    MMM-GoogleCalendar reports 2 commits behind but I can't resolve them.
    3 Posts 2 Posters 20 Views 2 Watching
      reilley
      A couple of weeks ago, MagicMirror started displaying a message that the MMM-GoogleCalendar module is behind by two commits, but I’ve git-pulled and installed, merged as required, and ran the npm install but it’s still showing as being behind. I ran npm audit fix and two moderate issues appear, but not sure how to fix them. I’ve installed the latest GAXIOS version as suggested but no joy.
      Any ideas?
        sdetweil @reilley
        @reilley I just did the git pull on my installation
        git pull
        remote: Enumerating objects: 58, done.
        remote: Counting objects: 100% (36/36), done.
        remote: Compressing objects: 100% (14/14), done.
        remote: Total 58 (delta 25), reused 27 (delta 22), pack-reused 22 (from 1)
        Unpacking objects: 100% (58/58), 205.78 KiB | 1.34 MiB/s, done.
        From https://github.com/randomBrainstormer/MMM-GoogleCalendar
           8679522..faf438e  main       -> origin/main
         * [new tag]         v1.2.7     -> v1.2.7
         * [new tag]         v1.2.5     -> v1.2.5
         * [new tag]         v1.2.6     -> v1.2.6
        Updating 8679522..faf438e
        Fast-forward
         .github/workflows/version-bump.yml   |  55 +++++++++++++++++++++++++++++++++++++++++++++++++++++++
         MMM-GoogleCalendar.js                | 108 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++----
         __tests__/MMM-GoogleCalendar.test.js | 102 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
         node_helper.js                       |  49 +++++++++++++++++++++++++++++++++++++++++++++++--
         package-lock.json                    |   4 ++--
         package.json                         |   2 +-
         translations/en.json                 |   3 ++-
         7 files changed, 313 insertions(+), 10 deletions(-)
         create mode 100644 .github/workflows/version-bump.yml
        sam@sams:~/MagicMirror.2.36.dev/modules/MMM-GoogleCalendar$ npm install
        up to date, audited 383 packages in 2s
        65 packages are looking for funding
          run `npm fund` for details
        12 vulnerabilities (8 moderate, 4 high)
        To address issues that do not require attention, run:
          npm audit fix
        To address all issues (including breaking changes), run:
          npm audit fix --force
        Run `npm audit` for details.
        and updatenotification does not report being behind
          reilley @sdetweil
          @sdetweil - Hi Sam! Surprisingly, the error may not show up for a while after you make changes and restart.
