    MMM-CalendarExt3 full color for timed events
    8 Posts 2 Posters 22 Views 2 Watching
      Jk1
      Hi. I have my MagicMirror pretty much set up the way I want except for one little thing…
      I would like the timed events to have the same block coloring as the full day events. Right now, it’s just the text that’s colored. Is there a way to do this?
      I eventually will also change the color based on the keyword in the title which I already know how to do for the text. I’m assuming it’ll be the same for the full entry coloring?
        sdetweil @Jk1
        @Jk1 see https://forum.magicmirror.builders/post/131110
          Jk1 @sdetweil
          @sdetweil Yeah, I saw that before but it only colors the text. I want to have it color the whole line like the full-day event.
            sdetweil @Jk1
            @Jk1 try
            .CX3 .headline {
              color: var(--calendarColor);
            from here
            https://github.com/MMRIZE/MMM-CalendarExt3#styling-with-css
              Jk1 @sdetweil
              @sdetweil That didn’t work either. Here’s my custom.css file… maybe something sticks out to you?
              I appreciate the help.
              custom.css
              .normal,
              .dimmed,
              header,
              body {
                color: #fff;
              .CX3 .headline {
              /* set text color to match color for the calendar list */
              .CX3 .event:not(.fullday) .headline .title {
              /* Remove the colored dot marker completely in CalendarExt3 */
              .CX3 .event.singleday .headline:not(.useSymbol)::before,
              .CX3 .event.singleday .headline.useSymbol .symbol.noSymbol::before {
                display: none !important;
              /* Optional: Clean up spacing if the headline text looks cut off */
              .CX3 .event .headline {
                padding-left: 0px !important;
                margin-left: 0px !important;
                sdetweil @Jk1
                @Jk1 css works top of the file down
                So you set it, then changed it
                It works on my Ext3
                  Jk1 @sdetweil
                  @sdetweil i’m probably missing something…
                  I removed all of the other .CX3 entries and left this.
                  .normal,
                  .dimmed,
                  header,
                  body {
                    color: #fff;
                  .CX3 .headline {
                  and this is what it shows.
                    sdetweil @Jk1
                    @Jk1
                    ok, tried again
                      color: green;
