multiple areas changing independently at different times. So I have the “Weather” area rotating between options there that appear all the time, and then the calendars rotating independently. I may be missing something but I don’t think I can do that with Pages.
          G S 2 Replies Last reply Reply Quote 0
          • G Offline
            gonzonia @gonzonia
            I got it working. The problem was a misconfiguration in one of the modules (not carousel).
              sdetweil @gonzonia
              @gonzonia you didn’t mention scenes before. But it’s just another module
